February 11, 2025, 11:39:32 PM
696 maintenance at 7500
Topic: 696 maintenance at 7500 (Read 3552 times)
September 15, 2009, 04:17:31 PM »
So i'm due for my 7500 mile maintenance.
dealers are quoting me $700-900 plus incidental parts.
Ducati certified local independant (haven't checked if he can rid me of the wrench indicator) quoting $600 inclusive (unless i need belts too) and inclusive is more inclusive, including brake and clutch line bleeds (which are needed). (need front pads too, but i'm sure they'll be less expensive as well.)
So can i get some opinions on whether it's worth the extra scratch to "protect" the warranty by doing it at a dealer?
Frankly, i don't know if i trust the dealers work (every time i've had it to the shop it's come back with something new broken/missing) so i'll probably be less needy of the warranty if i take it to the indie.
Red 696- You can call her Isabella.
Langanobob
Re: 696 maintenance at 7500
September 15, 2009, 06:36:47 PM »
I'm not 100% sure how the warranty issue works with an independent shop. I think that as long as the shop does the work required by the warranty and you have the receipts, there's no problem. Ducati would have to prove that faulty independent shop work caused the warranty issue in order to disclaim it. But again, not 100% sure.
September 15, 2009, 09:31:13 PM »
the wrech indicator needs the Ducati computer. the belts are supposed to be changed at 15K
w7ck7d
The DUCtOr
September 16, 2009, 08:04:59 AM »
Shop here by my place did my 7500 service for less than $400..no problem at all.But ofcourse i always have to check the guys work i never trust em..and sure enough bolt missing at the right side holding the tank in place..so i just replaced it..
You dont need belts replacement for 7500..Only when need it.
09' 696 Black
94' BRONCO 5.8 EB
September 16, 2009, 08:43:15 AM »
Quote from: w7ck7d on September 16, 2009, 08:04:59 AM
I'm in LA, not going to find prices near that. Not planning on needing belts, it was just mentioned as a remote reason the service would end up more than the quote, didn't sound at all like he expected it. Basically, i'm looking at $650 verses $1k to get everything done (Mandatory service, brake pads, brake/clutch bleeds). $400 goes a long way, and i'm not expecting anything to come up that would need warranty repair at this time... i just don't want something found and be out of pocket more than i'm saving, nor do i want the dealer screwing me out of a warranty repair down the road because i didn't let them do this service. ( i know they're not supposed to, but i know that some would.)
September 16, 2009, 08:46:30 AM »
if he is doing more than the book then he is charging you too much. just check that.
w7ck7d
The DUCtOr
September 16, 2009, 08:58:56 AM »
Job: 7500 MILE SERVICE
Job For: 2008 DUCATI M696 MONSTER **********
Parts COMPRESSION
- MOTOR OIL 20w-50-----------$28.00 H. 170
- HIFLO HF FILTER------------- $ 10.00 V. 165
- 2 NGK PLUG------------------$ 6.00
- BRAKE FLUID-----------------$ 2.00
PARTS TOTAL--------$ 46.00
WASTE OIL FEE--------------------$ 2.00
5 HOURS JOB LABOR----------------$ 375.00
JOB TOTAL-------------------------$ 423.00
09' 696 Black
94' BRONCO 5.8 EB
September 16, 2009, 09:25:56 AM »
Quote from: Raux on September 16, 2009, 08:46:30 AM
What he's doing above the book, i need done anyway. so i'd be paying the dealer above their service quote.
Quote from: w7ck7d on September 16, 2009, 08:58:56 AM
Parts COMPRESSION
Depends on what they're charging for Labor, I'm assuming they're using synthetic oil, and if not i'm requesting it, and you're leaving out shims, if they're needed (which, i understand at 7500, they probably won't be). That said, the dealer quote i got put the labor at 575 (without the clutch/brake work), which is already right there with the indie shop's all inclusive price.
I honestly don't think it's a horrible price for LA, (but you can bet i'll learn how to do it myself and save those labor costs once the warranty is dead).
I'm starting to think maybe i should pull the plugs before hand, to get an indication if i may be facing warranty issues during the maintenance.
sroberts152
Say hello to my
September 16, 2009, 09:49:33 AM »
Where was that quote from? When I hit 7500 on my 696, my dealer said it was a 7.5 hour job and was going to run me $750 + parts. I took it to Nichols (In Milpitas, CA) and they charged me about $450. And they do great work. But they couldn't reset the wrench.
duclvr
October 01, 2009, 10:22:41 AM »
Just had my 7500 done today. Took it to the dealer where I bought it.
Parts, labor, tax out the door $547.00
JasonV
October 01, 2009, 10:31:54 AM »
Quote from: duclvr on October 01, 2009, 10:22:41 AM
Now that price I don't have a problem with.
2009 696 Monster, CF Termi's, Hindsight LS CRG's, (yes that's it, have a lot of catching up to you guys...)
October 01, 2009, 03:45:31 PM »
where?
duclvr
October 02, 2009, 03:48:00 AM »
Quote from: zedsaid on October 01, 2009, 03:45:31 PM
where?
S. Florida
