January 30, 2025, 08:07:06 PM
SoCal Monsters
Alternator solved! New problem:
Topic: Alternator solved! New problem: (Read 4410 times)
evoasis
I lost my Titanium Member
January 25, 2010, 07:57:22 AM »
I need either that or some quick advice on putting my duc back together. I was in the middle of fixing the shifter fork spring and alternator generator when I had to perform a military obligation, forgetting how the thing went back together
1) I need to know which direction the clutch control rod goes back in (In reference to the rounded end and the O-Rings)
2) I need to know which way the flywheel's inner ring installs in reference to its broad side and the engines inner case.. Item #18 and that washer #17 looks alot thicker on the diagram than the thin one I seem to have...
Cheers,
Christopher
Last Edit: January 29, 2010, 11:34:40 AM by evoasis
I guess there are good and bad mods; you'll find the good ones here
Re: Haynes Manual to Borrow?
January 25, 2010, 09:01:24 AM »
Clutch pushrod; O-rings toward the left side.
Which # on the diagram is "flywheel inner ring"?
evoasis
January 25, 2010, 09:07:00 AM »
Number 18 Nick, thanks for the help old buddy.. The ECU is STILL working just fine
evoasis
January 25, 2010, 09:10:45 AM »
It's in no way attached to the flywheel, it just slips on the spindle with it
January 25, 2010, 09:17:04 AM »
It goes together as shown in that diagram.
Put some grease on the washer #17 to hold it in place for installation.
Make *absolutely* sure that it hasn't slipped out of place before you tighten the nut.
evoasis
January 25, 2010, 09:22:48 AM »
Will do, thanks man. Why would they make a washer whose inner diameter is larger than the spindle it rests on?
January 25, 2010, 09:26:52 AM »
ID of washer #17 is just slightly bigger than the snout on #18.
Not sure why they did it that way.
January 25, 2010, 10:38:56 AM »
Quote from: Speeddog on January 25, 2010, 09:26:52 AM
Not that Speeddog needs this, but I can completely confirm the above information and yes....#17 is like wafer-thin.
evoasis
January 25, 2010, 11:25:12 AM »
Stupid Ducati.. Alright here's what I'm goin' with. When it breaks I'll drop it off @ Valley Ducati
I need to sync all the tick marks huh. Damn. lol
evoasis
January 25, 2010, 02:52:17 PM »
Does it really matter the position of the tick marks on the flywheel in reference to the piston position? Idk if they've ever given me a correct TDC reading since I've owned the bike~
January 25, 2010, 02:56:47 PM »
Quote from: evoasis on January 25, 2010, 02:52:17 PM
Well, at the very least, it's better to get it right, just to avoid confusion in the future.
What model and year of Monster?
January 25, 2010, 08:21:07 PM »
Quote from: evoasis on January 25, 2010, 11:25:12 AM
The white mark you have circled needs to line-up with the small gear that is keyed onto the crankshaft. That alignment is what keeps the valves from kissing the pistons. I don't know what other mark you have circled in that picture, but it's not the alignment for the timing.
January 25, 2010, 08:21:57 PM »
Quote from: Speeddog on January 25, 2010, 02:56:47 PM
'02 to '05 620 IIRC...
January 25, 2010, 08:28:18 PM »
IIRC, there's a dot on the center hub of the flywheel that lines up with a slot or a mark on the crank, such that the hashmarks on the flywheel will give you a correct TDC and Ignition point in the sidecover window.
I think that's what he's talking about..
evoasis
Reply #14 on:
January 25, 2010, 09:09:21 PM »
Yeah it's for the timing mark in the window, I never use it when I shim, I just go with watching the valves for compression / exhaust strokes and with a screwdriver in the spark plug's hole.
Turbine engines are so much easier than these things. Hell, even the boxer engines on a Cessna are more straightforward, but magnetos are no fun to sync...
Edit: I didn't take any other gears off other than the (#20) pictured~ And that just engages the crank from the starter I thinkkkkkkkkk...
Last Edit: January 25, 2010, 09:11:37 PM by evoasis
