2v SBK build thread
Started by TAftonomos, April 28, 2010, 02:13:59 PM
1KDS
Glad to see some progress in this thread but...
Every bike I've ever owned.
Christian
Quote from: The Mad King Pepe' on September 21, 2012, 03:23:17 PM
On the 916 it's up from the master, between the fender and the shock (or in front of the shock if you don't have a fender), on top of the chain cover, then down to the caliper right before the sprocket.
What did you do for the motor/frame/swingarm setup? I see your "oops" photo showing them not line up, but no more photos to elaborate.
Did you remove bosses from the cases? What about the alignment issue?
The Mad King Pepe'
#92
Quote from: Christian on September 21, 2012, 07:23:55 PM
I think this is the photo you're talking about.
Found a good welder thanks to Artful and had him do a bit of cut & paste on the frame.
This photo should illustrate the problem better (this is before doing any work).
I took care of the engine cases with a cutter wheel and narrowed them down to the necessary width for the SBK swingarm to fit.
EDIT: Found where I went over these issues on my build thread: http://www.ducatimonsterforum.org/index.php?topic=46971.45
Christian
Thanks for the speedy reply!
My plan is to leave the frame as is, and try to deal with the hole through some sort of boss or filler bore.
Ideally I'd like to get the motor setup similarly to a 4V motor so it wouldn't need the one frame. I like your idea, though.
Decisions, decisions!
TAftonomos
minnesotamonster
2004 S4R
1998 Honda F3 (Track)
2001 M600 (Now the Wife's)
The Mad King Pepe'
My name is Jack Daniels and I approve this message!!!
Randy@StradaFab
Lookin Good!! But you really need a Ti frame ;D
1KDS
really digging the naked 749/999 look  [thumbsup]
You got a multi? Nice!
