February 09, 2025, 04:07:15 PM *
Author Topic: For those with a Wet Clutch Monster  (Read 1104 times)
CairnsDuc
« on: October 22, 2009, 05:30:07 PM »
G'day all
I just wanted to post a link to my new Tutorial on how to check the Clutch nut that can work loose in the Wet clutch model Monsters.
http://ducatimonsterforum.org/index.php?topic=31110.0
If you read this Topic here (about 5 pages)
http://ducatimonsterforum.org/index.php?topic=24411.0
you will notice that if this Nut loosens, the results are horrendous to both the the Engine and your bank Balance!
I am letting everyone know about this as I would like people to contribute to the Tutorial Topic, if you know of a better way, easier method, then throw it in the Tutorial topic, the more we know, the safer we all are!
Thanks!  waytogo
bazz20
« Reply #1 on: October 23, 2009, 03:25:21 AM »
the only thing i can see that ill would do different is use loctite primer if you want the loctite too bond and grip other wise theres  no point puting loctite on   waytogo
dragonworld.
I can make like a tripod with my.....
« Reply #2 on: October 23, 2009, 09:31:33 AM »
Yep, yep!!  waytogo  A must!!  waytogo
CairnsDuc
« Reply #3 on: October 23, 2009, 01:09:15 PM »
No worries, Thanks for the info, I will add it to the Tutorial, I intend to inspect this nut every 12000k's (as part of the service)
Now I know how to do it I will rip the side cover off while the oil is out and check the tension.
next time I'll add some Loctite primer to the job  waytogo
