GUN STUFF
Started by fastwin, June 26, 2010, 11:24:07 AM
It is plastic. You think just a primer would launch it?
That one I pressed in went in stiff but I was able to seat and crimp with my 1.100 oal that I run.
WarrenJ
If you can get to your OAL, you should be good.  Trim back a couple bullets so they chamber and prime up a couple cases and give it a try.  Just use a brass rod and tap them out if
they don't make it.  What some guys do, is enlarge the flash hole in the case when using plastic bullets, just remember to segregate the cases so they don't get mixed in with your regular stuff.
With the bullets being that long, I'm not sure they will stabilize, but Hey!  Proof is by Test!!
These experiments will need to be filmed.
For science.
Quote from: Buckethead on March 28, 2013, 08:14:52 PM
For science.
tempting
It is plastic.  It can be cut down to size.
Happy Easter, Peeps... [evil]
That...
was...
glorious.  [thumbsup]
WarrenJ
That really illustrates what a fragile thing bullet stability is.
Quote from: WarrenJ on March 31, 2013, 12:16:49 PM
This
Dense vs sparse.
Do the same thing with ballistic gel, despite the heavier target medium, the projectile will remain mostly on the same trajectory (mostly) since the resistance of the medium is equal-more or less- on all sides.
The very light deflection given by the first few peeps is enough to change the projectile's trajectory without an appreciable change in speed.
But you all knew that...  :-)
Kopfjäger
Anyone shooting a Horus reticle?
Zaster
Quote from: kopfjäger on March 31, 2013, 08:26:55 PM
Do tell, I was just planning on getting a bdc reticle in a 4X16 for my 7mm Rem Mag.
Kopfjäger
I'll let the Man himself explain. This is the shit, period. We run these on all are guns.
Zaster
Damn that's slick [thumbsup]
What scopes are available with this?
