January 09, 2025, 04:00:11 PM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: What is the Italian word for 'moron'.  (Read 6748 times)
roy-nexus-6
« on: September 17, 2009, 01:48:08 AM »
I installed the Ducati Crankcase Breather Vent Filter Kit from TPO 2 days ago: I had to remove the tank to do so (I ride an S4, and Ducati made NO attempt whatsoever to neaten up the mares nest of host and wiring on the 916 engine).
Long story short - I am not sure if I have reconnected the two fuel lines correctly. They are labelled M and R respectively - which stands for two Italian words (of which I am ignorant) that would normally be printed on a sticker on the underside of the tank (no such sticker on my bike). Undecided
Any advice would be appreciated. waytogo
The two lines go into the throttle bodies.
(1)Tank underside: TWO outlets. I have installed hose R onto the outlet that is closest to the front of the bike; hose M is on the outlet closer to the back of the bike.
(2)Throttle body in profile. Hose M (labelled) enters the body closest to the front of the bike; hose R attaches to the body closest to the rear.
« Last Edit: September 17, 2009, 01:50:06 AM by roy-nexus-6 » Logged
DucHead
No garage queens
« Reply #1 on: September 17, 2009, 02:41:38 AM »
M = mendata(?) (feed) and R = ritorno (return).
I labeled mine with a sharpie before dismantling, but I'm away from my bike and I'm not much help.   Tongue
Hopefully, Speeddog will answer, as he's an expert and he has an S4.
However, if you fit quick disconnects, orient the M and R quick disconnects in different directions, and you'll never get them confused again.
weemonster
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #2 on: September 17, 2009, 02:56:15 AM »
Deficiente   is the italian for moron.
Simon
« Reply #3 on: September 17, 2009, 05:04:56 AM »
you have connected the R & M same position as mine, 03 620, should be the same with your S4.
have you tried fire it up?
roy-nexus-6
« Reply #4 on: September 17, 2009, 01:12:16 PM »
Ah, feed and return! Still not sure if they are in the right orientation, but now I have something new to google!
I would normally label everything, but I started this job just prior to a ride... and then it became a 'rush' job when I couldn't fit the breather without removing the tank Sad
Good to know it is the same as your bike! Yes, I've fired it up, it seems to run fine. Just don't want it to STOP running when I am 30mins from home.
EEL
« Reply #5 on: September 17, 2009, 02:30:24 PM »
I think it was changed to DeAngelis as of 2 weeks ago.. Grin
Vin
« Reply #6 on: September 18, 2009, 09:44:16 AM »
Asinello = donkey
Sei asinello!
2007 S2R 1K
Arrow full system + DP ECU + Mag wheels
Gus Duc
« Reply #7 on: September 18, 2009, 04:04:28 PM »
The Italian word fo " Moron" is:     LUCA cheeky
brad black
« Reply #8 on: September 19, 2009, 10:05:03 PM »
if you had the feed side going to the low pressure side of the regulator i don't think it would start, as the reg wouldn't let any fuel through.
Brad The Bike Boy
http://www.bikeboy.org
I am Sofa King
idiot sans savant.
« Reply #9 on: September 20, 2009, 03:22:23 AM »
zing!
anybody bring extra pants?
weemonster
« Reply #10 on: September 20, 2009, 05:39:34 AM »
Italian word for idiot or moron is scemo (masc.) or scema (fem.)
Pronounced shemo
My dad used to call me that quite often
 scemo just means silly its not even as bad as stupid. which is stupido.
bdfinally
« Reply #11 on: September 21, 2009, 06:22:29 PM »
Quote
"Britore" this week
« Reply #12 on: September 21, 2009, 07:41:48 PM »
I don't have my bike in front of me.
Service manual is no help on it.
Owner's Manual has a pic, not sure how clear it is.
AFAIK, all of the '02 and later steel tanks will have the same inlet/outlet configuration.
jerryz
« Reply #13 on: September 22, 2009, 04:00:44 PM »
Italian word for Moron is ......BERLUSCONI
Rever_Corsa
Custom Bikes and Parts
« Reply #14 on: September 24, 2009, 07:59:34 AM »
How about MaleDucati, I always thought it was a great club name.
Pages: [1] 2   Go Up
