inching for an upgrade advice?
Started by tonkoshala, June 24, 2009, 05:44:49 PM
foggy123
Quote from: Speeddog on June 26, 2009, 09:10:34 AM
@ foggy123, what are your engine mods?
Pretty simple-
996 st4s motor (now 1080)
1000 crank (balanced for rods/pistons)
916 MBP red heads
506 cams
Lightened flywheel
Motowheels slipper
K&N pod filters
Stock FI  :P
Power commander dual map (individual cylinders)
Compression just under 13:1 so Premium gas.
How did you deal with the piston height at TDC due to the longer crank?
foggy123
Cylinders were shimmed up with base gaskets.
Bigger problem was using a 916 heads on 996.  New holes and smaller CC had to be opened up.
Bruce Myers did the build.
OK, a base gasket 'shim' was what I was going to do.
I'll have to deal with belt length somehow.
Do you mean 916 SBK heads or 916 S4 heads?
redial
ug both those dynos are straight sex.  [evil]
foggy123
Quote from: Speeddog on June 26, 2009, 10:06:01 AM
916 s4 heads were used.  stm adjustable pulleys.
Another thing is belt covers won't work the same way so not running them.
Quote from: foggy123 on June 26, 2009, 10:56:56 AM
Cool, thanks for the info.  [beer]
tonkoshala
Ordered a set of BST. Should see them next week!
tonkoshala
Ran across this a few minutes ago.
http://www.virdung.net/S4mainpage.html
Is this one of you guys?
ghostface
Quote from: tonkoshala on June 26, 2009, 03:49:18 PM
Nice, stil lthe C.A.D. I see! I can't wait to get some side cash for more building!
tonkoshala
Quote from: ghostface on June 30, 2009, 11:25:14 AM
:) thank bud
Couple of questions.
What size frame plugs work on our bikes? I've been looking at them for a minute now and think some red ones would really add to my bike. Also what do you do to lower the dash?
tonkoshala
Knock on the door BSTs have arrived! Will post pics soon. Now I'm really hating my clutch lever mishap...
tonkoshala
Finally got them installed! Nothing comes easy  8)
Man oh man. I'm needing a ride on that bike in a hurry. For more go-fast motor ideas, try picking the brains of the MBP guys, or Ducshop in Atlanta. They do go fast stuff. OR give your bike to me, and i will ride the buisiness right out of it, and at least ONE of us will be quite thrilled with the experience.
thruxton
