September 01, 2024, 07:19:39 AM
Please Help
DIY Painting Tips
38
39
40
41
67
Topic: DIY Painting Tips (Read 398893 times)
TitanMonsterS4R
Re: DIY Painting Tips
Reply #570 on:
November 01, 2011, 05:26:42 PM »
Instructions say to to just clean, score with a scotch pad, wash, dry and paint. I got the cure part from reading previous posts.
Langanobob
Reply #571 on:
November 02, 2011, 01:55:07 AM »
DP, I think those Speedymoto belt covers are anodized. If so, will an anodized surface require a different prep than bare aluminum?
Bob
Edit: Just saw the part about scoring the surface with a Scotchbrite pad, maybe that will deal with paint bonding to the anodized surface.
Last Edit: November 02, 2011, 01:59:03 AM by Langanobob
Reply #572 on:
November 02, 2011, 02:53:58 AM »
Quote from: Langanobob on November 02, 2011, 01:55:07 AM
Bob
Good catch
Anodized parts require abrasion, and Alodine will do nothing.
I would use an epoxy primer on the anodizing and then an activated urethane.
In the OP's case I'd follow label directions.
TitanMonsterS4R
Reply #573 on:
November 02, 2011, 04:49:47 AM »
Quote from: ducpainter on November 02, 2011, 02:53:58 AM
Good catch
The circles which were anodized were powdercoated to make things just a little more complicated
Reply #574 on:
November 02, 2011, 05:02:31 AM »
Quote from: MadDuc 20/20 on November 02, 2011, 04:49:47 AM
What is the state of the parts you want to paint?
Bare...anodized...?
Josh_357
Reply #575 on:
November 02, 2011, 05:04:10 AM »
Hey ducpainter,
I got two questions. First is mostly a story with a "what'd I do wrong?" Wanted to paint my own red with black stripe s4r seat cowl. So I bought an unpainted OEM cowl, prepped it, painted with acrylic base coat in a an aerosol from here
http://www.repaintsupply.com/pd_aerosol.cfm.
I let paint set for about a day. Then laid the oem black stripe decal over the base coat. Now here's probably where I went wrong. I did not color sand, didn't think I needed to. Then I laid the oem decal dry, wasn't sure I could wet lay it and only had one decal. I didn't have any bubble visible though.
Then I sprayed 2K spraymax urethane clear in aerosol,
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm.
I let that set up for a couple days then wetsand and polish to a shine. The cowl looked great, see pic of old broken and shiny new one I did below.
Then all hell broke loose! First time out in sun I got a ton of bubbles under the decal. Looks like a teenagers acne face! Where'd I go wrong?
My plan of attack now is to cut the decals out and paint the stripe and reclear, but what could I do different next time?
Second question is quick, any experience with paintless dent repair? Like this
http://motorcyclepaintlessdentrepair.com/testamonials.html
TitanMonsterS4R
Reply #576 on:
November 02, 2011, 05:09:42 AM »
Quote from: ducpainter on November 02, 2011, 05:02:31 AM
Bare...anodized...?
See pic below. The belt covers (circles) themselves are powdercoated yellow and the rest of the belt cover is 6061 billet aluminum (not colored).
Reply #577 on:
November 02, 2011, 05:23:35 AM »
Quote from: Josh_357 on November 02, 2011, 05:04:10 AM
Hey ducpainter,
You didn't wait long enough to apply the decal. Solvents got trapped under the vinyl and that is the result.
You may have difficulty applying the decal and not having some evidence of the repair. Good luck.
My limited experience with paintless repair is that it is never perfect.
Reply #578 on:
November 02, 2011, 05:27:00 AM »
Quote from: MadDuc 20/20 on November 02, 2011, 05:09:42 AM
That is also anodized.
It will need to be scotch brited at the minimum.
As I said, I use epoxy primer because that is the standard for use over anodizing in the aerospace/mil spec world. It works.
Some materials are not suitable for use over epoxy primer.
I think in your case, not knowing what the rattle can will do, I'd just skip the primer.
Josh_357
Reply #579 on:
November 02, 2011, 05:30:04 AM »
Quote from: ducpainter on November 02, 2011, 05:23:35 AM
Thanks, how long should I have waited till applying the decal?
Reply #580 on:
November 02, 2011, 05:39:39 AM »
Quote from: Josh_357 on November 02, 2011, 05:30:04 AM
longer?
Your links don't work, and I can't find tech info on color on the site.
Many rattle can products require you wait a week. Technique, temps, and film thickness will vary the requirement.
TitanMonsterS4R
Reply #581 on:
November 02, 2011, 05:44:06 AM »
Quote from: ducpainter on November 02, 2011, 05:27:00 AM
Thanks DP
Reply #582 on:
November 02, 2011, 05:57:10 AM »
Try them now.
Josh_357
Reply #583 on:
November 02, 2011, 06:10:57 AM »
Quote from: howie on November 02, 2011, 05:57:10 AM
Try them now.
Thanks for cleaning up my links Howie!
Reply #584 on:
November 02, 2011, 06:53:32 AM »
Quote from: Josh_357 on November 02, 2011, 06:10:57 AM
My pleasure. Thanks for the info on that company.
38
39
40
41
67
