February 06, 2025, 04:25:08 AM
Who Does Corse Cuts On Clutch Side Cases?
Topic: Who Does Corse Cuts On Clutch Side Cases? (Read 4106 times)
RAT900
April 30, 2010, 11:47:21 AM »
I have a spare right side cover that could use the ventilating cuts machined around the clutch basket area
Anyone know of a board member/sponsor/vendor etc who does this work?
Looking for a good clean professional job with radius'd corners etc
as opposed to my wrecking it with my madd skillz using a sawzall and a dremel
Düb Lüv
ASE master internet mechanic
Re: Who Does Corse Cuts On Clutch Side Cases?
April 30, 2010, 02:32:44 PM »
+1
Building, building, building
ducrider45
Just Ride!
April 30, 2010, 03:41:59 PM »
Sawzall that bad boy!
Thomas Jefferson
April 30, 2010, 03:51:53 PM »
Quote from: ducrider45 on April 30, 2010, 03:41:59 PM
Get a drill press, turn that bad boy on, and feed the case cover into it!!!
April 30, 2010, 03:54:26 PM »
How do you want it to look?
1KDS
April 30, 2010, 04:24:24 PM »
Like Travman's?
Every bike I've ever owned.
April 30, 2010, 04:42:11 PM »
That was done at DucPond for about $75.
http://www.ducpond.com/contact.html
I think it would be cool to see a right side cover that was simply drilled something like this S&S air cleaner cover. Then you could match a similarly drilled clutch cover.
Düb Lüv
April 30, 2010, 04:50:01 PM »
i knew i remembered seeing a place that machines covers.
here it is $75
http://www.foxperformanceengines.com/clutch.html
crimsoncloak
April 30, 2010, 05:00:17 PM »
I have a nice vintage one on ebay from my 1997 748, I dunno if they interchange. Radiused nicely. I basically copied the corse mag cover cut pattern. If you need better pics of how it is cut so you can have someone local get it looking nice I can send you some if you pm me your email.
I see alot of them on ebay, but very few of them are done in a way that flows with the lines correctly. Take a look at the accesory magnesium cover one of the Ducati dealer's websites if you are curious.
I.E.
http://www.desmoworks.com/images/0863.CARTFRIM.jpg
Feral 859
April 30, 2010, 06:12:33 PM »
This one was done at the Ducshop.
RAT900
April 30, 2010, 06:42:20 PM »
Yup the one right above and the one 1KDS's post is what I had in mind
Thanks guys I will check out DucPond and Ducshop
loves ze desmodromics.
May 01, 2010, 09:46:31 AM »
Fox Performance does this i believe, as well as an eBayer.
TAftonomos
is without a monster :(
May 02, 2010, 03:08:30 PM »
Fox and ducpond will do it for $75
Ducshop will charge you $140, and take it next door and have it machined.
My experience/.02
I've used both, guess who I use now?
MyDucParts.com
Düb Lüv
May 02, 2010, 05:57:01 PM »
Quote from: TAftonomos on May 02, 2010, 03:08:30 PM
My experience/.02
eichh
Reply #14 on:
May 04, 2010, 01:04:02 AM »
Didnt a member buy a CNC machine for their house?
