February 05, 2025, 11:13:25 AM *
Pages: [1] 2 3   Go Down
Author Topic: Radial Master Cylinder - or the art of braking  (Read 10222 times)
pjfa
M696 pjfa Edition & 900SL III #643
« on: November 27, 2009, 05:24:22 AM »
Hi,
I just start this thread because I´ve done some search in the forum but didn´t find what I´m loking for  Grin
So, I want a Radial Master Cylinder and after some time spend in the internet, I found these:
"Classic" Brembo´s
19X18
German "High-Tech" Magura
Radial 190 (option cyclinder diameter: 13, 16 and 20)
Swedish "Ultra-tech" ISR
21-014
21-012
Why I want it?
First for improve the brake feeling
Second for Design (form & function)
Where I apply it?
M696 pjfa Edition
Where I use it?
Everywhere but circuit  coffee
If anyone want to give some options/feedback, I´ll be glad to know  waytogo
« Last Edit: November 27, 2009, 05:48:35 AM by pjfa » Logged
supertjeduc
« Reply #1 on: November 27, 2009, 05:49:45 AM »
The first on is good but is a cast one
The second i nicer and good i have one on the clutch side (it's a Spiegler but i think they are the same)
The third one i think is very big (to big) i did see those at a bikeshow last week and the are so big
And when you have the brakemaster you also need the clutch master because otherwise it looks silly
pjfa
« Reply #2 on: November 27, 2009, 06:09:13 AM »
Thank´s for your feedback.
Yes, I also think CNC is better than forged  Grin
I also think the same about the size of the ISR.
I may have some great deal with a used Magura.
loves ze desmodromics.
« Reply #3 on: November 27, 2009, 07:29:08 AM »
I have the Brembo "GP" radial forged 19x18 shown in the top. So does Kopfjager and Samsonite. It is fantastic.
« Reply #4 on: November 27, 2009, 07:29:38 AM »
Note that the Brembo is also available in Billet, but it is going to cost you a fortune. Check the Yoyodyne website.
Ducatl
« Reply #5 on: November 27, 2009, 07:59:53 AM »
I vote ISR with integrated master, they also come in black Wink.
pjfa
« Reply #6 on: November 27, 2009, 01:38:42 PM »
I also thing they are to big  Grin but thank´s for the info about the color.
Yes, a little fortune  bow down
Great.
So, here a used Magura 190 Radial Master Cylinder. I think I´ll keep it  popcorn
« Last Edit: November 27, 2009, 01:43:03 PM by pjfa » Logged
pjfa
« Reply #7 on: December 02, 2009, 02:11:00 PM »
I had some bad new today...
Seems like the Clutch MC from Magura doesn´t accept DOT oil so... bye bye the clutch to match with the brake  bang head
I will try the Brake MC and then I will see if I keep it or switch to Brembo because Pazzo Racing doesn´t have levers for Magura  Cry and I like my Pazzo´s  waytogo
« Reply #8 on: December 02, 2009, 02:12:20 PM »
What do you mean no DOT oil?
Which brake fluid does it not accept?
Enjoying the ride
« Reply #9 on: December 02, 2009, 03:19:45 PM »
Maybe DOT 3 or 4...
« Reply #10 on: December 02, 2009, 04:06:52 PM »
Then you could use 5.1...?
Not likely that its hydraulic but doesn't take brake fluid. Are you seeing the "mineral oil only" master and missing the others?
http://www.spieglerusa.com/MaguraPage/
« Last Edit: December 02, 2009, 04:09:10 PM by ato memphis » Logged
Enjoying the ride
« Reply #11 on: December 02, 2009, 05:05:35 PM »
pjfa,
you have to be more specific so that we can help regarding the fluid...
aaronb
« Reply #12 on: December 02, 2009, 05:47:15 PM »
all or magura bicycle products used mineral oil, maybe that's what they call for for the clutch.
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
« Reply #13 on: December 02, 2009, 05:51:58 PM »
Only Part No. 0020641 (12mm LH 195 model) states "Mineral Oil Only" so I would think that means other listed clutch master cylinders don't have such limitations.
The other options are: 0120643 (13mm LH 195 clutch); 0120437 (16mm LH 190 clutch); and 0120441 (13mm LH 190 clutch)
The 195 series is forged, looks like the forged brembo radial master.
The 190 series is billet, so you could pick either 16mm or 13mm and neither state a mineral oil limitation.
(Note: I'm just going by the Spiegler Catalog)
pjfa
« Reply #14 on: December 03, 2009, 10:18:08 PM »
Hi All  waytogo
Well... good news.
The last info was based from Portuguese importeur answer.
So, I´ve sent an e-mail to Magura (Germany) and they answer me:
the 190 works only with DOT. We haven´t another version from the 190.
 bow down
Now, I´m officialy looking for a Radial 190 Clucth from Magura  Grin
Thank you for your support  waytogo
Pages: [1] 2 3   Go Up
