February 22, 2025, 11:17:26 PM
Bt-014's
Topic: Bt-014's (Read 3580 times)
scduc
Bt-014's
August 29, 2009, 12:23:23 PM »
I have my bike in for service, and will be haveing them replace the rear with same as stock BT-014. I was happy with the performance and life of the tire(7500 miles). Does any one know of a reason not to buy this tire?
08' S2R 1K That was close damn near lost a $400 hand cart.
S2R 800 '07
Re: Bt-014's
August 29, 2009, 02:06:03 PM »
I had the 014 as stock - changed to Metzeler Sportec M3 - WOW
One of the important differences is the profile. M3s are rounder - meaning they turn more easily and allow further lean angle. The flatter profile of the 014 will mean more rubber on the ground (confidence) up to the point where there is no more (disaster).
The most commonly chosen tires are all better than the 014, I think. If you don't want to leave the brand, at least look into the 016s.
Your next question might be: is it ok to have two different brands/models front and rear? Answers will vary, but bottom
line is yes.
EEL
Re: Bt-014's
August 29, 2009, 07:01:22 PM »
Replace with BT016 You will not regret it
Re: Bt-014's
August 29, 2009, 08:59:52 PM »
how do you ride your bike?
WHat is hte main function of your bike?
I would probably never get the Pilot Sport 2ct just because i commute so much, but damn is it good make the beast with two backsing tire.
scduc
Re: Bt-014's
August 30, 2009, 12:39:15 PM »
I'll call the dealer first thing in the morning and chage to the Bt-016. I should be ok with the Bt-014 up front yes?
S2R 800 '07
Re: Bt-014's
August 30, 2009, 01:10:40 PM »
Quote from: scduc on August 30, 2009, 12:39:15 PM
If the different profile also applies for the front - then, in theory, you will run out of front tire before you run out of rear tire. Most people report that they don't use all of the front, but more often all of the rear.
Forget my theory, this issue is very insignificant and you will be fine
When you eventually also change the front tire - you might get an aha moment. Bonus is that you will know what a tire change does to the front versus the rear.
El Matador
Do I need knee pucks for my
Re: Bt-014's
August 30, 2009, 01:14:43 PM »
Quote from: He Man on August 29, 2009, 08:59:52 PM
Pilot Road 2ct.
CairnsDuc
Re: Bt-014's
August 30, 2009, 01:26:00 PM »
Throw on the 016, it is a much better Tyre than the 014, If your bike does a lot of Commuting, you may want to consider the 021 Sports/Touring tyre, I have had the 016 on the rear until I switched to the 021.
I Commute everyday so I needed the harder compound of the 021, but I still like to get out on the local Mountain range, and the 021 so far has been better than I thought and is wearing very well doing the commute duties, and It still grips very well when at full attack on the Range (better than I thought actually) I still run an 016 on the front, I prefer the better grip the 016 offers on the front.
nicrosato
I refuse to join any club that would have me as a
Red Dog with Yellow Dog
Re: Bt-014's
September 28, 2009, 12:56:11 PM »
While I'm out here in Albuquerque riding here and there on my '97n M900 and meeting members of the NMMR, my '01 is back at the dealer on Long Island. Since I am replacing both front and rear, I had a detailed discussion with him about which tires to fit. The bike came with Pilot Sports. I do no track days and the bike is mostly a commuter; the Sports had worn down the center. He recommended BT-021's which he said would wear longer and give me enough grip for those times I want to push the bike a little.
Anyone have any long-term (a few thousand miles) experience with the BT-021's? I'd be interested in the feedback. Thanks...
Nobody said that I did. Everyone says that I would.
brent9632
Re: Bt-014's
September 28, 2009, 02:45:21 PM »
Quote from: El Matador on August 30, 2009, 01:14:43 PM
Pilot Road 2ct.
+1 I swithched from pilot power 2ct rear to the Pilot Road 2ct on my 07 1k and there was almost not difference except for the longer wear life.
"Ride it like its your last"
-2007 S2R1000 red and white with carbon termis and DP CPU
Greg
Re: Bt-014's
September 28, 2009, 03:36:11 PM »
Quote from: EEL on August 29, 2009, 07:01:22 PM
I agree the BT016's are awesome, they have fantastic grip and they inspire a lot of confidence in corners, however they do wear pretty quickly.
2012 M1100 Evo with Termis
Kirk Allen
Re: Bt-014's
December 29, 2010, 02:29:49 PM »
hey fellows, Sorry if its a bit off topic. What kind of tyre pressures do you run on the BT-014s? The tyre says max 42psi, Should i try to maintain that? Most of my riding is twisty Spanish roads but no track days yet... Thanks for the input.
S2R 800 '07
Re: Bt-014's
December 29, 2010, 02:37:07 PM »
Quote from: monstro72 on December 29, 2010, 02:29:49 PM
42psi is max. More suitable for normal riding would be around 32 or 34
Kirk Allen
Re: Bt-014's
December 29, 2010, 02:47:13 PM »
Quote from: stopintime on December 29, 2010, 02:37:07 PM
Thanks!
Düb Lüv
ASE master internet mechanic
Re: Bt-014's
Reply #14 on:
December 29, 2010, 07:37:32 PM »
i have the PP2's and love them. i've commuted about 1.5K on them and the centers aren't indexed yet. the good thing about the BT-016's are that they have 3 different compounds on the tire. hard in the center for commuting, medium and soft on the sides. the reason i didn't go with those is because the rear tire weighted almost 1.5lbs more than the PP2's.
no matter what tire you buy, please don't try to get a donkey kong wide tire.
Building, building, building
