February 22, 2025, 10:52:46 PM
Please Help
Lower back pain from bad Shock?
Topic: Lower back pain from bad Shock? (Read 1988 times)
Piller
March 15, 2010, 11:10:53 AM »
I heard the shock on the 695 is bad. Could this cause lower back pain? I drove for three hours and it seemed like the shock wasn't doing much. Is the stock shock adjustible?
My back has been hurting for three days.
Last Edit: March 15, 2010, 11:18:04 AM by Piller
Spidey
Crashin' mofo
Re: Lower back pain from bad Shock?
March 15, 2010, 11:14:51 AM »
Hey Piller. The problem is your riding posture and that you're not in shape for long-distance riding, not the shock. It *could*--depending on your weight--not work as well as you'd like, but it almost certainly isn't what is causing your pain.
The shock is adjustable for preload (which you should adjust -- how much do you weigh?), but not for rebound or compression. Your next questions should probably be a follow-up about proper posture, followed by a tech question about preload, rebound and compression, and how to set your preload.
P.S. You ride a bike, not drive it.
Piller
March 15, 2010, 11:22:56 AM »
Ok. I weigh 180. I'll look into the posture and preload stuff. Is the rear shock a very noticeable improvement to make? I did seem to feel every bump.
Spidey
Crashin' mofo
March 15, 2010, 11:36:48 AM »
Your rear is set up for someone lighter than you, so you'll want to adjust the preload.
Changing out the entire rear shock will make a really big difference in how your bike feels, but so will adjusting the preload and maybe changing out the spring.
Changing your posture, how you hold yourself up on the bike, how you use your legs and how tightly your grip the bars will also have a drastic effect on whether you feel all the bumps or not.
BTW, did you check your tire pressure? That will also make a big difference. And if it's cold out, that too will affect how well your suspension works.
Piller
March 15, 2010, 12:16:19 PM »
This topic from the tutorial section isn't working:
Suspension, Adjusting Preload
http://ducatimonsterforum.org/index.php?topic=13710.0
Piller
March 15, 2010, 12:36:41 PM »
Here's a good tutorial I found:
http://www.ducatisuite.com/rearsuspension.html
I'm surprised that site's still around. Is the person who made that on this forum?
Mr Earl
2003 M800 Dark
March 15, 2010, 01:19:40 PM »
Quote from: Spidey on March 15, 2010, 11:14:51 AM
<snip>
Doesn't the 695 shock have rebound adjustment like the earlier Monsters? My M800 shock does...
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
Spidey
Crashin' mofo
March 15, 2010, 02:45:47 PM »
Quote from: Mr Earl on March 15, 2010, 01:19:40 PM
Yes, it does. My bad--typing fast and not thinking.
Feral 859
March 15, 2010, 08:46:51 PM »
No, You ride on the back, you drive the bike.
teddy037.2
March 16, 2010, 06:13:12 AM »
Quote from: kopfjäger on March 15, 2010, 08:46:51 PM
but you can still "go for a ride" by yourself...
Spidey
Crashin' mofo
March 16, 2010, 08:11:41 AM »
Hmmm. It appears that . . .
P.S. We're not talkin' about rollin' that pretty bike of yours into the back of the truck and takin' it to the shop for more bling. That's definitely driving.
Last Edit: March 16, 2010, 08:22:49 AM by Spidey
ArguZ
March 16, 2010, 09:50:38 AM »
The standard yellow spring is very soft but also nice to your back.
I upgraded to some orange Metise and its hard and higher now and better on the track but also harder to ride over four hours or so.
Go to the gym for four weeks daily..
Look for the back crunch machine..
Find a weight you can lift 20x3 times.
increase it every two or three days.
I bet the problems goes away before June.
March 16, 2010, 11:04:30 AM »
i think i found a pic of kopfjager
March 16, 2010, 01:49:32 PM »
Quote from: He Man on March 16, 2010, 11:04:30 AM
I'm not going to rescue you...
when he rips your head off and shits in your neck.
Statler
Reply #14 on:
March 16, 2010, 04:12:22 PM »
I'm not going to rescue you....
when one of the other admins bans you for baiting him into an argument with this blatant threadjack.
It's
still
buy a flounder a drink month
