February 23, 2025, 09:38:25 PM
DFWM
Sorry, I could not wait for help
Topic: Sorry, I could not wait for help (Read 8291 times)
TresGatos
December 06, 2009, 05:54:26 PM »
Woo Hoo!!! It works! I knew the tank would but my repositioning, wiring, and routing was worrisome. I was right, the starter cable (new) should go onto the solenoid post, not its tank bolt. I figured I had fried something, like maybe the ECU
Figured it out and 8 total hours of labor and voila! [moto]
Josh, I'm sure it would have gone much better with your help, but I could not resist.
Last Edit: December 06, 2009, 06:22:16 PM by TresGatos
'65 Honda CM91 - '98 Suzuki DR650 - '08 695+mods - '08 Hypermotard 1100S
caffeinejunkee
Re: Sorry, I could not wait for help
December 06, 2009, 06:12:06 PM »
Quote from: TresGatos on December 06, 2009, 05:54:26 PM
the proof
Last Edit: December 06, 2009, 06:14:14 PM by caffeinejunkee
caffeinejunkee
December 06, 2009, 06:16:28 PM »
Oh, BTW, you beat the Busa's tank by almost a gallon.
fastwin
December 06, 2009, 06:23:12 PM »
I assume that you made the switch to the larger aftermarket gas tank but it's kinda hard to tell by the post and pics. I feel like I need a McCain/English English/McCain dictionary.
TresGatos
December 06, 2009, 06:32:42 PM »
Bonus, now I know how to get a little screw out of a fuel tank. Remove the tank, dump the fuel, remove the fuel pump and carefully drain until the fastener comes out. But wait ther's more!! Take the time to put a rag in the hole in the first place, or buy a new tank and do what I did.
fastwin
December 06, 2009, 06:41:15 PM »
Is that the California Cycle Works tank conversion? With that much fuel you'll out ride everyone! Nothing better than gassing up at the pump for a couple of bucks while the Suburban next to you rolls past $75 bucks on the meter! I know, I have scooters and that Suburban!
TresGatos
December 06, 2009, 06:59:44 PM »
Once I did what they said, the tank fit right in and looms and wires had grooves that worked just fine.
Even the pump and filler flanges had no problem like they warned.
Now when the weather and my schedule allows, I'll ride to, ... hell I don't even know
Cher
Mostly Harmless
December 07, 2009, 03:08:35 AM »
Holy smokes, very cool conversion! What was the range before the bigger fuel tank, and what is it now?
webspoke
December 07, 2009, 04:32:53 AM »
Great job getting it in, curious now how many gallons it will take to hit the reserve light, so get riding!
Streetfighter 1098S
RED
carries my
'04 ST4s, '73 Triumph Bonneville 750 cafe
December 07, 2009, 05:47:00 AM »
Nicely done!
TresGatos
December 07, 2009, 09:01:46 AM »
Quote from: lisaboyd on December 07, 2009, 03:08:35 AM
About 90 miles before. Should get 200+ after
loves ze desmodromics.
December 07, 2009, 10:30:10 AM »
LOOKS AWESOME!
And like a fun project. I will not forgive you for excluding me, that is... until I see it in person. Then all is ok.
TresGatos
December 07, 2009, 12:55:35 PM »
Thanks for the complements! 2 things: I've got an un
uses hose on the bike, and how much does 6.4 gals
of 93 octane weigh?
December 07, 2009, 01:02:49 PM »
Gas weighs about 6 lbs and change per gallon iirc.
So around 36-42 lbs.
fastwin
Reply #14 on:
December 07, 2009, 01:11:28 PM »
I was thinking it was abound 8 lbs/gallon. Anyone have a gallon in the garage to weigh?
