Torque values
Started by Ddan, May 06, 2008, 01:46:27 PM
Ddan
Some torque values, taken from the Haynes 2valve, '91 to '96, and LT Snyders, Vol. 1
Conversion calculator:   http://www.boltscience.com/pages/convert.htm
                                 or:
 Ft.Lbs to Nm                  x 1.355
 Nm to Ft.Lbs                  x 0.737
Alternator nut                                    157 Nm
Alternator stator bolts                      8-10 Nm
Brake banjo bolts                           17-20 Nm
Brake caliper joining bolts                    33 Nm
Cam belt pulley nuts on camshafts    70-75 Nm
Cam belt pulley nut on driveshaft           60-65 Nm
Cam belt driveshaft gear nut                40-45 Nm
Clutch housing, 900 and early 750          30-34 Nm
Clutch nut                                          137-147 Nm
Clutch hose union bolts                  17-20 Nm
Connecting rod big end
    1st stage                                20 Nm
    2nd stage                                  35 Nm
    3rd stage                                  63.5-68.5 Nm
Crankcase bolts          M8                  23-25 Nm
                               M6                  8-10 Nm
Cylinder head nuts
    1st stage                                 15 Nm
    2nd stage                                     30 Nm
    3rd stage 900 w/ old studs         41-43 Nm
    3rd stage 600/750 and
     900 w/ new studs                         38-40 Nm
Disc mounting bolts                         26 Nm
Engine mounting bolts                         40-45 Nm
Exhaust flange nut                         23-25 Nm
Fork top bolt
         Showa                                   35 Nm
        Marzocchi                                 25 Nm
Front axle nut                                 70-76 Nm
Front axle clamp bolts                         20-25 Nm
Front brake calipers                         35-38Nm
Gear change pedal                         23-25 Nm
Gear shaft bearing retainer bolts         8-10 Nm
Handlebar clamp                                22-27 Nm
Low fuel level sensor                        32-35 Nm
Oil drain                                        40-44 Nm
Oil pressure switch                        18-20 Nm
Oil pump mounting bolts         M8        23-25Nm
                                          M6        8-10 Nm
Pick-up coils                                4-6 Nm
Primary drive gear nut                        110-120 Nm
Rear axle nut                                70-76 Nm
Rear brake caliper                               23-25 Nm
Rear brake pedal                                23-25Nm
Rear shock             Upper                 39-44Nm
                           Lower                 34-37 Nm
Rear suspension linkage arm
to frame bolt                                  34-37 Nm
to linkage fork bolt                          34-37 Nm
Rear suspension ball joint
locknut to linkage fork                        34-37 Nm
Rear suspension linkage fork
to swingarm bolt                              22-24 Nm
Rear wheel axle nut                        69-74 Nm
Spark plugs                                        29 Nm
Starter motor mounting bolts             8-10 Nm
Steering head nut                        40-45 Nm
Swingarm pivot pin clamp                34-37 Nm
Top yoke pinch bolts   M8                 20-25 Nm
                              M10                35-38 Nm
Ducati Monster Forum at
www.ducatimonsterforum.org
VisceralReaction
Dan, thanks for taking the time to do this! wt:
Fresh Pants
+1
I was just about to post this. I had it saved on my HD at work.
Bwooooooahhh
Braaaaaaaappp
CRASH!
Hey Admins! Time for a FAQ page ;D
techno
One more to add for those with a single sided swingarm. The two bolts clamping the axle should be 33Nm according to my dealer.  wt:
Quote from: ducmeister on May 24, 2012, 01:45:16 AM
Hey Techno you are a smart man.  [thumbsup]
Had an accident in Tasmania? - www.tas-compo-law.com.au
teddy037.2
or at the very least, a sticky!
carlosbarrios
#6
Torque settings for 07 S4RS:
-  Torque settings
Frame torque settings  Part  Thread (mm)  Nm ±10% Tolerance  Notes
Front sprocket
Front sprocket retaining nut  M25x1.5  186 *  GREASE B
Front sprocket cover bolt  M6x1  6
Drive chain slider retaining screw  M6x1  6
Lights and reflectors
Headlight retaining bolt  M8x1.25  12
Bolt securing headlight support to subframe on silent block     4
Tail light unit nuts  M6x1  6
Number plate light nuts  M5x0.8  2.5
Reflector nut  M4x0.7  2
Cable guide to headlamp mount retaining screw  M6x1  9
Turn signal retaining bolts  M6x1  6
Headlight support retaining bolt  M6x1  10
Headlight reflector retaining bolt  M4x0.7  2.3
Instruments
Fasteners securing silent block mountings for instrument panel  M5x0.8  4
Bolts securing instrument panel to silent blocks  M5x0.8  5
Air temperature/pressure sensor retaining bolt  M6x1  6
Front Fork
Top yoke central retaining bolt  M8x1.25  23 *  GREASE B
Top yoke bolts  M8x1.25  22 *  GREASE B
Bottom yoke clamp bolt  M8x1.25  20 *  GREASE B In the sequence 1-2-1
Front axle clamp bolt  M8x1.25  20 *  GREASE B Sequence 1-2-1
Steering limit lock nut  M8x1.25  18  LOCK 2 (apply Loctite to nut thread only)
Steering stem nut  M35x1  30 *  GREASE B
Fork splashguard retaining bolt  M5x0.8  5.5  LOCK 2
Electrical System
Relay bracket bolt  M5x0.8  1
RH/LH handlebar switch bolt  M5x0.8  3.5
Keyswitch cover cap nut  M6x1  7
Keyswitch screw  M6x1     * Tighten down the screw head until it fails LOCK 2
Battery terminal bolt  M6x1  6
Starter motor nut  M6x1  5
Nut securing cable to starter relay  M6x1  4
Speed sensor retaining bolt  M6x1  10
Bolt fastening regulator to oil breather tank and frame  M6x1  6
Bolt securing regulator to oil breather tank  M6x1  6
Bolt securing battery support to silent-block mountings  M6x1  6
Bolt securing battery support to cylinder head  M6x1  10
ECU retaining bolt  M6x1  13
Bolt securing earth cable to engine  M6x1  10
Horn bracket retaining screws  M6x1  10  LOCK 2
Horn retaining screw  M8x1.25  25  LOCK 2
Immobilizer antenna        Mounted on assembly line between antenna and Lock 11 switch cover
Front brake
Front brake caliper bolt  M10x1.25  43 *  GREASE B
Front brake master cylinder bolt  M6x1  9  Sequence 1(UP)-2-1
Rear brake bleeder fitting to caliper  M10x1  7
Front/rear brake hose fitting  M10x1  20
Gearchange lever and brake pivot bolt  M8x1.25  24  LOCK 2
Rear brake
Rear brake caliper bolt  M8x1.25  25 *  GREASE B
Rear brake master cylinder bolt  M6x1  10
Rear brake reservoir retaining bolt  M6x1  2
Swingarm
Swingarm pivot shaft bolt  M8x1.25  18 *  GREASE B
Chain tensioner eccentric screw  M12x1.25  33 *  GREASE B Sequence 1-2-1
Bolt securing rear brake hose guide and speed sensor to swingarm  M5x0.8  2.5
Front and rear chain-guard retaining screw  M6x1  6
Caliper mounting bracket pin  M12x1.25  33 *  LOCK 8
Handlebars - Clutch control
Handlebar top clamp bolt  M8x1.25  20 *  GREASE B In the sequence 1-2-1
Clutch master cylinder bolt  M6x1  9  Sequence 1(UP)-2-1
Clutch hose connector  M10x1  20
Clutch bleed valve  M6x1  4
Clutch cylinder retaining screw  M6x1  10
Throttle twistgrip retaining bolt  M6x1  10
Throttle twistgrip cover retaining bolt  M4x0.7  1.8
Counterweight bolt  M6x1  9
Rear shock absorber
Shock absorber top bolt  M10x1.25  45 *  GREASE B
Shock absorber bottom bolt  M10x1.25  45 *  GREASE B
Suspension linkage upper bolt  M10x1.25  45 *  GREASE B
Nut securing suspension rocker arm to frame  M12x1.5  75 *  GREASE B
Nuts securing end fittings to tie-rod  M12x1.5  36 *
Front and Rear Mudguards
Front mudguard retaining bolt  M6x1  3  LOCK 2
Number plate holder bolt  M6x1  5.5
Bolt securing splashguard to underseat  M6x1  1.8
Nut securing number plate holder to splashguard  M6x1  1.9
Footrests and Levers
Gearchange lever retaining bolt  M6x1  10  LOCK 1
Bolt securing gearchange linkage pivot to gearchange lever  M6x1  10
Bolts securing front footrest bracket to engine  M10x1.5  36
Bolts securing front footrest brackets to swingarm pivot shaft  M12x1.5  55 *  GREASE B
Bolts securing rear footrest brackets to frame  M8x1.25  24  LOCK 2
Bolt securing heel guard to footrest bracket  M5x0.8  5  LOCK 2
Front and Rear Wheels
Front wheel nut  M25x1.25  63 *  GREASE B
LH rear wheel nut  M33x1.5  156 *  GREASE B
RH rear wheel nut  M38x1.5  176 *  GREASE B
Front and rear brake disc retaining bolt  M8x1.25  25 *  LOCK 2
Rear sprocket nut  M10x1.25  48 *  LOCK 2
Bolts securing driving pins  M6x1  11 *  LOCK 2
Fuel tank
Fuel hose clamp     1.5
Tank filler cap screw  M5x0.8  6
Tank hinge bracket retaining screw  M6x1  10
Fuel tank rubber mounting retaining screw  M6x1  10
Exhaust system
Exhaust pipe clamp retaining bolt  M8x1.25  19
Special bolt securing exhaust manifolds to crankcase  M12x1.5  25  LOCK 1
Bolt securing exhaust pipes to crankcase  M6X1  9
Fasteners securing 1/8” gas stainless steel plugs to exhaust pipes  M10x1.25  25
Bolt securing silencer to frame  M8x1.25  24
Bolt securing heat shield to silencer  M6x1  10  LOCK 2
Bolt securing heat shield to exhaust  M5x0.8  2.4  LOCK 2
Nuts securing exhaust pipes to horizontal and vertical cylinder heads  M6x1  10
Lambda probe fastener  M8x1.5  45
Seat
Seat lock nut  M22x1.5  1  LOCK 3
Seat lock support retaining screw  M5x0.8  6
Seat cover support retaining screw  M5x0.8  3
Seat slide screw  M5x0.8  6  LOCK 2
Bolt securing seat cover and storage compartment cover to seat  M6x1  2
Seat lock screw  M5x0.8  6
Intake Oil Breather
Fastener securing air box stud bolt to air box  M6x1  6
Fastener securing air box stud to dowel  M6x1  4
Fastener securing screw to front of air box  M6x1  10
Oil breather valve hose clamp  M7x2  1.2
Oil breather tank hose clamp  M7x2  2
Bolt securing oil breather tank to frame  M6x1  6
Screws securing springs to intake funnels  M5x0.8  3
EVAP system canister filter
Throttle body clamp  M4x0.7  1
Restricter plate retaining screw for power restricted model  M5x0.8  4.8  LOCK 1
Bolt securing canister support to engine  M6x1  10
Canister clamp retaining screw     1.7
Fairings
Side panel retaining bolt  M5x0.8  0.8
Bolt securing headlight shell to mounting bracket  M6x1  8
Sidestand
Sidestand bracket bolt  M10x1.5  36  LOCK 5
Sidestand sensor cable clamp bolt  M6x1  10
Sidestand pivot bolt nut  M8x1.25  24
Stand sensor bolt  M6x1  10
Frame
Nut for engine-frame bolt  M12x1.5  60 *  GREASE B
Screw securing hose guide to starter motor screw  M6x1  9
Oil cooler
Oil cooler retaining bolt  M6x1  9
Oil pipe union on cooler with TWIN SEAL O-ring  M16x1.5  25 *  Lubricate with engine oil (Shell Advance Ultra 4)
Oil pipe union on crankcase with Twin Seal O-ring  M16x1.5  25 *  Lubricate with engine oil (Shell Advance Ultra 4)
Oil cooler nipple  M14x1.5  27  LOCK 1
Oil pipe union on crankcase  M10x1  19
Oil delivery pipe to cylinder heads fitting  M10x1  15
Liquid Cooling
Radiator retaining screw  M6x1  10
Coolant hose clamp  M7x2  2.5
Clamp securing expansion reservoir hose to radiator  M4x0.7  1
Clamp securing expansion reservoir hose to reservoir  M4x0.7  0.5
Radiator side cowling retaining screw  M6x1  2.4  LOCK 1
Coolant drain plug on pump cover  M10x1  18
Screw securing bracket to expansion reservoir  M6x1  10
Screw securing expansion reservoir to head  M6x1  10
Engine torque settings
Part  Thread (mm)  Nm  Min.  Max.  Notes
Blow-by valve  M40x1.5  40  36  44
Pick-up filter cap  M32x1.5  42  38  46
Coolant inlet union  M30x1.5  30  27  33  LOCK 6
Oil temperature sensor holder nut  M30x1.5  38  34  42  LOCK 4
Crankshaft gear nut  M25x1.5  190  171  209  GREASE B
Alternator rotor nut  M24x1  270  256  284  LOCK 5
Primary drive gear nut  M22x1  190  171  209  GREASE B
Oil drain plug  M22x1.5  42  38  46   (NOTE:  If  your drain plug uses a 5mm hex the torque is 20nm)
Oil pick-up filter  M22x1.5  42  38  46
Coolant outlet union  M22x1.5  27  25  30  LOCK 5
Engine fan thermo switch  M22x1.5  42  38  46  LOCK 4
Oil filler plug  M22x1.5  5  5  6
Idler/tensioner pulley mounting stud  M20x1  50  45  55  LOCK 2 or THREE BOND 1324
Clutch centre nut  M20x1  190  180  200  GREASE B
Steel/aluminium crankshaft blanking cap  M20x1  15  13.5  16.5  THREE BOND 1375B
Head timing belt roller ringnut  M17x1  71  64  78  GREASE A
Selector drum locating screw  M16x1.5  30  27  33
Oil filter nipple  M16x1.5  42  38  46  LOCK 2 or THREE BOND 1324
Oil filter cartridge  M16x1.5  11  10  12  Engine oil on gasket
Pick-up filter housing plug  M15x1  20  18  22  LOCK 5 or THREE BOND 1375B
By-pass pump cap  M15x1  25  22  28  LOCK 5 or THREE BOND 1375B
Timing belt driveshaft pulley nut  M15x1  71  64  78  GREASE A
Timing belt camshaft pulley nuts  M15x1  71  64  78  GREASE A
Alternator cover inspection plug  M15x1  20  18  22  THREE BOND 1215
Idler pulley bearing screw  M14x2  50  45  55  GREASE C
Low sump oil intake duct plug  M14x1.5  24  21  27  LOCK 5 or THREE BOND 1375B
Timing belt driveshaft gear nut  M14x1  55  50  60  GREASE A
Radiator connection plug  M14x1.5  24  21  27  LOCK 5 or THREE BOND 1375B
Radiator connection blanking plug  M14x1.25  27  24  30  LOCK 5 or THREE BOND 1375B
Oil cooler nipple  M14x1.5  27  24  30  LOCK 5 or THREE BOND 1375B
Pick-up sensor inspection screw  M12x1  15  13  17  LOCK 2 or THREE BOND 1324
Earth connection bolt  M12x1  15  13  17  LOCK 2 or THREE BOND 1324
Oil temperature sensor  M12x1.5  18  16  19  LOCK 4
Coolant temperature sensor (control unit)  M12x1.5  23  20  26  LOCK 4
Spark plugs  M12x1.25  20  18  22
Lower sump oil drain plug  M12x1.50  20  18  22
Cylinder head nuts: Hand tighten Hand tighten Tighten down  M10x1.5    15 30 48      28 45      32 51  GREASE C
Connecting rod cap bolts: Tighten at 50 rpm Wait 2 seconds, then back off
360° at 30 rpm 1st step at 30 rpm 2nd step at 10 rpm Tighten by 65° +/- 1° at 14 rpm Torque check  M10x1    35     20 35   70-103        GREASE B
Oil pump duct plug  M10x1.5  fully seated with tool 15 13 17  LOCK 5 or THREE BOND 1375B
Cylinder head studs  M10x1.5  25  23  26  LOCK 2 or THREE BOND 1324
Pressure switch  M10x1  19  17  21
Threaded insert  M10x1           LOCK 5 or THREE BOND 1375B
Spark plug  M10x1  15  13  17
Water pump cover plug  M10x1  20  18  22
Neutral warning light switch  M10x1.25  10  9  11
Clutch-side crankcase service plug  M10x1.5  15  13  17  LOCK 5 or THREE BOND 1375B
Oil circuit plug - exhaust side  M10x1  15  13  17  LOCK 2 or THREE BOND 1324
Crankshaft grub screws  M8x1.25  13  11  15  THREE BOND 1375B
Tensioner pulley shaft  M8x1.25  26  23  29  LOCK 2 or THREE BOND 1324
Idler pulley shaft  M8x1.25  26  23  29  LOCK 2 or THREE BOND 1324
Selector claw bolt  M8x1.25  25  22  28
Gear stop lever bolt  M8x1.25  18  16  20  LOCK 2 or THREE BOND 1324
Oil pump bolts  M8x1.25  26  23  29
Clutch drum screws  M8x1.25  35  33  37  LOCK 4
Crankcase screws:
Stage 2
Tighten down  M8x1.25    19 25    17 22    21 28
Cam cap bolt:
Stage 2
Tighten down  M8x1.25    10 22.5    9 21    11 25  GREASE B
Crankcase drilled bolt  M8x1.25  20  18  22
Earth bolt  M8x1.25  13  11  15
Tensioner eccentric nut  M8x1.25  25  22  28  GREASE A
Screws for timing belt cover on cylinder head  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Clutch spring bolt  M6x1  6  5  7
Stator wiring clamp bracket bolt  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Intake and exhaust manifold studs  M6x1  5  5  7  LOCK 2 or THREE BOND 1324
Starter motor bolts  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Starter idler gear shaft screw  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Coolant pump bearing stop screw  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Alternator stator bolts  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Rotor/flywheel bolts  M6x1  13  11  15  LOCK 2 or THREE BOND 1324
Gearbox bearing retaining plate bolts  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Coolant drain bolt on union  M6x1  8  7  8  LOCK 2 or THREE BOND 1324
Fuel pump/intake manifold union  M6x1  2.5  2  3  LOCK 2 or THREE BOND 1324
Bosch pick-up bolts  M6x1  10  9  11
Fluid recovery tank bracket nut  M6x1  9  8  10
Spark plug cap screws  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Battery support stud  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Battery support lower stud  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Cylinder-side cover screws  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Cylinder head cover studs  M6x1  3  2  4  LOCK 5 or THREE BOND 1375B
Driven pulley flange bolts  M6x1  10  9  11
Cylinder coolant inlet union screw  M6x1  10  9  11  LOCK 2 or THREE BOND 1324
Selector claw bolt  M6x1  9  8.5  9.5  LOCK 2 or THREE BOND 1324
Cylinder heads/cylinders coolant cover screws  M6x1  6  6  8
Inspection cover bolts  M6x1  4.5  4.5  6
Cylinder head coolant outlet union screw  M6x1  10  9  11
Valve cover bolts  M6x1  10  9  11
Intake/exhaust valve cover screws  M6x1  10  9  11
Intake manifold nuts  M6x1  10  9  11
Crankcase screws  M6x1  9  8.5  9.5
Clutch cover bolts  M6x1  9  8.5  9.5
Alternator cover bolts  M6x1  10  9  11
Cylinder head cover nut  M6x1  10  9  11
Cooler mounting pin  M6x1  5  4  6  LOCK 2 or THREE BOND
Coil mount nut  M6x1  10  9  11
Clutch bypass valve screw  M6x1  6  5  7
Intake manifold plug  M5x0.8  3  2  3
Clutch spring bolts  M5x0.8  5  5  7
Manifold nipple  M5x0.8  3  2  3  LOCK 2 or THREE BOND 1324
Coolant hose clamps     2.5  2  3
Cylinder head oil hose screws  M5x0.8  5  5  7  LOCK 2 or THREE BOND 1324
Unspecified fasteners  M10x1.5  45  40  50
Unspecified fasteners  M8x1.25  25  22  28
Unspecified fasteners  M6x1  10  9  11
Unspecified fasteners  M5x1  5  5  7
CRASH!
Holy shit! Don't you think you might have missed a bolt?
I had no idea there were that many bolts on an S4R. Glad I have an oldy carby...much simpler. ;D
Maybe this should be moved to how to?  At least have it be a sticky in Tech.. and then sweep out junk posts like this one  ;D
mostro
hey guys, does anyone have any idea where i can find a gear change pedal? [thumbsup]
VeryMetal
You can find it just in front of your left foot peg, has a little rubber thing on it, looks a bit like the brake pedal on the right of the bike in the same location. Oh god, I'm so funny. Not. Sorry.
You could try posting a new thread in one of the other topics like 'tech' some of the members here have a pretty comprehensive collection of bits they could sell/ trade you. Or at least someone will be able to tell you where to get one.
Have you tried your dealer? They might have one lying around..
2002 Ducati Monster 750ie Dark
2005 Monster S2R Dark
mostro
how terrifically funny!
aite i shall try Tech. my local dealer is well far, so i don't go there often. thanks mate
Capo
Carlos, you deserve recognition for that, well done
Capo de tuti capi
Beyote
Thanks Guys.  I was just looking for this.
Misplaced my Haynes Manual and pulling my hair out trying to find the torque settings.
corey
#14
post removed to avoid confusing people.
-Cor
