February 05, 2025, 04:49:40 AM *
News: Please Help
Pages: [1] 2 3   Go Down
Author Topic: Carbon Fiber Triple Clamps  (Read 6668 times)
Rever_Corsa
Custom Bikes and Parts
« on: September 14, 2009, 12:41:35 PM »
We're in the process of finishing up carbon fiber triple clamps for Ducati Superbikes, should be available by the end of October for 848/1098/1198 models. With carbon rear sets, swingarms, and frames to follow. Should be able to get them to fit Monsters as well, but only with clip-ons and some other kind of headlight bracket.
Go to our website for more info:
http://shop.revercorsa.com/catalog/product_info.php?products_id=366
Feral 859
« Reply #1 on: September 14, 2009, 12:57:47 PM »
Very nice.  Evil  Will the frames be SBK?
« Reply #2 on: September 14, 2009, 01:05:46 PM »
How does one tighten said triples onto the forks?  Nevermind.  I read the text in the link.
SBK triples aren't adaptable to Monsters BTW.
DucHead
No garage queens
« Reply #3 on: September 14, 2009, 01:12:37 PM »
Thanks, I just make the beast with two backsin' messed my pants!   Angry
 Grin  Jeebus, they're beautiful...shwing, tentpole!!   Evil   waytogo
« Reply #4 on: September 14, 2009, 01:24:44 PM »
just the tops aren't compatible right?
S2R 800 '07
« Reply #5 on: September 14, 2009, 01:36:33 PM »
I don't care  Evil I'll get one and display it in my living room  Cool
2001cromo
« Reply #6 on: September 14, 2009, 01:42:40 PM »
Neither top or bottom SBK triple are compatible with a Monster frame in their stock configuration.
Only if you take the stock front headstock from an SBK and graft it to a Monster's frame or make your own frame with similar (to a SBK) front headstock.
If you're spending that kinda coin anything is do-able... but it aint "bolt on"!
Rever_Corsa
« Reply #7 on: September 14, 2009, 02:07:05 PM »
Correct in its current configuration you would not be able to put them straight onto a Monster unless you were using a superbike front end. The triples are a multiple fit design that allow different collars to be inserted into the top and bottom to work with varying fork diameters. So we could use the same triples for either stock Showas’s on a 1098 or Ohlins, you would simply change the lower collars.
Eventually it will be possible to make a kit to adapt to Monsters.  It’s certainly something we want to do down the road.
DucHead
No garage queens
« Reply #8 on: September 14, 2009, 02:16:08 PM »
How/with what does one twist the inserts?
2001cromo
« Reply #9 on: September 14, 2009, 03:28:19 PM »
Do they have adjustable offset?
Feral 859
« Reply #10 on: September 14, 2009, 03:34:50 PM »
Will it need that for the 848/1098/1198?
needtorque
« Reply #11 on: September 14, 2009, 06:06:48 PM »
Two things.
First: Absolutely beautiful.  One of the best looking mods I have ever seen.
Second:  Is it really worth $2500?  I don't see how there could be any real performance advantage and the weight savings would be negligible.  If so then it would be a $2500 cosmetic mod?
Am I wrong?  Is there a performance gain of any kind besides making your wallet lighter and thinner?
From a workmanship standpoint I can see the cost and definitely has to be priced pretty high but what is the gain other than looks?
Who insures the FDIC?
corey
'06 Tang/Black S2R800
« Reply #12 on: September 14, 2009, 06:22:48 PM »
if i'm not mistaken... these are MACHINED (CNC) from a BLOCK of carbon fiber... not unlike the new oakley CF shades...
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #13 on: September 14, 2009, 07:16:40 PM »
+1  ...lol
« Reply #14 on: September 14, 2009, 08:24:02 PM »
just a question totally a thread jack. but does that mean a SF lower triple and forks won't fit on a Monster either?
Pages: [1] 2 3   Go Up
