November 28, 2023, 08:31:52 AM
2v SBK build thread
Topic: 2v SBK build thread (Read 31488 times)
TAftonomos
is without a monster :(
2v SBK build thread
April 28, 2010, 01:13:59 PM »
Some progress has been made.
999r stripped of it's former heart, in goes the ds motor (core).
Already found one problem, going to need a machinist to fix this one:
Motor is from a 04 multi, so it bolted right up to the frame, and the width is correct. What does not seem to be correct is the spacing between the rear motor mount bolt and the swingarm hole. The 999r motor measures approx 4.25" between the spots, whereas the ds motor is 4.00. You can see how the swingarm bolt appears to be centered, where it needs to be a bit lower to fit using the 999's pivot bolt blocks/washers. I'm hoping I can find someone to machine some new ones.
Other minor issue I can see is the exhaust routing/rear suspension linkage. A tight radius stainless donut ought to be able to give me the pieces I need to route around it.
MyDucParts.com
mattyvas
Re: 2v SBK build thread
April 28, 2010, 01:22:17 PM »
Wicked as always
I am sure you'll find someone to help fix your problems if you can't do it yourself.
So when you're done with it will you ship it to me here in Oz?
My new web home is now at
www.mattvas.com.au
MattyVas Flickr Photos
OzMonsters Flickr Photos
Some Dude
April 28, 2010, 01:24:08 PM »
Very nice. Someday I want to build something similar. What is that swing arm off of? It looks different than the normal 999 swinger.
Bike Info
99 m900s Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
TAftonomos
April 28, 2010, 01:31:25 PM »
999r (although all 999's from 05 on got the same arm)
MyDucParts.com
1KDS
April 28, 2010, 02:12:36 PM »
About the pivot location, at least you're using a 999 frame. It is the only SBK with oval mounts so all you have to do is machine a small insert (as you know). The progress looks great and you can really start to get a sense of what it will look like.
Every bike I've ever owned.
April 29, 2010, 02:14:04 AM »
I can picture the headlight and the guages from the SR4t in the background on your 2V SBK.
1KDS
April 29, 2010, 12:48:05 PM »
+1
loves ze desmodromics.
May 01, 2010, 09:45:16 AM »
fun! glad to have another one of these projects to get ideas from and contribute ideas to.
Monstermash
AKA-TomColore
Interferiscalo se potete
May 01, 2010, 06:36:09 PM »
Hey Theo,
Looks like a very cool project. I was thinking of doing something similar but I wantd to use the 999 frame, tank, and tail unit and make it naked.
I'm curious, have you given any thought to using the multi swingarm? Or maybe one from and S2/4R?
TAftonomos
May 02, 2010, 01:28:50 AM »
Going with the 999 arm as it's lighter as an assembly (probably stiffer as well). Since I'm using a multi motor, it's the same width as the sbk arm so no modding needed. If you want to use a s*r arm, make sure you use the correct case/motor.
MyDucParts.com
May 02, 2010, 05:43:31 AM »
for anybody tuning in that is interested in the 2vSBK idea, my iteration is (slow going) over here:
http://ducatimonsterforum.org/index.php?topic=36864.0
, and is a 748/996/998 era frame.
also, i claim the rights to the name "
testa aerea
" or "air head Ducati"
- my spin on Testarossa (red head, a la Ferrari and MBP) and Testastretta (narrow head - a la Ducati 4v's) - but we can totally shop this out and brand a bunch of bikes with the logo, work with a decal group to have them done in Ducati font for the fairings - cost to use the name is exactly 1 moonpie (double decker). or an "across-the-interwebs" high-five.
Last Edit: May 02, 2010, 05:46:15 AM by a m
May 02, 2010, 05:55:16 AM »
Things that inspired me:
http://ducatimonsterforum.org/index.php?topic=36864.msg649120#msg649120
My progress so far:
http://ducatimonsterforum.org/index.php?topic=36864.msg662676#msg662676
TAftonomos
May 02, 2010, 08:08:55 AM »
Nice
I'd like to get ahold of kamena (sp?) but can't navigate their site worth a shit. The US "dealer" has no info on it's page either....
I'm mainly after a fairing. Or mount up a 1098-style front light and fairing...although I don't think I want to add that much weight.
MyDucParts.com
S2R 800 '07
May 02, 2010, 08:23:33 AM »
Quote from: TAftonomos on May 02, 2010, 08:08:55 AM
Nice
It's Kämna / kaemna.de
What are you looking for? Is it a specific piece / on a bike / just the part in a picture?
I can take a look around for you...
Reply #14 on:
May 02, 2010, 08:27:19 AM »
http://www.kaemna.de/cms_en/katalog.htm?&view=seite&seite=3
or even better IMO
http://shop.durbahn.de/shop/en/products/Monocoque_-_Tailsections/Durbahn
Last Edit: May 02, 2010, 08:32:28 AM by Raux
