October 06, 2024, 10:09:33 AM
DIY Painting Tips
40
41
42
43
67
Topic: DIY Painting Tips (Read 402511 times)
Re: DIY Painting Tips
Reply #600 on:
December 09, 2011, 03:53:38 AM »
SORRY...
Missed the kit part.
http://www.por15.com/CYCLE-TANK-REPAIR-KIT/productinfo/CTRK/
I buy mine at my local Federated parts store
Mike Qube
Reply #601 on:
December 09, 2011, 06:51:53 AM »
Quote from: ducpainter on December 08, 2011, 02:41:33 PM
Here's the rub...
If you apply a stripe over the edge it may show through vinyl. It will definitely show through a painted stripe. I would clear after the color, sand, and then stripe and re-clear.
I like Kleen-Strip 'Aircraft' stripper. It may not be available in all states.
You can do the coating at any stage before paint. After stripping is probably a good call. Don't forget to braze the hinge before you coat.
I did a search for the Kleen Strip, it seems that a lot of auto body supply places have it. There's an auto body supply place not far form me, I'm going to give them a call.
One more question, when I apply the new decals, do I put them on top of the clear or under it?
Thanks for all you help on this!
Reply #602 on:
December 09, 2011, 04:21:53 PM »
Quote from: Mike Qube on December 09, 2011, 06:51:53 AM
Best way for decals.
Paint and clear.
Sand clear with 1000 and re-clear.
First coat of clear on the re-clear is a dust coat.
If you don't understand what I'm saying say so.
Be glad to explain.
Mike Qube
Reply #603 on:
December 12, 2011, 08:09:22 AM »
Quote from: ducpainter on December 09, 2011, 04:21:53 PM
Paint and clear.
Be glad to explain.
I understand everything except for "dust coat"
Reply #604 on:
December 12, 2011, 12:18:57 PM »
Quote from: Mike Qube on December 12, 2011, 08:09:22 AM
If you put a full wet coat of clear over clear sanded w/ 1000 grit it will end up on the floor.
Your first coat should be light. It will level. Let it tack up. You want to spray the subsequent coats before the previous coat gets slick to the touch and after it stops 'stringing' when you touch it and pull your finger away.
Reply #605 on:
December 12, 2011, 10:34:27 PM »
Never knew the techncal side was so precise for a painteer
TitanMonsterS4R
Reply #606 on:
December 20, 2011, 05:03:41 AM »
Anyone know if the sound changes on an exhaust once it's been ceramic coated. Thinking about sending Arrow cans in to be ceramic coated and was wondering if it will get damaged or change the sound at all.
The Mad King Pepe'
Reply #607 on:
March 06, 2012, 03:17:45 PM »
Hey DP, questions for you!
My SBK project nears completion and I need to paint the frame (all of the same color
). I've read through this thread and from my limited understanding I believe I need to:
- wash / degrease
- sand the painted parts with 400 dry / 600 wet (btw, wet as with water or some particular mix?)
- paint & clear coat
Is the above correct, or am I missing something? It's already dis-assembled...
Also, the frame was cut + welded in a few spots (swingarm mount & near the former fuel injectors now carbs), so there was some exposed metal that I sprayed with some anti rust (the spots of white paint). Should I just paint those sections or sand down to the metal and start from a base?
I will be doing the work myself with some spray cans, a bit of a heresy yes, but I'm on a budget now. I'd like to clear coat the frame in a year or two when I have the money.
TIA
Reply #608 on:
March 06, 2012, 03:24:24 PM »
Your synopsis of the process is correct. Wet refers to water.
I would use a completely different set of materials, and probably blast it and work from bare steel...
but on a budget...
Scuff it and squirt it with whatever you can afford.
You understand it won't be fuel resistant.
If you want to spend a bit more, you can get activated materials loaded into spray cans and those would be fuel resistant.
How tight is the budget?
The Mad King Pepe'
Reply #609 on:
March 06, 2012, 03:39:39 PM »
Budget's pretty tight for now, family stuff takes priority. But a couple years from now, my bling will put rappers to shame!
Sand blasting is a maybe; if I can manage it, what would be the process from bare steel?
For now, all I can afford is spray cans from advance auto, or some other place. Since I'm going for black I thought Duplicolor T090 Truck + Suv universal black followed by Krylon Flat Clear....
Quote from: ducpainter on March 06, 2012, 03:24:24 PM
Cheap toilet paper and..
Thanks!
Reply #610 on:
March 06, 2012, 04:11:56 PM »
Quote from: The Mad King Pepe' on March 06, 2012, 03:39:39 PM
Thanks!
If you blast...
epoxy primer with activated urethanes over...
good enough for nasa... good enough for me.
If all you can afford is auto zone...
don't bother blasting yet.
The Mad King Pepe'
Reply #611 on:
March 07, 2012, 01:17:00 PM »
Hey DP, what should I do with the parts of the frame that have been welded and are currently down to bare metal? I have some Rustoleum clean metal primer that I've already used on some spots, should I just use that?
Quote from: The Mad King Pepe' on March 06, 2012, 03:17:45 PM
Just realized I made a mistake there, I meant POWDER COAT the frame, not clear coat! For now I will paint and clear coat the frame, later on I will powder coat it.
Went shopping today and saw these at Advance Auto: I got the clear and the black.
Thanks!
Reply #612 on:
March 07, 2012, 07:03:10 PM »
Quote from: The Mad King Pepe' on March 07, 2012, 01:17:00 PM
Thanks!
Sure.
Just make sure you wash the frame with some grease remover and prime and paint.
Enjoying the ride
Reply #613 on:
March 11, 2012, 04:59:29 PM »
DP,
I accidentally scratched my CF seat cover with a small box I put on top and then I slid said box, the scratches look as if the clear was dulled, question is, can I use my No7 fine polishing compound to 're-smoothen' the surface?
That's what I have at hand . . . if you send me the 3M or Meguiar's or Mother's way, I'll have to purchase . . .
Reply #614 on:
March 11, 2012, 05:09:14 PM »
Quote from: Panamanian Monster on March 11, 2012, 04:59:29 PM
DP,
Are you sure it's been cleared?
No 7 isn't the best for clearcoat unless by hand.
If they're not deep scratches it might work.
40
41
42
43
67
