February 08, 2025, 07:25:08 PM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: tyre pressures when riding with a pillion?  (Read 2707 times)
kursed
« on: August 04, 2009, 04:09:36 PM »
hey guys,
what pressures do you run front / back when you have pillions? I am just getting into taking passengers and the oddness of the way the bike handles when I do!!
any tips?
I'm running pilot road2 f/r
its an s2r1000
pillions are usually about 70 - 80kg and I am about 78kg
cheers!
dragonworld.
I can make like a tripod with my.....
« Reply #1 on: August 04, 2009, 04:22:54 PM »
Usually the front doesnt need to be raised by much if at all, but the main load carrying wheel definately needs an increase of maybe 5psi with a turn increase on the spring and 1 click increase on the rebound damping (and same on compression damping if fitted) Grin
You manual will give you a "Load Carrying" tyre pressure recommendation, use these as a starting point and see how you go.  waytogo
Six95
07 695
« Reply #2 on: August 04, 2009, 04:36:17 PM »
I take my wife with me everywhere - most times.
I just have my rear at the maximum recommended, which on my bike is 2.4bar. My rear is a 160, so it will be different for yours.
I used to religously piss about with the pre-load and damping which is a good thing, but now a pain in the ass having to set it back and forth whenever I go by myself
I now just leave it set for a single rider, when she gets on it sags a little but we manage to get from A-B without any handle issues.
The sound of Ducati - A symphony of internal combustion
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
« Reply #3 on: August 06, 2009, 02:02:20 PM »
upgrade pillions...you should be able to get something decent around the 50 to 55kg mark and that way will cause less problems...and I've heard if you train them right in balnace/weight transfer/cornering then they have a lot less impact.
Dannog
S4RS
« Reply #4 on: August 06, 2009, 02:15:03 PM »
upgrade pillions.....you should be able to get something decent around the 50 to 55kg mark and that way will cause less problems
Top advice Spider....unfortunately that upgrade could cost just too much. Better top get a new shock with remote preload!
kursed
« Reply #5 on: August 06, 2009, 02:48:30 PM »
cheers guys.
the pillions 70kgs because its my mate who wants to see what it feels like to ride (another conversion to the ducati dark side) and pillion was the easiest way to show him some semblance of what it is like.
Still haven't been able to convince my gf to give it a try Smiley
I run 32 / 35psi at present. what do you guys run on pilots?
dragonworld.
« Reply #6 on: August 06, 2009, 03:03:34 PM »
Pretty much the same:
750 with the 160 rear 32/34
1000DS        180 rear 32/36
And that is using a Michelin tyre gauge, different gauges can definately read +/- quite a bit. I NEVER use gauges at servos.  Roll Eyes
Using the same gauge all the time gives a constant in setting pressures. waytogo
Trap for young players. Grin
Betty
« Reply #7 on: August 06, 2009, 03:23:52 PM »
Dragon, can you please explain the lower pressure for the lesser volume tyre? ... remember I not too bright.
I think Julie only runs about 20 in Lillie (think tiny, tiny tyres) ... I am not too sure why, just do as I'm told Grin. But we run the same pressures in the Monsters (think your two).
Thanks
dragonworld.
« Reply #8 on: August 06, 2009, 03:35:34 PM »
Hmmmm. good question Betty!!  Huh?
I can only theorise that it has something to do with air compressability and the larger volume in the lager (Oops larger, thinking  chug again.) tyre.
The larger cavity needing a higher pressure to maintain its working, most efficient shape and temperature.  waytogo
Might have to do some Googling. Grin
Spider
« Reply #9 on: August 06, 2009, 04:34:29 PM »
haven't done research into the S4rs...comes with a OEM spec DU321? with remote preload?
the DU333 (top of the line for monsters) does....
but not really an option if it's just 'mate' riding...has there evrer been anyone who liked the pillon on a monster?  Huh?
Betty
« Reply #10 on: August 06, 2009, 04:58:16 PM »
Jukie hated it so much she bought me my own Monster  laughingdp
Dannog
S4RS
« Reply #11 on: August 06, 2009, 05:16:04 PM »
S4RS - has external piggyback reservoir to adjust the compression damping but no remote preload adjustment Cry
« Last Edit: August 06, 2009, 05:28:26 PM by Dannog » Logged
bazz20
« Reply #12 on: August 06, 2009, 05:29:12 PM »
i run 34-f 36-r on the pilot powers , i have rased the front pressure a little more than i like to try and get a bit more tyre life out of the front , i dont worry about changing pressure when i chuck wifie on the back just allow for the extra weight and slow down  waytogo
Big T
Bikeless..........
« Reply #13 on: August 06, 2009, 05:38:32 PM »
07 S4RT
This is what "my" tire pressure gauge shows.
I use the same gauge always to measure.
And totally agree different gauges will show different pressures. The gauge on my eclectic pump, foot pump and hand gauge can vary by 4-8 PSI.
Rear Tire: 34 PSI
180/55 ZR 17
Front Tire: 34 PSI
120/70 ZR 17
Works for me.......  [moto]
   .... This is your captain speaking. Please fasten your seat-belts as we prepare for take off.... (I'm the passenger now....)
bazz20
« Reply #14 on: August 06, 2009, 06:00:12 PM »
07 S4RT
Rear Tire: 34 PSI
180/55 ZR 17
Front Tire: 34 PSI
120/70 ZR 17
and gives you funny spots on ya hoops  Grin
Pages: [1] 2   Go Up
