February 10, 2025, 06:13:32 AM *
Pages: 1 [2] 3 4   Go Down
Author Topic: O Bling is O so good, but is this to Anal ????????????????????????  (Read 8659 times)
FIFO
Doing the latter
« Reply #15 on: October 10, 2009, 02:26:53 PM »
That rear sprocket would look great on my bike. Wink
Who made it? Where can I get one?
The nice shiny bolts on the front end are great. Mine are a bit rusty, maybe I should replace them too Grin
Hey YM i got the sproket from monster parts check with spider he
might have some info on that as well. Smiley
http://www.monsterparts.com/
FIFO
Doing the latter
« Reply #16 on: October 10, 2009, 02:39:02 PM »
Rob....nice work mate!
now.....can you get some grey cable ties please.....and maybe black plastic belt covers?Huh? waytogo
Hey Spider the cable ties are coming i want to find some that are good quality like OEM or better i hate cheap ties.
And the belt covers  black plastic or painted cf.
got any.
 Might even go open covers, Speedmoto look good  Grin
http://www.monsterparts.com/pc/11-0210/Accessories/11-0210.html
Jukie
I need a
Paradise
« Reply #17 on: October 10, 2009, 02:40:59 PM »
hhhmm nice Rob open cover, but i like to keep it closed in.
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
FIFO
Doing the latter
« Reply #18 on: October 10, 2009, 03:28:45 PM »
when your finshed with your bike you can work on my bike anytime Rob  Wink
Hey Jukie.
Unfortunately as you now our bikes are never finished Tongue
But i might be able to fit yours in some were.
You can get 24 carat gold plating  kit's as well not that expensive
http://www.janekits.com.au/mainframe.php
 some selected parts  on your bike ,real gold plated  would look good on your bike. waytogo
I was nearly going to use gold on mine.
 I know what your saying for the belt covers open look good but not very practical For a daily ride bike.
PS
 If you or any one get a plating kit  i will be very happy to help any one get started or have a look at my set up if your in Sydney area or surrounds Smiley
« Last Edit: October 10, 2009, 03:36:11 PM by Rob s » Logged
FIFO
Doing the latter
« Reply #19 on: October 10, 2009, 03:48:04 PM »
In my mind there's no connection with your/anyone's poop chute....
G'Day Mate !!
Here in Australia Anal is used to describe someone with A obsessive compulsive disorder such as being very very clean or neat ,putting things in there correct place or something like that, others may be able to elaborate on this bang head bang head laughingdp
S2R 800 '07
« Reply #20 on: October 10, 2009, 03:52:15 PM »
G'Day Mate !!
I knew that  waytogo I just don't think plating bolts is too much of it  Grin
bazz20
« Reply #21 on: October 10, 2009, 07:30:51 PM »
 rob what do you get in a jane kit cheers bazz
FIFO
Doing the latter
« Reply #22 on: October 10, 2009, 07:58:48 PM »
KIT CONTENTS
Hi Bazz
They give you instrution booklet but a little vague read it about 20 time you'll be right and you can call him which i have done
They supply the electrolyte in powder form for a 4 litre kit.
 i just went to Cole's and bought 4 litre bottles of distilled water to mix it up and a few 3/4 liter containers with vacuum sealing lids.
And you need some heat source the chip fryers are the best i had an old one.
It's all on the web site http://www.janekits.com.au/mainframe.php
Just get the nickel kit.
If your in Sydney area your welcome to look at my set up and help you get started.
Tip polished the bolts or anything round in my pistol drill  just put em in the chuck spin them up and polish the surface with emery cloth and Brillo pads before plating.
and after plating samething but use a soft cloth and metal polish, autosole or similar
I copied this from there site.
The kits contain the chemical in crystal form to mix to make the required electrolyte. The brighteners are also supplied for each chemical. Anodes are supplied for each type of plating, be it nickel, zinc, or copper. A thermometer is supplied in the nickel kit, or dual kits. Pipes are supplied which are used as hanging bars for the jobs. Nickel wire is supplied to hang anodes on, and copper wire for hanging plating work on.
A bench top transformer is included to supply current at 1.5 AMPS, with adjustable voltage. Larger power supplies are available if required. A bridge wire is included to bridge copper pipes together if required. A book is included in the kits complete with instructions and tips. I am always available for back up help if required.
Rob waytogo
« Last Edit: October 10, 2009, 08:09:44 PM by Rob s » Logged
bazz20
« Reply #23 on: October 10, 2009, 10:35:48 PM »
what do you use to take of the old plating , thanks for all that  can you just buy the nickel oxide and and nickel anodes  cheers bazz got every thing else
FIFO
Doing the latter
« Reply #24 on: October 10, 2009, 11:13:04 PM »
Hydrocloric acid removes the old plate, plus a 12v battery speeds it up.
But the how to manual is what you really need
Makes it easy a lot to learn even though it is simple it's all the little tricks.
You will need the anodes and electrolyte
the power supply needs to be around 12v/ 6volts variable  for small stuff .they are available from jaycar will get the part no later for you.But no cheaper than jankits
 kenco degreaser for the parts before plating works they must be spotless or it goes patchy.even finger marks will stuff you up.
AS IS SAID ITS ALL THE TRICKS
But for $160 for the nickle kit not worth stuffing around.
Serious Groper
« Reply #25 on: October 11, 2009, 11:59:27 AM »
Looks nice and clean  waytogo
My bike gets to dirty for me to bother about any of that stuff.
I'm happy to enjoy and appreciate the work others do with me sitting on my butt  [moto]
Dannog
S4RS
« Reply #26 on: October 11, 2009, 08:34:05 PM »
Hey Jukie.
...You can get 24 carat gold plating  kit's as well not that expensive
Jukie, if you Gold plate the bolts on your baby everyone will confuse it for a 'pimp my wheels special'!
Jukie
I need a
Paradise
« Reply #27 on: October 11, 2009, 09:19:10 PM »
pimp me pimp me
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
monsta
Perth, Australia.
« Reply #28 on: October 12, 2009, 01:01:20 PM »
nah, not to anal..  the devils in the detail!   waytogo
I went with stainless on most of my bike, but not only did I polish the bolts I rounded the heads and got rid of any knurling.
I do it with the pistol drill at home, I have a buff for my bench grinder as well..  that was a good investment...
 but if I have heaps to do I'll do it at work on the lathe. The rounded heads seem to catch the light better...
« Last Edit: October 12, 2009, 01:04:04 PM by monsta » Logged
Dannog
S4RS
« Reply #29 on: October 12, 2009, 06:54:22 PM »
Monsta, how do you hold the bolts securely while grinding and buffing them?
Pages: 1 [2] 3 4   Go Up
