February 22, 2025, 11:18:48 PM
oil cooler interchangeability?
Topic: oil cooler interchangeability? (Read 4947 times)
Privateer
February 28, 2010, 06:06:04 AM »
I have the opportunity to pick up an oil cooler off a 750 to graft onto my 620.
Any known problems with this? Any specific parts I should ensure I obtain from the seller?
Thanks
Re: oil cooler interchangeability?
February 28, 2010, 06:41:13 AM »
Quote from: Privateer on February 28, 2010, 06:06:04 AM
Thanks
Hoses...fittings on the cases...baffle under the oil filter.
and the valve cover to attach it to.
teddy037.2
February 28, 2010, 08:08:10 AM »
the cover might be the tricky bit... does the 750 have that sensor for the head like the 620 does?
February 28, 2010, 08:16:41 AM »
Quote from: teddy037.2 on February 28, 2010, 08:08:10 AM
Maybe if it was injected.
If not any valve cover with the mount should work
February 28, 2010, 08:18:52 AM »
Only the fuel injected M750, which limits you to one year. I'm not sure if 900 valve covers with the 5.9 computer fit, if they do that would increase your possibilities.
Mr Earl
2003 M800 Dark
February 28, 2010, 09:36:25 AM »
The M800 cover should work, too, but somewhat slim pickins there as well. Only 2 years production.
How about S2R800 cover?
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
teddy037.2
February 28, 2010, 10:06:10 AM »
Quote from: Mr Earl on February 28, 2010, 09:36:25 AM
the S2R 800 should fit
February 28, 2010, 10:08:42 AM »
2000-2002 M900
2002 M750
2003-2004 M800
2005-2007 S2R800
All those will interchange and provide the required sensor mount and cooler mount.
February 28, 2010, 10:13:45 AM »
AFAIK, all '2-valve' belt drive valve covers are the same profile and bolt pattern, except for DS and 696.
So they'll interchange.
I'm pretty sure the valve cover from '02 M750, '02 M900, M800 and S2R800 will all work for a high-mount oil cooler on an M620.
feck, Stu got it while I was hunting and pecking.
February 28, 2010, 10:55:39 AM »
how do the 4V lower oil coolers mount?
February 28, 2010, 11:18:29 AM »
Quote from: Speeddog on February 28, 2010, 10:13:45 AM
Ha-ha!
February 28, 2010, 11:25:18 AM »
Quote from: Raux on February 28, 2010, 10:55:39 AM
I can go check my 996, but it's probably different from a Monster
Enjoying the ride
February 28, 2010, 11:47:32 AM »
Quote from: ducpainter on February 28, 2010, 11:25:18 AM
please do since i was thinking on purchasing a 749 oil cooler for my m620...
February 28, 2010, 12:04:15 PM »
The one on the 996 mounts very much like the Monster.
The ears are ~4 3/4" apart and they use an insulator like the ones on an SBK exhaust as opposed to the rubber peg like a 2V monster.
Reply #14 on:
February 28, 2010, 12:29:01 PM »
yeah i'm thinking about doing this for the rebuild.
