February 06, 2025, 06:48:14 AM *
Pages: [1] 2 3   Go Down
Author Topic: Other Steering Damper Options...  (Read 7711 times)
DarkStaR
« on: May 09, 2010, 05:28:07 PM »
Ok, after looking at everyone else's dampers for the last 5 or so years, maybe I'll start looking in to getting one.
Now here's what I have to work with:
1) Don't like side mounted ones.
2) I have Clip-ons, and don't want to use or have the stock risers...so most top mounted kits are a no go.
I like the below the triple kit Motowheels has for the older bikes, but don't think it will fit an 02+.
I also wouldn't mind one of those rotary dampers, but can't find that either.
I guess I can try to copy Monstermash's set up, but...
Are there any other options out there?
2005 S2R
« Reply #1 on: May 09, 2010, 05:55:59 PM »
if you want a top mount you need to connect it to the triple. no questions asked. How you go about doing that is up to you.
Scotts makes one for the Monster up to 02. Not sure waht changed.
Scotts also makes one for the hyper which i think is quite similar. but not sure if it will fit.
Sidemount seems like your only option. The only reason i wouldnt go for it, is because i dont want it to break if i crash. Thats why i like top mount. undermount is pretty sweet to if you can get the parts. maybe its time to machine some stuff?
Novelo
« Reply #2 on: May 10, 2010, 03:42:42 AM »
I was in the same situation that you are in sadly I never came up with a solution. The rotary kits are different for the Hyper and the Monster. The Hyper uses a bar mount system that comes with the kit which is different from the style that the Monsters uses. You would have to drill holes in your top triple to use it take a look at their install pages to see exactly what I mean. Plus there is a height difference in where the key hole is higher on the Monsters than the Hypers. You would need to have a custom made link arm and mounting system to use that style of stabilizer. I think He Man's style with the Ohlins under mount fit my bill the best for what I was looking for. I can't stand for the thing sitting up top because like you I have clip ons and there is no other use for the stock risers. So till I find a better solution to what I want I have this silly contraption sitting up top might even go without it.
« Reply #3 on: May 10, 2010, 05:25:36 AM »
if you were going custom design, maybe you could still use top mount. It would look 10x nicer if you moved the damper foward over the triple instead of between the triple and ignition. THis would allow it to lay lower and more out of the way.
really i think i might end up doing that now that i know how everything works. it really sticks out like a sore thumb. Sad
OR, i think i could get the scotts for the older monsters to fit with easier parts.
loves ze desmodromics.
« Reply #4 on: May 10, 2010, 09:13:55 AM »
In 02 the steering stem sized changed as well as the triple clamp's offset. (it went with the frame change from 851/888 based to ST based). The 're-02 monsters also came from the factory with tapered roller bearings in the headstock, while the 02+ models just came with the roller bearings
« Reply #5 on: May 10, 2010, 09:37:57 AM »
how about the location for the key? if that disance from the triple remains the same  then all youd need is the proper place to tap some threads on the triple.
corey
'06 Tang/Black S2R800
« Reply #6 on: May 10, 2010, 10:12:52 AM »
just run bunjie cords from your barends to your frame gussets.
Alexandre
Monstro
« Reply #7 on: May 10, 2010, 12:29:45 PM »
this may be helpful to look at:
http://ducatimonsterforum.org/index.php?topic=7727
DarkStaR
« Reply #8 on: May 10, 2010, 03:33:31 PM »
I've actually looked at that many times, and unfortunately those are all side mount, top mount with stock triple, or an under triple that doesn't fit.   Undecided
and, TOB sucks.
« Reply #9 on: May 10, 2010, 03:34:34 PM »
Why won't an under triple mount work? How much larger is the crossmember of your frame at that spot? or is there something else there?
If you don't want a sidemount or a top mount... why is it that you want a damper again? For looks or for function? You may need to figure that out.
Just kind of seems that you are finding reasons not to put a damper on for aesthetic reasons, when the part is for function, not for looks.
« Last Edit: May 10, 2010, 03:36:39 PM by a m » Logged
DarkStaR
« Reply #10 on: May 10, 2010, 03:40:04 PM »
@a m:  Do you have the MW under triple kit?
I'm wondering the same thing.  Motowheels states that the kit is pre-'02.
http://www.motowheels.com
Anybody know?
« Last Edit: May 10, 2010, 03:43:41 PM by DarkStaR » Logged
« Reply #11 on: May 10, 2010, 03:41:55 PM »
It is shaped like that because it goes around the regulator, which is right there on those era bikes (I have this damper mount).
I do not have a newer 2v Monster to compare with for frame diameter. I do know they have a silly deflector thing coming off the lower triple that you'd likely have to remove.
DarkStaR
« Reply #12 on: May 10, 2010, 03:47:04 PM »
@a m : Do you think you can do me a big favor and maybe take a pic of the underside where the damper mounts?
I'll compare it to mine, and take some measurements.
I think an under triple will be the most feasible for what I'm looking for.
« Reply #13 on: May 10, 2010, 03:51:06 PM »
oh no! i guess i have to go into the garage again... [Cheesy]
mendoje
« Reply #14 on: May 11, 2010, 09:18:02 PM »
The immobilizers kicked in starting 2002.  If you look at the Scotts damper installation for the 99-01 Monster, they provide a completely machined aluminum ignition key housing which supports the pin that engages the damper arm.  For Monsters '02-on, the key chip sensor antenna is built into the housing, so a Scotts billet aluminum housing wont work.  The Scotts damper also has to be mounted in-line with the steering head axis, and there is extremely little room between the steering head axis and the key housing on a Monster to locate and support a pin.
However I just picked up a Scotts damper cheap, as I want to go this route on my '03 Monster.  I recently went to clip-ons, but stayed with the stock upper triple for now.  I figure I can use the former bar mounts as a base to install a damper, either linear or rotary, and keep it lower profile than what's currently out there.  It's going to take some custom machining & fab work, but I can see a few ways to do it.  Dont hold your breath, it's gonna take a while, but I'll post when I get something going.
Another possibility though, I've been following posts where others are reflashing ECU's which also disables the immobilizer.  If so, I assume then the stock key housing and it's key chip antenna are no longer needed, so the Scott's damper with its aluminum key housing for 99-01 might work.
Jeff
2003 M800Sie / 2004 BMW R1100S / 1981 BMW R100RS (Sold) / 1977 Kawasaki KE100 (1st Bike Smiley)
http://ducatimonsterforum.org/index.php?topic=27788.0
Pages: [1] 2 3   Go Up
