LED License plate light choices
Started by djrashonal, November 17, 2009, 07:35:55 PM
djrashonal
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
RUFKM
I have the black radiantz frame and I like it.  My stock duc one didn't hold the bulb well enough to keep it lit so I switched to the LED.
Kopfjäger
If you want to stick with a red lens, get one for a Buell. It has a clear bottom and puts out enough light for
your tag.
djrashonal
Quote from: kopfjäger on November 17, 2009, 07:55:49 PM
your tag.
for the tail chop i went with the motodynamics smoked lens, for 75 bucks, i'm happy with it, and it was a super easy install! [thumbsup]
01 SSSSSSS4 - Sold
djrashonal
Quote from: RUFKM on November 17, 2009, 07:51:18 PM
Did you cut off the stock license plate light and wire the frame up to that? or did you splice it in?
01 SSSSSSS4 - Sold
Kopfjäger
Quote from: djrashonal on November 17, 2009, 08:03:15 PM
Doesn't that one have a clear bottom as well?
djrashonal
No, the motodynamic light doesn't have a clear bottom, it also uses red/yellow LEDs, so I dont think it could be used as a License plate light
01 SSSSSSS4 - Sold
Kopfjäger
^^ Will the clearalternatives lens fit? It has a clear bottom.
djrashonal
Yea, i think they're all interchangeable.  You got a lead on a nice, cheap CA taillight?  [beer]
01 SSSSSSS4 - Sold
Kopfjäger
RUFKM
Quote from: djrashonal on November 17, 2009, 08:03:56 PM
I coupled it into the spade connectors for the taillight.
djrashonal
Quote from: RUFKM on November 17, 2009, 08:52:24 PM
sweet! any pics of the install?
01 SSSSSSS4 - Sold
i used an ebay LED pod from this guy named joe florida. he has a life time warranty and if you email him if it ever fails, you get a new one. $4 bucks. any color you want, though in many states you need white
djrashonal
Quote from: He Man on November 18, 2009, 04:12:32 AM
thanks He-man! I searched ebay, found the ones you were talkin about bought'em for 3.25....now im just waiting for delivery. did you splice yours into your wire for the tailight or the license plate light? did you get the 3 led pod or the 4? I picked up :
http://cgi.ebay.com/ebaymotors/4-LED-Cluster-POD-Motorcycle-Accent-Lighting_W0QQitemZ400074614195QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item5d264e25b3
was also looking at this:
http://cgi.ebay.com/ebaymotors/3-LEDs-In-Line-POD-For-Accent-Lighting_W0QQitemZ400074618320QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item5d264e35d0
01 SSSSSSS4 - Sold
i had both. i orignally bought a green one, but he sent an aqua one and maintained that it was green. but i kept it. it was secured right so it fell off the mount and my tire bounced it to death. and i threw it away. Then i bought the 4 pod white led (white is req by law here) and its been fine, especially since it was only $3.25 ( the bar one was more expensive for some reason).
I hooked it up to the license plate lamp wire. i cut the original ends off and soldered the pod directly onto them and then threw a heat shrink over it.
