February 23, 2025, 10:09:41 PM
2v SBK build thread
5
6
7
Topic: 2v SBK build thread (Read 34699 times)
loves ze desmodromics.
Re: 2v SBK build thread
Reply #75 on:
June 11, 2011, 12:50:00 PM »
999RS uses removable / bolt-in frame members. Allows a head to be removed easily without dropping the motor, etc. That thing makes gobs and gobs and gobs and gobs of torque.
TAftonomos
is without a monster :(
Reply #76 on:
September 20, 2012, 05:42:54 PM »
Bumpage
Bike is a complete roller now. Problem I'm running into is making a decision on how to make it run. I can't fit the hyper TB's without chopping the frame crossmember....which I'd rather avoid. I'm not sure what to do about the ignition if I go with FCR's either.
I'm at a cross roads....it's time to either finish this thing or break it down and sell it piece by piece. A lightweight 749R chassis sure seems like it would be a ton of fun...
MyDucParts.com
xsephirot
Reply #77 on:
September 20, 2012, 06:00:21 PM »
Quote from: TAftonomos on September 20, 2012, 05:42:54 PM
Bumpage
finish it! It's been 2 years+. You can do it, be a man. haha.
graydo
Reply #78 on:
September 20, 2012, 07:07:37 PM »
Any new pictures of it with the engine in?
The Mad King Pepe'
Chop it like it's hot!
Reply #79 on:
September 21, 2012, 10:31:44 AM »
Chopped the cross member on my 748/916 frame.
And replaced it with a diagonal rod (black/grey under the intakes).
If you're really concerned about frame stiffness, you could weld another rod. As far as I can tell, there's no need.
Reply #80 on:
September 21, 2012, 11:16:04 AM »
nice. i will save these pitchers to refer to later
Reply #81 on:
September 21, 2012, 11:34:17 AM »
I keep thinking that i'd like to see someone adapt the sbk TBs instead of cutting the frame for the 2v TBs
The Mad King Pepe'
Reply #82 on:
September 21, 2012, 12:09:04 PM »
Quote from: junior varsity on September 21, 2012, 11:16:04 AM
Almost all my photos are here:
http://codeherrings.com/images/moto/ducati/speciale/
There's other stuff if you want to look around, just watch for the hidden pr0n folder...
Quote from: Raux on September 21, 2012, 11:34:17 AM
If the injectors have the same specs it's doable (as far as I understand). If they don't, you would need to re-calculate a bunch of parameters and re-program the ECU accordingly. Cut & weld seems so much easier.
Reply #83 on:
September 21, 2012, 12:25:44 PM »
Quote from: The Mad King Pepe' on September 21, 2012, 12:09:04 PM
i have 999 shower injectors to try with
zooom
Reply #84 on:
September 21, 2012, 12:28:18 PM »
I couldn't find the hidden pr0n folder....it is labeled Regina De Cuori or something like that?
2010 KTM 990 SM-T
TAftonomos
Reply #85 on:
September 21, 2012, 01:21:02 PM »
Well, there is no going back. Before we left Moscow I dispatched a letter to.... oh crap.
No seriously, the frame is cut now. TB's are in. I also made some decent progress. Calipers are bolted up (radial brembos), rotors are bolted up (iron braketech). Fender is on (forgot the 999 mounts before everything else goes on ...DOH!).
I also got the rear brake master, rear sets, clip ons, and shifter worked out. Gonna have to order one 90deg fitting for the brake lines to work at the front master, and also figure out WTF I'm supposed to do to route the rear brakeline for the underslung caliper....
All in all, I've made more progress on the bike today than in the past year. I'm excited, and moving forward hopefully this week I can have a good idea of the wiring/routing and where I'm going to put the ECU, battery, blah blah.
MyDucParts.com
Reply #86 on:
September 21, 2012, 01:48:32 PM »
zzzzzzipties.
Reply #87 on:
September 21, 2012, 01:49:23 PM »
The Mad King Pepe'
Reply #88 on:
September 21, 2012, 02:23:17 PM »
Quote from: TAftonomos on September 21, 2012, 01:21:02 PM
Get a small LiFePO battery (Shorai, Ballistic,...). It'll make your life much easier!
On the 916 it's up from the master, between the fender and the shock (or in front of the shock if you don't have a fender), on top of the chain cover, then down to the caliper right before the sprocket.
Reply #89 on:
September 21, 2012, 02:46:43 PM »
No battery. No Starter. Get race starter.
5
6
7
