696 rebuild - on the road & stage 2
Started by Raux, June 09, 2010, 11:34:34 AM
ahhhhahhhhhahahah
PC V arrived today  ;D
just got it on the road and I'm ready to take it off and do the motor  [bang]
had some clutch slippage today.
thinking I need to check the freeplay on the clutch lever? Noticed there is none...
opinions.
Good place to start.  1 - 1.5 mm.
Quote from: Raux on August 31, 2010, 08:12:05 AM
opinions.
Screw + lever part # 4 on page 62, US 696 parts catalogue (2009) [thumbsup]
So, I assume that's a yes for your bike as well.
I'm running older Brembo goldline masters. i can't see how they adjust
DarkStaR
#170
Quote from: Raux on August 31, 2010, 07:34:32 PM
If they are small pivot goldline masters, this is what you are looking for to adjust (clutch side looks a bit different due to switch):
I've heard people struggling with the set screw - it's often tight and/or loctite'd.
You might need to heat it - IIRC.
Quote from: stopintime on September 01, 2010, 12:52:36 PM
k
will probably try to tackle it saturday morning
dbran1949
Be very careful I still have the end of the allen key stuck in the set screw on my clutch lever
hcomp
Holy BuhJeezus Wow Raux! I go away for 2 weeks and you finished a masterpiece! Awesome work and the bike looks super badass!
にã,,かかã,ã,‰ãšã€ç§ã®è»Šã¯æœ¬å½"に速ã,,ドラã,¤ãƒ–、私は女性のç"Ÿæ®–器のã,ˆã†ãªãƒã,¤ã,¯ã«ä¹—ã,‹
Quote from: ryanracer on September 02, 2010, 07:53:52 PM
what the hell are you taking 2 weeks off for ;)
thanks, Ryan.
now looking at the pics, wish i was able to accomplish more of the changes I wanted. Sometimes I think it isn't changed enough to be considered custom
 [roll] I told you to put that Volkswagen Beetle rear-end on it, but you wouldnt listen... "too radical" you said.... so now look at you.....  [roll] [laugh]
Veloce-Fino
The people who "matter" will know how custom it is.
Is this thing on?
phew spent some hours on the bike today.
wrote a small report in the riding tech. threads.
I think I need to change some things and add others.
The zero rise bars are great... but a lot of work. It makes a great weekend bike but not such a great commuter. Gonna have to decide what I want from this bike, cause in this config, it definitely is not an all around bike.
IF I keep the zero rise, I need a damper. It turns SO easily. I don't want to change my suspension and lighten the front, but the steering angle is steep and I want to be careful of headshake.
IF I come up a couple of inches, I can forget modding further toward the 848 cause I doubt I'll have room for a rise. But it will make the bike easier for commuting.
The exhaust need to be fixed soon. The stock just aren't cutting it.
I finally fixed the lights, now have low and high beam instead of just high and high+low.
Painted a few more bits and pieces as well. I didn't like the look of the silver front sprocket cover, so that's black now. and a few brackets that I had made are black after being raw until I had some black paint.
PC V is next. Suppose I'll need the autotune unless I can source a shop with a Dyno and willing to let me use it for free ;)
