February 22, 2025, 10:57:40 PM
oil cooler interchangeability?
Topic: oil cooler interchangeability? (Read 4945 times)
Enjoying the ride
Re: oil cooler interchangeability?
Reply #15 on:
February 28, 2010, 12:58:43 PM »
Quote from: ducpainter on February 28, 2010, 12:04:15 PM
The one on the 996 mounts very much like the Monster.
The ears are ~4 3/4" apart and they use an insulator like the ones on an SBK exhaust as opposed to the rubber peg like a 2V monster.
so instead if a 749 oil cooler a 996 oil cooler will fit 'easier'? just need to get the covers and lines? or something else?
Reply #16 on:
February 28, 2010, 01:06:10 PM »
Quote from: Darkmonster620 on February 28, 2010, 12:58:43 PM
I honestly cant say. The 996 cooler has a separate line that runs to the heads I think. That would need to be plugged for your 620. You would need to measure a 2V cover to see if it would work.
I don't know what the dimensions are on the 2V cooler mounts.
Privateer
Reply #17 on:
February 28, 2010, 01:19:41 PM »
this one happens to be a 2002, so looks like I'm in luck. Need to see if they'll include all the necessary bits. For $100, it seems like a good deal.
Enjoying the ride
Reply #18 on:
February 28, 2010, 01:28:25 PM »
Quote from: ducpainter on February 28, 2010, 01:06:10 PM
But then why the M1000 mounts above and the M620 under?, don't like it there...that's why I like the SBK/S4R look...
Reply #19 on:
February 28, 2010, 01:34:47 PM »
Quote from: Darkmonster620 on February 28, 2010, 01:28:25 PM
You don't like it high...or low?
You could always make a bracket to mount it wherever you want.
Enjoying the ride
Reply #20 on:
February 28, 2010, 01:36:41 PM »
Quote from: ducpainter on February 28, 2010, 01:34:47 PM
...low
Quote
....that's not the issue, the issue are the hoses....
what about an st or mts oil cooler?
Reply #21 on:
February 28, 2010, 01:39:09 PM »
Quote from: Darkmonster620 on February 28, 2010, 01:36:41 PM
...low
what about the st oil cooler?
The SBK has the cooler low...radiator high.
You can have hoses made. You just need a supplier that has AN-6 fittings.
I believe the ST would use the same cooler as an SBK mounted low.
Enjoying the ride
Reply #22 on:
February 28, 2010, 02:23:31 PM »
Quote from: ducpainter on February 28, 2010, 01:39:09 PM
but, i do like the sbk look of the cooler...and the fittings, male/female for engine and female for cooler? right?
i can always get a belly pan for cosmetics reasons but, if it's too much hassle[me being down here and not to thrustworthy machinists around] then i'll got the 'oem' way but mod to m1000 looks. above...if it's rectangular goes up, trapezoidal, down...
Reply #23 on:
February 28, 2010, 02:28:48 PM »
Quote from: Darkmonster620 on February 28, 2010, 02:23:31 PM
I'd have to check on the fittings on the cooler.
The coolers on the old/748-996 SBKs are rectangular.
teddy037.2
Reply #24 on:
February 28, 2010, 02:38:03 PM »
I am totally confused here... carlos, are you trying to mount a 2V cooler to the lower valve cover of your bike (4V "look" mounting)?
or mount a 4V cooler (low, like the 4V bikes)?
Enjoying the ride
Reply #25 on:
February 28, 2010, 02:43:53 PM »
Quote from: teddy037.2 on February 28, 2010, 02:38:03 PM
4V cooler to my 2V M620D....
sorry for the confusion...
me not thinking straight, wife's being ill for the past two weeks and haven't been getting to much rest so ideas are clear in mind but not n writing...
teddy037.2
Reply #26 on:
February 28, 2010, 03:02:06 PM »
ah... gotcha.
making spacers from cooler to cover will most likely be the only "problem" if the widths are different... fittings and line are pretty easy to come by.
a cover from a carby 750 or 900 should probably bolt right up on the bottom of the head
Enjoying the ride
Reply #27 on:
October 29, 2010, 05:32:48 PM »
OK guys, I made the purchase, a S4Rs oil cooler but no lines.
Parts needed? Need list in order to purchase what's needed.
Hoses? S4R/s/T hoses or pre-assembled kit for 2v or 4V or just purchase OEM M620? No reliable hose assembler locally so need to purchase.
Thinking of manufacturing bracket so that cooler is in an 'in between' position, not so high not so low.
Thanks
Reply #28 on:
October 31, 2010, 06:19:15 PM »
If you use the cooler in the stock location you should be able to use stock 2V lines...I think.
If you move it all bets are off.
Enjoying the ride
Reply #29 on:
October 31, 2010, 06:22:26 PM »
Quote from: humorless dp on October 31, 2010, 06:19:15 PM
my idea is to install it in an 'in between' location; M620 install low, M1000 hi, in between ... but, what parts do i need?
only got cooler in good condition, hoses are toast ... it's from a S4Rs
