CNC Machining
Started by Some Dude, May 22, 2010, 01:38:46 PM
Some Dude
Hi I recently purchased a Haas cnc mill for my garage. I have access to a lathe as well.  If you have an idea or want some kind of custom part send me a PM and I will see what I can do.  I will be posting up pics of some parts I have already built pretty soon.  I have 15 years machining experience so this is not something I am just trying to figure out or play around with.
Thanks
For looking
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
[bacon]        [bacon]        [
It maybe nice to may post a per/hr example with examples of how long something took. God knows the last thing you need is a inbox exploding full of PMs.  ;D
Some Dude
Quote from: He Man on May 22, 2010, 05:01:23 PM
Good Point.
Here is a set of Parts to do a GSXR Fork Swap.
  Took me about 4 to 5 hours charged $150
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
[bacon]        [bacon]        [
DarkStaR
Master cylinder spacers please!
desmoworks
I'm getting ready to start a new project bike and need some parts machined. Where are you located?
Anthony Creek
Pro Italia Online || mota-lab
Some Dude
Quote from: desmoworks on July 20, 2010, 08:40:54 PM
I am located in utah.  What kind of project are you starting?
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
[bacon]        [bacon]        [
Some Dude
Quote from: DarkStaR on July 20, 2010, 06:09:03 PM
I could build some of those would there be much interest form other people?  The more I can build the lower the price will be.
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
[bacon]        [bacon]        [
desmoworks
Quote from: Some Dude on July 21, 2010, 03:17:28 PM
Doing a custom Moto Guzzi V7. Was hoping you were around LA. I need triples with bar riser, foot pegs and a couple of other brackets to be machined.
Anthony Creek
Some Dude
Quote from: desmoworks on July 21, 2010, 03:21:56 PM
Sounds like a fun project.  If you can draw what you need I should still be able to build it.  Let me know if you need anything & good luck.
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
[bacon]        [bacon]        [
The Bearded Duc
Some Dude: Are you able to machine a top triple for older monsters('01 M750)? I'm looking for forks so I'm not sure if I'm gonna end up doing a 50mm bore or a 53mm bore for the forks but I figured I'd ask first.
2001 M750 - Sold
Some Dude
Quote from: Carbon 14 on July 27, 2010, 11:21:52 PM
How about some heelguards for the stock setups.  Mine look terrible & don't keep my right heel off the pipes.  Almost all other makes have some badass looking guards.
It's possible. which model bike do you have? Can you give me an example of what your thinking?
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
[bacon]        [bacon]        [
Some Dude
Quote from: duc750 on July 27, 2010, 11:51:14 PM
I can do it.
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
[bacon]        [bacon]        [
The Bearded Duc
Quote from: Some Dude on July 28, 2010, 04:11:08 AM
I can do it.
About how much would that run me? Would there be a difference in price for the different bore?
2001 M750 - Sold
El Matador
If I send you a CAD drawing would you be able to make it happen? I've got some rearsets I've designed that I would like to have machined.
suzyj
Quote from: Some Dude on July 21, 2010, 03:20:09 PM
Yes please!
