Lowering reservoirs/replacing them?
Started by djrashonal, November 06, 2009, 10:59:11 PM
djrashonal
So my brake reservoir sits super high up and if I lower it, I dont think it will function correctly. I have big round ones and with my clip-ons and head light, it looks weird. Any solutions? smaller ones? coffins? thoughts?
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
ducducgooseme
Rizoma makes some new hanger brackets for theirs....looks pretty killer I think  [thumbsup]
probably high-sided.
DucHead
There are a couple of threads on this topic.   :)
djrashonal
Quote from: pompetta on November 07, 2009, 06:37:17 AM
i searched but didnt find one....direct link? i may not be good with this interweb yet  [bang]
01 SSSSSSS4 - Sold
DucHead
djrashonal
Sweet, thanks! anybody try using smaller reservoirs?
01 SSSSSSS4 - Sold
I use two rizoma reservoirs that are the same size (medium) so it is symmetrical. If you google "Bimota Single Reservoir" you'll an example using a t-junction to come from one larger reservoir to work both your hydraulic masters. Kind of a neat alternative.
djrashonal
that sounds pretty interesting, i just saw it online.....do you think the reservoir gets in the way of the gauges at all?
01 SSSSSSS4 - Sold
It doesn't have to be mounted in front of your gauges at all, just put it on one side and run the house down in front of gauges by the bolts. IF you wanted to do it.
djrashonal
i think it would be cool, but i like the symmetry of one on each side.
presently the reservoir on the clutch side is waaay smaller than the brake side (rear brake reservoir I believe ??) is there a was I can just get a smaller version of that? would there be any foreseeable drawbacks to making that smaller?
01 SSSSSSS4 - Sold
I made the brake size the same as the clutch size (both the midsize, bottom outflow rizoma reservoirs). No issus. you don't want to go too small if you have dual front calipers.
djrashonal
I was thinkin the midsized ones. overall, I want them to be tucked down like in this pic
i believe this is Chris' bike from Desmoworld....the question is, how
01 SSSSSSS4 - Sold
MOUSEMAN
I think the guys at Indy Ducati are making the ones you are looking for. I saw the prototype and they are sweet. Low, tucked in, and tight!
1992 851   2009 M696
djrashonal
awesome! got any contact info? or should i just call the parts department on monday?
01 SSSSSSS4 - Sold
Monstermash
I kinda like the reservoirs that come on the 999 master cylinders. I had these on my Y2K M900 as well as my 996.
