February 06, 2025, 12:57:39 AM
Cafe build...beginning?
Topic: Cafe build...beginning? (Read 9919 times)
TAftonomos
is without a monster :(
February 25, 2010, 04:02:46 PM »
Here is what I've got so far:
999 frame
999 mono subframe
999 tank/seat
S4rs swingarm, that is broken. All the parts are good, but the arm is tweaked and probably not worth saving
1098 forks
1098 triples
999 stem
999 radial master cylinder
What I don't have:
headlight/1/4 fairing
Wheels
rotors
calipers
lines
and a motor....
I can built the exhaust easily, and fab up whatever else I might need. Thoughts were to use the sssa from a s*r, and loose the suspension linkage, weld a mounting boss to the swingarm, and mod the frame for a direct setup. Another idea is a older 900ss aluminum swingarm, but the sssa is "cooler". Yet another idea is to find an arm off a 696, but I have yet to see one FS (and will probably be $$$ to put a complete setup together).
Thats what I need help on. Looking for a 2v, simple, clean, and light. Can't decide between a carb'd 900 with single short manifolds, or trying to piece together a 1000 or 1100 motor from ebay. I'm a bit leery of that, because the little wiring bits that you may not get can nickle and dime ($50/$100) you to death in a hurry. I don't need a zillion hp, just enough to have fun with in the mountains, and take to the track.
I admire a LOT of the work that takes place on this site, and welcome the thoughts and opinions of everyone! Input requested!
MyDucParts.com
mattyvas
Re: Cafe build...beginning?
February 26, 2010, 12:20:41 AM »
I don't know I can offer any advice but my thoughts/preference would be a DSSA
I do love the SSSA but on a Cafe bike DSSA and low pipes just rock.
Other than that, I'll just wait and watch what kinda magic you come up with.
My new web home is now at
www.mattvas.com.au
MattyVas Flickr Photos
OzMonsters Flickr Photos
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
February 26, 2010, 12:36:55 AM »
I saw a 696 swingarm for sale recently.... but after half an hour of searching I'm buggered if I can find it again
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Howley
February 26, 2010, 12:37:45 AM »
If you're going cafe you gotta go a carbed 900!
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
February 26, 2010, 01:41:36 AM »
900 and DSS for sure
dropstharockalot
Sex-Toy Bludgeonin'
The Teabaggin' Dragon
February 26, 2010, 04:57:53 AM »
Quote from: Big Troubled Bear on February 26, 2010, 01:41:36 AM
While you're at it.... dual external rear shocks, a la Sport Classics or Triumphs.
///since I'm not the one doing the work...
Like these'uns:
'96 M900
Some Dude
February 26, 2010, 07:42:57 AM »
Quote from: ungeheuer on February 26, 2010, 12:36:55 AM
This One
Bike Info
99 m900s Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
Ducatl
February 26, 2010, 08:09:44 AM »
696 arms are popping up on eBay constantly as I've seen 5 or 6 sell already and less than $150 in almost all of the cases. I'm sure if you keep an eye out daily you could pick one up soon.
Alternatively, SC swingarm with the dual shocks?
Last Edit: February 26, 2010, 08:12:29 AM by Ducatl
February 26, 2010, 08:49:01 AM »
Superbike frame, air-cooled Ducati motor, and S2R swingarm. I think of Radical Ducati. Will your bike be anything like these? Will it be hard to match the 2V engine to the 999 frame?
February 26, 2010, 09:16:58 AM »
I wouldn't try to piece together a DS1000 or 1100 from ebay when you could buy the whole engine. DS1000's are often listed for $2K or more. 900's are generally half of that. However, here is a DS1000 with broken motor mounts for $899 on eBay right now. This may be something you could fix with your welding skills. Add a set of FCR's from CA-Cycleworks (because it's not my money) and you will have yourself one of the baddest air cooled Ducatis of all time.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230436836239&viewitem=&_trkparms=clkid%3D8122856209577889338
Last Edit: February 26, 2010, 09:25:20 AM by Travman
TAftonomos
February 26, 2010, 03:46:41 PM »
Quote from: Travman on February 26, 2010, 09:16:58 AM
Been speaking with that guy about the 1000 motor....When I said piece together, mainly talking about getting the motor here, wiring there, ecu, from somewhere else, etc...
Only concern on that motor is the way it broke, and how would I be able to weld on the bottom side of the mount (can't). Would it be strong enough if I did the sides...I'm unsure.
The mounts I've seen/welded were along the sides where I could get to 100% of it....not so with this one.
And yes, something like the radical ducatis....without the 2K tank and tail....I'll make my own tail and use the 999 tank/seat.
I did find a built 750 motor that made 83 hp on the dyno..... thats a bit more than a stock 900 w/carbs iirc. Then again, a carb'd 1000 motor would be cool.... I'm unsure how I would control the timing, but I'm confident it could be done.
MyDucParts.com
February 26, 2010, 03:58:07 PM »
Quote from: TAftonomos on February 26, 2010, 03:46:41 PM
<snip> Then again, a carb'd 1000 motor would be cool.... I'm unsure how I would control the timing, but I'm confident it could be done.
Ignitek...
February 26, 2010, 04:57:39 PM »
I just mentioned that damaged 1000 motor because it is the only one I've seen for under $2K and knew you might have an idea if it was usable. I saw one for less but it was missing parts like the clutch. Chris at CA-Cycle has a DS1000 for sale for $2K.
If you were to build an engine, I wonder if a 1000DS top end would fit on top of a 900 bottom end.
February 26, 2010, 05:01:58 PM »
Quote from: Travman on February 26, 2010, 04:57:39 PM
I'm not sure, but I don't think that would be a bolt on.
fouramdesigns
Reply #14 on:
February 26, 2010, 05:10:39 PM »
Like this exhaust, want something similar. Only options seem to be ExBox to get a different look. Very nice bike.
2001 Monster S4, Termignoni/ECU, DP short air box w/BMC filter, Rizoma Zero's front/back, Cookie tail chop, Rizoma belt covers, Evoluzione slave, CF all over
