April 17, 2024, 07:10:57 PM
DFWM
The Official "Ask Hiero, Because Hiero Knows Everything" Thread
Topic: The Official "Ask Hiero, Because Hiero Knows Everything" Thread (Read 6071 times)
Duc L'Smart
May 23, 2008, 02:29:00 PM »
So, if one were so inclined, and felt enough inner fortitudeness, to undertake a 6k service on an air cooled twin, say, oh, I don't know.... a Monster or a Sport Classic, what should be performed, and what exotic precision instruments are necessary?
One would assume, it goes without saying, that it would involve an oil change, clutch fluid change, brake fluid change, check brake pads, look for things that are loose but should not be loose...
What else?
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS,
'73 BMW R75/5
'67 Ducati Monza 250 Bevel Drive
'63 Vespa GS 160
never2loud
Re: The Official "Ask Hiero, Because Hiero Knows Everything" Thread
May 23, 2008, 02:56:55 PM »
Tires
(Sorry, couldn't resist... wonder what's the female equivalent of "Svoloch"?)
dallas2r
May 23, 2008, 03:13:37 PM »
Quote from: n2f on May 23, 2008, 02:56:55 PM
Tires
you mean Svoloch isn't a chick?
OH GOD!!!
2007 Monster S2R1000
2016 Multistrada 1200S Touring/Urban
A motorcycle will get you through times of no money better than money will get you through times of no motorcycle. -Unknown
cdc
my superbike. nutts someone copied my avatar.
May 23, 2008, 03:19:54 PM »
Quote from: dallas2r on May 23, 2008, 03:13:37 PM
OH GOD!!!
Is this the same as a James' "OH GOD"?
cdc
WonderBoy
May 23, 2008, 03:27:37 PM »
That would be like a quagmire from family guy "oh god."
What i wanna know from Hiero is the answer to life, the universe, and everything.
High above the muckey muck...
calscrazy
May 23, 2008, 04:31:42 PM »
does one still have his owner's manual to read?
home will always be between the red and rio!!!
2007 m695 errr recently passed away
factorPlayer
May 23, 2008, 04:42:01 PM »
methinks it be time for another 6k maintenance clinic
Gone Ape
Boom-Shaka-Laka.....So much for my Titanium Member
May 23, 2008, 05:14:25 PM »
I'll bite......Realizing this is totally tongue in cheek:
micrometer 0-25mm
dial caliper 0-150mm
beer, for the loose ones you have to buy
knife sharpening stone for tight shims
manometer or mercury carb sticks for TB balancing
the old board (for a cool excel program for shim calcs)
patience
patience
oh yeah, patience
And a sense of humor ...clearly something lost od me...
Always one to be underestimated
hiero
May 23, 2008, 06:29:52 PM »
letsee, on top of what you got, valve clearance adjustment etc,
you'll want to readjust your belts (although valve clearance adjustment is easier with the belts off anyways)
reset your TPS
balance TBs
check chain tension
if you like, you can check your throttle cables and your steering head bearings
special tools:
use an impact driver to get those pesky crank cover bolts off, don't try to do it by hand, you'll strip em
engine turning tool (you can make one on the cheap if you don't want to buy a real one)
shims and shim measurement tool
I use only a set of calipers to measure my shims, but whatever you choose to use
angled feeler gauges (angled makes it easier)
something to hold the top of the valve in place so it doesn't fall in
magnetic pick up tool makes pulling half rings out easier
something to depress the rockers (I just bought the purpose made tool made by EMS, but used to just use a screwdriver being careful)
some kind of sync tool (I use a digital vacuum gauge now)
fluke for the TPS reset (depends on model of bike though as some TPS can be set manually, some have to be done using software)
maybe an extra 5mm screw to block the oil galley hole when you're pulling your half rings so they don't fall in there
other answers: 42
2000 Monster 750
1999 748
YELLOW!!
MurDuc
2003 M1000S
May 23, 2008, 09:11:33 PM »
hiero,
I am so going to bribe you to come "hang out at the lake" for a couple days.
Just as soon as my tools aren't hogging up the guest bedroom.
I wish I was joking...
Master of Suds / LSD - Department of Hooliganism
♣ McKraut ♣
touched by his noodly appendage
May 23, 2008, 09:54:16 PM »
Quote from: DucatiFan on May 23, 2008, 05:14:25 PM
manometer
what exactly does this measure? because i have a rule that i think takes the same measurement.... does your "manometer" go up to 10 inches also??
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
Duc L'Smart
May 24, 2008, 01:00:24 AM »
Quote from: McKraut on May 23, 2008, 09:54:16 PM
The "Wishful Thinking" thread is over in the No Monster Content forum
'73 BMW R75/5
'63 Vespa GS 160
Duc L'Smart
May 24, 2008, 01:10:02 AM »
Okay, I found this, although it's from waaaay back in '05
'73 BMW R75/5
'63 Vespa GS 160
Duc L'Smart
May 24, 2008, 01:11:01 AM »
Does this still work?
Reset the MAINT light:
Hold down the left button. Turn the bike on. Release the button.
'73 BMW R75/5
'63 Vespa GS 160
Duc L'Smart
Reply #14 on:
May 24, 2008, 01:15:52 AM »
More Techie Goodness on TOB
http://www.ducatimonster.org/forums/forumdisplay.php?f=166
'73 BMW R75/5
'63 Vespa GS 160
