January 15, 2025, 02:00:41 PM *
News: Please Help
Pages: 1 ... 12 13 [14] 15 16 ... 24   Go Down
Author Topic: 696 rebuild - on the road & stage 2  (Read 110818 times)
DucatiTorrey
My wife's super hero is my
Industrial Designer
« Reply #195 on: September 21, 2010, 08:30:29 AM »
so, anyone know if a speedymooto top triple and stock lower triple with fit the 1098 forks? do i need a new axle? what about breaks?
  - real place
« Reply #196 on: September 21, 2010, 08:40:20 AM »
1098 (plain jane 1098 not the Ohlins) forks are 53/53mm so you'll need the 53mm SM triple and spacer for the lowers (.5mm thick sleeve basically) I think motowheels sells them.
If you get Ohlins 1098S forks, forget the stock lower, but enough material from what I heard to go out the required 56mm but maybe someone has done it.
Axle.. 1098 axle and bolt with (1) 1098 spacer and (1) monster spacer worked for me perfectly.
Brakes... with stock wheel, you'll need 15mm offset 6-bolt rotor or 5mm spacers between stock brakes and wheel (I went with 15mm offset Braking rotors)
Your stock calipers will work
DucatiTorrey
Industrial Designer
« Reply #197 on: September 21, 2010, 09:57:20 AM »
perfect thanks man, i was considering a new bike, more power etc for tw up riding, but i think a stiffer rear spring, 1100 rise in the back and this 1098 set up with be perfect, and little more ajustability and higher seat will be nice for the two of us
  - real place
« Reply #198 on: September 21, 2010, 10:15:03 AM »
i haven't ridden two up, but yeah the bike is taller for sure
and forks are awesome
but need to set up some time with a suspension expert to set preload/damping/rebound
DucatiTorrey
Industrial Designer
« Reply #199 on: September 21, 2010, 11:04:33 AM »
absolutely, that is key
  - real place
dennisd
« Reply #200 on: September 24, 2010, 05:24:56 AM »
Hey, calling Raux.
I've been wanting to paint the lettering on my calipers also.  I was going to do a light sanding with a sanding block so only the ends of the letters are sanded and then use a small artist brush to put Urethane on the very ends.  Is that how you did it or did you find a better method?
« Reply #201 on: September 24, 2010, 09:26:14 AM »
I used car touch up paint and a steady hand
dennisd
« Reply #202 on: September 24, 2010, 10:33:28 AM »
OK thanks.  I have some of the Dupli-Color paint in Duc red left over from when I painted my headlight trim and sprocket carrier.  It's a perfect match. waytogo
My only problem is I'm 54 years old and a steady hand was about 25 years ago. laughingdp
« Reply #203 on: September 24, 2010, 10:46:14 AM »
take the calipers off, put them on a stool and have your wife do it.. bet she paints her nails all the time.
just make sure to clean them well so there's no grease, dirt or brake fluid
« Reply #204 on: September 25, 2010, 08:56:25 AM »
well I've put enough miles on it for things to start vibrating loose. Kickstand front bolt was loose. Noticed it at the gas station and rode home, put it on the rear stand to tighten... one more ride and it would have been gone...
time to check every bolt again. Need to buy a torque wrench.
DarkStaR
« Reply #205 on: September 26, 2010, 06:44:18 PM »
...and you need to update your sig line also.  Tongue
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
« Reply #206 on: September 26, 2010, 07:06:24 PM »
Agreed, it's been bothering me.
Is this thing on?
« Reply #207 on: September 26, 2010, 07:08:41 PM »
better? I'm sure there are things I've forgotten on the specs, sorry
« Reply #208 on: October 04, 2010, 11:20:53 AM »
 bang head Aluminum is not a very good material for a dash mount.
Mounting tabs broke at 100mph today.
need to remake a template and get it done in steel.
S2R 800 '07
« Reply #209 on: October 04, 2010, 12:21:18 PM »
From wind pressure alone?  Shocked
Pages: 1 ... 12 13 [14] 15 16 ... 24   Go Up
