O Bling is O so good, but is this to Anal ????????????????????????
Started by FIFO, October 09, 2009, 10:39:01 PM
Two dogs
Can we have the equivalent of a fondue party at Rob's nickel plating garage?
[/quote] [laugh] [laugh] [laugh]
Is that safe? what about protection?
cduarte
FIFO
Quote from: cduarte on November 20, 2009, 06:44:31 AM
very nice, but your front axle is not aligned properly...
Yer i know i was waiting for some one to pick that up.
It was like it when i bought it.
Got a do some more plating on the fron axle spacers and replace the front forks seals so it will be sorted out soon .;D
monsta
bazz20
about bloody time some one has put that to bed ive found the same in hydraulics on boats the high tensil bolts snap but the old soft stainless doesnt and in the marine environment you have too just use stainless on all fitting including prop shafts engine mounts ect by the way any one puting stainless bolts into aluminum dont use the copper or nickel anti seize it will create electrolysis just use a bit grease or better if you can get lancoate cheers bazz
FIFO
Thanks Monsta
I'm with Chris Kelly on this as well. i have been in the engineering game for a long time and used S/S with no drama's, In all different applications. [thumbsup]
And as stated screwing S/S into aluminium go figure  [roll]
Propeller-heads [laugh] [laugh] [laugh]
Bazzo
now the debate is on anti seize copper versus grease [laugh] [laugh]
bazz20
