February 05, 2025, 07:51:14 AM *
Pages: 1 [2] 3   Go Down
Author Topic: Lowering reservoirs/replacing them?  (Read 7114 times)
loves ze desmodromics.
« Reply #15 on: November 07, 2009, 06:06:43 PM »
I'm not really sure what I think about reservoirs THAT low. (not the 999 style coffins).
You have to have it so there's no air bubble chance - the low point is the master, the high point being the top of the reservoir surface.
djrashonal
« Reply #16 on: November 07, 2009, 06:22:30 PM »
Wow Mash, I really like those! A lot better than those big ole mason jars i've got! are they only compatible with 999 MC's? I've got gsxr MCs....
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
djrashonal
« Reply #17 on: November 07, 2009, 06:23:09 PM »
i hear what you're sayin!
01 SSSSSSS4 - Sold
« Reply #18 on: November 07, 2009, 06:29:19 PM »
The 999 reservoirs are fine because the reservoir is mounted smack on top of the master, no height issues at all.
djrashonal
« Reply #19 on: November 07, 2009, 06:44:05 PM »
sweet, so if i procure a set of 999 reservoirs i can just plunk them down on my Nism MC's, correct? While I'm at it, would there be a benefit to replacing the tubing with clear? Anyone know if the reservoirs can be painted? sorry for all the questions, I'm just a noob when it comes to italian fluids
01 SSSSSSS4 - Sold
Feral 859
« Reply #20 on: November 07, 2009, 06:54:50 PM »
djrashonal
« Reply #21 on: November 07, 2009, 06:56:32 PM »
That is soooo hot! Yours? I love those forks too! Any issue with air bubbles with those reservoirs being so low?
01 SSSSSSS4 - Sold
Feral 859
« Reply #22 on: November 07, 2009, 06:59:13 PM »
No issues.
« Reply #23 on: November 07, 2009, 08:24:41 PM »
his meet the height I was talking about before. If you mount them "below" the master, that's where you'd have problems.
kopfjager is running the same master cylinder / reservoir set up that I am, but with a different mount location.
I don't think the 999 reservoirs will mount to anything but 999 masters.
Monstermash
AKA-TomColore
Interferiscalo se potete
« Reply #24 on: November 11, 2009, 09:21:21 AM »
 Thats is correct. Well almost correct. They could be made to fit any of the radial masters that come on the Ducatis. But why bother as the 999 masters are listed for sale on Ebay a lot and are not very expensive.
djrashonal
« Reply #25 on: November 11, 2009, 11:40:10 AM »
Alright, So I'm looking into swaping out to 999 MC's. I saw some on ebay for about 200, is that what I'm looking at spending per side?
http://cgi.ebay.com/ebaymotors/Ducati-749-999-Radial-Front-Brake-Master-Cylinder-Res_W0QQitemZ280383741523QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item41482c5e53
are they normally cheaper or more expensive?
would that include what I need to make the swap?
If I'm gonna do the swap, should I also change out the rear?
TIA for the Help
01 SSSSSSS4 - Sold
Ducatl
« Reply #26 on: November 11, 2009, 12:24:02 PM »
Seems about right, They aren't all that cheap...Although cheaper than buying new stuff.  ISR and Beringer both make radials with integrated masters that are really nice but pricey.
If you decide on smaller reservoirs you can buy 15cc brembo stockers for pretty much nothing, this is the same size as the rear brake.  For clear tubing you want to use tygon, in my experience clear tubing is fun and pretty but it seems to collapse easier if you're trying to give it a tightish radius...totally usable but just something to think about.
djrashonal
« Reply #27 on: November 11, 2009, 12:47:52 PM »
Wow! Great advice/FHE! I Think im gonna go with the 15cc cup first. Any good place to find it, or should I just check ebay? any particular one to look for? I saw people selling them from thialand but i was kinda skeptical of it (5 reservoirs for 40 bux)
http://www.desmoworks.com/index.php?main_page=product_info&manufacturers_id=5&products_id=38
http://www.yoyodyneti.com/ProductInfo.aspx?productid=10.4446.50
any pro/con to getting the 45 vs the straight fitting?
« Last Edit: November 11, 2009, 12:50:44 PM by djrashonal » Logged
01 SSSSSSS4 - Sold
Ducatl
« Reply #28 on: November 11, 2009, 01:24:16 PM »
Depends on the orientation of the inlet on your master/distance/height/angle etc.
djrashonal
« Reply #29 on: November 11, 2009, 02:16:27 PM »
this is my current set up: http://gallery.me.com/afakhori#100252
there is a nipple at the top, not sure if i can pull that out and install the straight reservoir...thoughts?
01 SSSSSSS4 - Sold
Pages: 1 [2] 3   Go Up
