Installing Battery Tender Connector on M696 vid
Started by peanut_man, November 08, 2009, 04:31:07 AM
peanut_man
So it is that time of year when we start to think about winter storage of the toys.  I decided to install the Battery Tender connector on my M696 this weekend, so might as well make a video of it.  Now I know there are plenty of people with way more mechanical capabilities than me, so this is probably very basic.  But the last video that I made changing the 696 oil / filter got many good responses that I think this one will also help a few people out.
Ducati sells their own charger also, but I believe it's close to $200.  So basically I replaced the OEM charging connector with the BT one so I can use the battery tender during winter storage.
Enjoy:
Ducati Monster 696 Battery Tender Connector Installation
2005 Buell XB12S | 2006 Honda CBR 600RR | 2005 Ducati Multistrada 1000DS | 2009 Ducati Monster 696+
roggie
Nice video!
this will be bookmarked next to your oil change video!!
thanks
[beer]
DucHead
You might want to move this to the "Tutorials" forum.
Kurt V
Nice video, but the manual makes this much more difficult than it has to be. I just added a battery tender extension this weekend. You can save a lot of hassle by just disconnecting the two hoses up by the filler hole. They pull right off. No need to mess with the carbon breather cover down low. Also I found no need to disconnect the electrical connectors. If you just remove the plastic covers and bolts holding the tank on you can shift the tank over enough to the right to access the battery.
yoreese
Very nice video!  But Ducati really made access to the battery a pain vs the older Monsters.  I could have removed the battery and drank a 6 pak of Bud before he had the tank cover off!  [drink]
1999 M750 Dark
2002 ST4S
bluemoco
Quote from: yoreese on November 09, 2009, 01:54:49 PM
No kidding!  Access is not easy on the 696's.  I installed a Battery Tender connection on my '04 Monster in about 5 minutes.
"I'm the guy who does his job. You must be the other guy." - Donnie Wahlberg in "The Departed"
"America is all about speed.  Hot, nasty, badass speed." --Eleanor Roosevelt, 1936
TWDucfan
Excellent video!  [bow_down]
I was trying to charge my battery but couldn't prop the tank up until I watch the video that there is a #5 hex screw underneath the tail section of the plastic fuel tank. After removed that screw it was easy.
However, I did noticed that my brand new Monster 696 is missing one 8mm bolt on the left side that holds the tank to the frame.  ??? Guess the QC at the factory still needs improvement...  [roll]
sbrguy
geez i am thinking about getting a new generation bike but damn changin the battery is a major hassle or just putting in a battery tender..
sure this isn't something i do everyday but its nice to know that its easy and not taking apart the entire bike like the newer bikes... wow that is some work there.
battlecry
It's like a BMW.  They suspend a battery in space and then build a bike all around it.
Volvo did it with the A/C evaporator.   [bang]
w7ck7d
Maybe a newbie question...But why do you have to put fuse?
09' 696 Black
94' BRONCO 5.8 EB
Quote from: TWDucfan on March 29, 2010, 09:58:32 PM
the left hand front mount for the tank shouldn't have a screw. i'm pretty certain it's to allow some tank flex so it doesn't crack and leak.
TWDucfan
The molded plastic tank has 2 metal pins about 1-1/2" long fastened to the bottom on both sides. These 2 metal pins slide into the mounting points with rubber groumets inside on top of frame rails. These 2 rubber groumets should allow some flex in mounting the tank, correct? I will check with dealer when bringing the M696 for service.
w7ck7d
09' 696 Black
94' BRONCO 5.8 EB
seriously.
only bolt the tank  on the one side. the other one is a slide mount.
even the rubber is different in them for that reason.
i've heard dealers putting the second bolt on.. i think that's a bad move.
danaid
Quote from: Raux on March 31, 2010, 07:57:21 AM
seriously.
My 696 also had only one tank bolt, hum, I guess that is how the tank is installed.
I thought the dealer left a bolt out when they installed my exhaust, I called them up and gave them a hard time about doing sloppy work.  :-[
11' 1198SP  Black
09' 1100S    Red
