February 10, 2025, 10:50:54 AM
Please Help
Pre-project checklist and fact find
Topic: Pre-project checklist and fact find (Read 1782 times)
fouramdesigns
November 20, 2009, 06:45:17 AM »
I'm considering a custom build of my current S4. Wanted to get some feedback of do's, don'ts and waste of time and money. Really want a Super Duke R, but $16K is out of reach for now.
So far this is the project list:
Frame repainted (sourced)
wheels repowder coated (sourced)
Forks replaced Ohlins, or new carts/paint (sources mod suggestions?)
engine painted
New speedo/tach (the Moto...from Germany, link anyone) also can the guts of the speedo be boxed and moved?
916 engine mods, see sig of current, what else is possible/worthwhile?
2001 Monster S4, Termignoni/ECU, DP short air box w/BMC filter, Rizoma Zero's front/back, Cookie tail chop, Rizoma belt covers, Evoluzione slave, CF all over
Re: Pre-project checklist and fact find
November 20, 2009, 06:52:24 AM »
Gauges:
www.motogadget.com
The guts of the speedo can be repackaged and moved.
I'd recommend regular paint for the wheels rather than powdercoat.
Engine mods, how much do you want to spend?
fouramdesigns
November 20, 2009, 07:14:51 AM »
Quote from: Speeddog on November 20, 2009, 06:52:24 AM
Gauges:
www.motogadget.com
thanks for the quick reply. Heard that paint would be better. Engine mods, maybe $2K
November 20, 2009, 07:24:57 AM »
Some folks have fitted SPS cams, and seem to like 'em.
Most of the power gain is way up top, so you need to ask yourself if that's what you want.
You could fit an S4R or ST4s motor.
With those, you get the wide-ratio transmission, which is a very good upgrade all in itself, IMO.
fouramdesigns
November 20, 2009, 07:51:18 AM »
Quote from: Speeddog on November 20, 2009, 07:24:57 AM
Whats the average cost on each, any links?
Also, is this the kit needed to change to a bar?
http://www.spieglerusa.com/cfm/sbk.cfm
Last Edit: November 20, 2009, 08:48:22 AM by fouramdesigns
November 20, 2009, 09:36:55 AM »
Dunno cost of SPS cams, they're getting rare.
I've seen S4R and ST4s motors go for ~$1500 or so.
For bars, easiest to get the upper triple from either:
'02 and later regular Monsters, 7/8" bars.
S*R for 1 1/8" bars.
I think there's aftermarket upper triples as well, more money tho.
fouramdesigns
November 20, 2009, 09:56:17 AM »
the vision in my head, is sick. All Black w/ orange wheels, orange Duc logo, kinda a cafe/meets modern/ mad max
MonsterMan1036
November 20, 2009, 11:21:43 AM »
The SPS cams should range between $900-2000, depending if they are new or used. I picked up a new set for $1200 not too long ago.
Last Edit: November 20, 2009, 11:23:35 AM by MonsterMan1036
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
fouramdesigns
November 20, 2009, 11:48:31 AM »
Quote from: MonsterMan1036 on November 20, 2009, 11:21:43 AM
change the sound much? Engine swap sounds more likely
November 20, 2009, 01:37:00 PM »
Definitely gets a more snarly with the SPS cams, idle gets a little lumpy.
TAftonomos
is without a monster :(
November 20, 2009, 02:08:27 PM »
Want lumpy idle without spending $1200 on a used set of cams that won't net you much?
Install the corse exhaust springs, or just leave the springs out altogether. Lumpy lumpy lumpy, and $1200 more into your pocket.
Also, skip the remove the guts idea and just get the immobilizer removed from the ECU. Get a spare plug for the gauges (or use a different one), and start shopping at motogadget
Maybe motocreations will have the "switchlets" out by then ?
MyDucParts.com
djrashonal
November 20, 2009, 07:16:50 PM »
Quote from: Speeddog on November 20, 2009, 01:37:00 PM
I've got the SPS cams in my 01 S4 and it bucks and kicks at low idle, but pushes hard when opened up! Not worth the price when you can bolt in an S4RS engine for 1500ish
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
loves ze desmodromics.
November 21, 2009, 06:46:38 AM »
Look at the cartridge fork kits rather than Ohlins forks.
There's the 25mm ohlins and racetech and the 20mm traxxion, and a 20mm gas charged traxxion. you can get 'em anodized gold if you want so it still looks blingy.
TAftonomos
November 21, 2009, 12:06:16 PM »
Quote from: djrashonal on November 20, 2009, 07:16:50 PM
THAT is an excellent point. And also why I'm thinking about dropping this 104mm (999r) motor in my s4r/testa...and then stuffing the testa motor into that st4 I bought...LOL muahaha. OK, I stop now.
MyDucParts.com
brad black
Reply #14 on:
November 21, 2009, 09:13:56 PM »
sps cams shouldn't make any difference to idle quality or low speed running. but if a 996 motor is available at those prices then there's no point doing anything to the 916 motor. you'll need a full system or st4/4s header and muffler set up to get the top end power it offers tho.
Brad The Bike Boy
http://www.bikeboy.org
