February 05, 2025, 07:50:11 AM *
News: Please Help
Pages: 1 2 [3]   Go Down
Author Topic: Lowering reservoirs/replacing them?  (Read 7113 times)
loves ze desmodromics.
« Reply #30 on: November 11, 2009, 03:12:07 PM »
you gots nice forks
Ducatl
« Reply #31 on: November 11, 2009, 04:34:50 PM »
Full gsxr swap?
You can disassemble the nipple on Nissin masters.  Carefully pull the rubber plug around the nipple back and remove the snap ring inside, you should now be able to swivel the nipple in any direction you want.
If you want to really lower the res. then you're probably gonna need to fab up a new mount.
From the looks of it I'd suggest a 45,  I have a 90 mounted like this
It too quite a bit of fiddling to get it into a position where the Tygon didn't want to collapse, a 45 would have eased the transition a bit.
« Last Edit: November 11, 2009, 04:40:31 PM by Ducatl » Logged
djrashonal
« Reply #32 on: November 11, 2009, 05:34:39 PM »
you gots nice forks
thnks much  waytogo
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
djrashonal
« Reply #33 on: November 11, 2009, 05:36:33 PM »
Full gsxr swap?
Nice set up! I'll order the 45 and keep you guys posted of the mounting
01 SSSSSSS4 - Sold
Juan
« Reply #34 on: November 11, 2009, 06:29:44 PM »
I have the regular cc for the Monster, all I did with my set was to place the brackets on the same place as the directionals.
ProTeal55
HalfFastChicago.Com
« Reply #35 on: November 12, 2009, 03:20:45 PM »
Looks good..
This is def. something I need to do to my scoot before next riding season..
Member: Half Fast Chicago
Website:
748s
« Reply #36 on: November 14, 2009, 09:59:02 PM »
Another forum..........stock reservoirs tucked out of the way.......down near headlight.
http://www.ducati.ms/forums/showthread.php?p=636896#post636896
warning........site of the interweb overlords.
« Last Edit: November 14, 2009, 10:03:03 PM by 748s » Logged
Jarvicious
The guy in my avatar wants your
Balls
« Reply #37 on: November 19, 2009, 11:17:58 AM »
Correct me if I'm wrong, but isn't that bike on the .ms forum asking for trouble with his reserviors that low?  I'd think it would be air bubble city unless the thing was full to the brim, and then what's the point of the reservioirs anyway?
djrashonal
« Reply #38 on: November 19, 2009, 11:19:51 AM »
i agree, it looks troublesome, especially because if it's full to the brim there would be nowhere for the excess fluid to go. Looks pretty bad ass though
01 SSSSSSS4 - Sold
« Reply #39 on: November 19, 2009, 12:01:41 PM »
Horrible idea. Sure you could make sure its bubble free by undoing the reservoir, moving it above the master, massaging the tube to free any air bubbles, fill, and then replace, but then you've just got to keep hoping that gravity doesn't pull the fluid down enough to create enough of a vaccuum to pull the air in, wherein you'd introduce air into the system. No good. One big bump and the fluid runs out of the line into the reservoir, replaced by air.
Pages: 1 2 [3]   Go Up
