GUN STUFF
Started by fastwin, June 26, 2010, 11:24:07 AM
The Architect
Quote from: ducatiz on October 23, 2015, 06:19:13 PM
MidSouth Shooter's has TulAmmo .223 for about 22c/round if you buy in bulk.  Shipping is very reasonable too -- even with the overweight charge for 80lbs .
http://www.midsouthshooterssupply.com/item/00112TA223550/point223-Remington-55-Grain-Full-Metal-Jacket-20-Rounds-
55g/FMJ .. good range stuff.  I've been using it in my Valmets and ARs and both like it a lot.
That place has some good pricing!  .38 for $13.63 per box.
http://www.midsouthshooterssupply.com/item/0003938A/38-Special-158-Grain-Lead-Round-Nose-50-Rounds
Kopfjager
Make sure you can hit what your aiming at under duress inside your house.
GK
Kopf, why were they shooting in the direction of vehicles?
2001 Ducati  Monster 900S ie
Gone but not forgotten!
Kopfjager
Quote from: GK on October 28, 2015, 03:05:24 AM
Not my range, but I'm sure those cars are there to be shot at/from etc.
GK
I figured something like that, but from my tiny iPhone 4s screen (and late at night) they didn't look beat up on! Best to ask! ðŸ'ðŸ»
Kopfjager
Frank explaining his new rear sight. I'm running these on my Glocks and my STI.
The Architect
After a slight case of paralysis by analysis, I finally made a decision.
20151029_204907 by anzalone22, on Flickr
I choose the Ruger GP100 over the SW 686.
Going to the range tomorrow.
Kopfjager
What he said.
Nice iron.
Quote from: The Architect on October 29, 2015, 06:54:16 PM
You're such a Ruger fanboi... :-*
The Architect
Zaster
I'm very happy with mine.
Didn't like the front sight and had to change it out for a HIVIZ sight.
Quote from: The Architect on October 24, 2015, 05:58:47 AM
I don't know about the steel case. The last time I used it in my ar a shell got stuck.  The heat melts the coating and if you leave a round in the chamber for more than a minute it gets stuck.  :-\
I tested that hypothesis a while back on a bet -- emptied a round, removed the primer and then used a torch on the unfired case.
No melting.  Nothing.  Case was glowing red.  Nothing came off when I scraped it.
I did find that SOME 5.56 cut chambers will stick but only if they are dirty.  Slight differences in the 5.56 and .223 cut (5.56 is slightly larger and using .223 spec ammo allows for some crap to remain)..
My wife has one of those, we both like it.
JM
The Architect
Quote from: ducatiz on October 30, 2015, 07:54:33 AM
I'm going to have to reconsider the steel case but in .223.
Thanks for the info.
