Fixing a toilet
Started by Monsterlover, June 16, 2010, 05:50:12 PM
One of our toilets leaks water past the flapper valve so it periodically has to refill the tank on it's own.
I put in a new flapper and the leak has not stopped.
What should I do next.
Never had to troubleshoot one of these before.
the long  tube that runs up from the bottom of the tank may need to me replaced or tightened, water may be leaking past it
WarrenJ
When I was a tyke, we had a 3 holer outside - never had any problems flushing!
1KDS
like bp said. also check the chain length, make sure there is slop
Every bike I've ever owned.
Quote from: WarrenJ on June 16, 2010, 05:58:56 PM
you shit in a bowling ball?
If you manually push the flapper down does it form a good seal?  Or does it still leak?
All good points.
Will check the flapper and tube thing tomorrow and report back.
Also - all flappers are not made equal!  I have found the $10 ones superior to the $4 ones.  The cheaper ones also do not last as long.
For a small leak, put some food dye in the tank so you can detect it easier.
z0mb1e_DUC
also make sure there isn't anything built up on the edge of the flapper.  You often get scale on the flapper & the tube it seals.  That will allow water to get past.  Somegirls's dye suggestion would be the easiest way to tell.
'09 m696 Dark
Pip
DM&TF
Ducati Monster and TOILET Forum.
Where shit goes down.   ;D
cyrus buelton
Replace it.
I spent so much money on make the beast with two backsing flapper kits and flusher valves and whatever else goes in there.
Long story short........toilet was built in 1980 and they don't make the proper size replacement parts.
1999 M750 (joint ownership)
2004 S4r (mineeee)
Quote from: cyrus buelton on June 17, 2010, 04:15:38 AM
Replace it.
how much did your neighbor charge you for that advice?
zooom
Quote from: bobspapa on June 17, 2010, 05:00:00 AM
some shitty amount that he pissed away...
2010 KTM 990 SM-T
Pip
Quote from: zooom on June 17, 2010, 05:06:38 AM
Yeah. He probably made a big flap about it, then old him to scat.
