August 19, 2024, 07:28:49 AM
CAM
What did you do today?
106
107
108
109
201
Topic: What did you do today? (Read 320119 times)
TitanMonsterS4R
Re: What did you do today?
Reply #1590 on:
October 09, 2011, 04:41:01 PM »
Took her out for her first long ride with a buddy up River Road to Poolesville. Saw lotsa Monsters out and about including a red/white striped S*R on River Road.
Love everything about the way the SBK swap has changed the way the bike tracks, corners and handles. Just need to get the front end and fork dialed in for this machine and we're all good. Might give MSP (is that the place you got your bike suspension worked on Jim and Ben?)
Artful
I'm glad they make pills for my
Reply #1591 on:
October 09, 2011, 05:33:39 PM »
MRP.
The Mad King Pepe'
Reply #1592 on:
October 09, 2011, 05:51:24 PM »
Quote from: zooom on October 09, 2011, 01:20:02 PM
I say....nice ole MK3 Golf....
'94 with California emissions, over 140.000 miles now, got me to college, back and forth to Chicago and Louisville a few times, and all the way up to Toronto via Philly, NY, Boston and Niagara Falls.
Moderator
Reply #1593 on:
October 09, 2011, 05:58:31 PM »
Quote from: The Mad King Pepe' on October 09, 2011, 05:51:24 PM
My MkIV has about 125K on it. Poor thing is starting to make some funny noises...
Omnipotent Potentate
Personal Pretext
Reply #1594 on:
October 10, 2011, 04:42:08 AM »
Work work work... well I am at work today - but I'm talking about yesterday.
Replaced the clutch on the 900
Had to cut out a leaking water shut off for my washer and break out the torch a solder a new one on.
Fit a new door, in a normal frame
Fit a new door, in a not so normal frame. So I'm not sure how they managed to do it, but the folks who made the frame to a door in my basement that should have been 36" made it 35 3/4" in middle and 35 5/8" at the top and bottom. So what should have been a pretty fast job with a router and a couple hand chisels turned into an adventure with a circular saw, power sander, many test fittings and a shit ton of time.
Isn't be a homeowner grand
zooom
Reply #1595 on:
October 10, 2011, 04:58:50 AM »
Quote from: Sad Panda on October 10, 2011, 04:42:08 AM
is this with your old house, or the perspective new one?....been offline for a couple days...so pardon my ignorance....
2010 KTM 990 SM-T
Personal Pretext
Reply #1596 on:
October 10, 2011, 05:07:48 AM »
my current - soon to be former house. Knocking off the home inspection stuff. I had kitty doors they the buy wanted replaced.
The shut off for the clothes washer must have had a hairline crack in it because no matter what I had tried it would just weep a tiny bit of water. New seal at the joint, Teflon tape, sealant goop, saying nasty things to it... nothing would keep it from leaking just a tiny bit - like a drop of water every few hours.
So after much wasted time and many attempts to getting it to seal I said 'make the beast with two backsit, you're off!' and out came the pipe cutter and torch. After 1 failed try due to not enough heat I got a nice pretty joint on and it's done.
I gotta say, my joint is a lot nicer than the 'professional' ones I can see. Maybe I'm in the wrong trade.
Artful
Reply #1597 on:
October 10, 2011, 07:21:37 AM »
That's the secret to sweating copper. When you think it's hot enough, torch it more. When the flame turns green, solder and set.
Personal Pretext
Reply #1598 on:
October 10, 2011, 07:33:49 AM »
Quote from: Artful on October 10, 2011, 07:21:37 AM
Catch there was I was being good and wearing eye protection - when yellow lenses.... so the flame was always green
Artful
Reply #1599 on:
October 10, 2011, 07:55:56 AM »
I wear glasses every day, if I wasn't wearing them I'd have burnt the house down
Yellow safety glasses? Were you sweating pipe then going out to shoot some clays?
zooom
Reply #1600 on:
October 10, 2011, 08:44:57 AM »
Quote from: Artful on October 10, 2011, 07:55:56 AM
who said he had to leave the house to do that?!?!?!
2010 KTM 990 SM-T
Personal Pretext
Reply #1601 on:
October 10, 2011, 09:19:06 AM »
Quote from: zooom on October 10, 2011, 08:44:57 AM
I am moving out after all..
Moderator
Reply #1602 on:
October 10, 2011, 12:39:57 PM »
Took the SC out for a quick flog on some of the "local" roads, then went by Colemans to start the process of replacing yet another tank. While there, noticed that I had picked up a nail in the rear tire. The guy asked me if I had been up/down Joplin road, which I had. Apparently someone has taken to distributing nails along the road over the last week or so...
zooom
Reply #1603 on:
October 10, 2011, 12:42:26 PM »
see Ted's picked up a nail and needs plugging thread in Tech for my suggestion....
2010 KTM 990 SM-T
Moderator
Reply #1604 on:
October 10, 2011, 12:45:42 PM »
Quote from: zooom on October 10, 2011, 12:42:26 PM
Not the "is it safe to ride on this tire" thread?
106
107
108
109
201
