February 18, 2025, 05:07:16 PM
So, are you an idiot like me?
Topic: So, are you an idiot like me? (Read 6430 times)
seevtsaab
05 M620
July 06, 2010, 10:57:16 AM »
As in, you have all your shit laid out just so, well,
just
the stuff you need 'cause you're so damn
smart
, doing your valves, and make the beast with two backsing sanding on your
Shim Measuring Tool
(Wow that closer STILL binds a little? Huh!)
Ok so I only wasted a few minutes at it, and as slow as progress is sanding I didn't do any real harm.
But damn, you kinda like to have your head straight doing this stuff?
I'm sure I've done worse.
So what's something totally stupid you've caught yourself doing?
Omnipotent Potentate
Personal Pretext
Re: So, are you an idiot like me?
July 06, 2010, 11:02:33 AM »
Mine usually involves hunting around for some tool I just had, for ages - when I was super bright and stuck it in a pocket to keep it handy.
Goat_Herder
July 06, 2010, 11:36:54 AM »
Quote from: yuu on July 06, 2010, 11:02:33 AM
+1 I usually would put all tools in one place and line up all bolts/screws in another area. But while I am working on something, I would think ahead of myself by placing this one tool at where I will need it in the next step. Like it would save me 3 seconds. But then I would forget about that move. Minutes later, I go back to the tool area and can't find shit...
I am an idiot
Goat Herder (Tony)
2003 Ducati Monster 620 - Yellow
SOLD
2007 Ducati Monster S2R1000 - Black
KILLED
RetroSBK
July 06, 2010, 01:34:07 PM »
my list is long and storied... lol
Actually my big one is that I continually buy the same consumables over and over.. We do a lot of welding and fab work, and a lot of grinding and smoothing. (I prefer no welds to a row of nickels)
10,000 things going on all the time, and I go to Grainger 3 times, and buy the same damn grit sanding disk or Scotchbrite disk...
Arghhh
Will Kenefick's Retro Superbike. Bringing you the sickest Sh*t since '94
Rob Hilding
July 06, 2010, 01:37:33 PM »
Too many to list here - that is for sure--
But this seems like an appropriate thread to see the chain made around the ladder rungs
Does somebody have the pic?
Turf
Awesome > Logic
July 06, 2010, 02:01:03 PM »
taking stock rearsets off bike at work
remove side stand bolt and have bike fall on me
not my best day
but pretty funny
SacDuc
WWSDD?
July 06, 2010, 03:59:32 PM »
sac
HATERS GONNA HATE.
BMiller
Rattle Rattle Rattle
July 06, 2010, 04:08:10 PM »
I've been beat down by a drill that ran away while drilling out a Honda 919 frame for sliders
But yeah, I usually do the "where is that tool" thing as well.....it's always right infront of you when you give up
2003 Ducati 748S
rockaduc
July 06, 2010, 11:05:26 PM »
Quote from: SacDuc on July 06, 2010, 03:59:32 PM
+1, me too.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
I am Sofa King
idiot sans savant.
July 07, 2010, 03:58:57 AM »
me three
So I went solo. -Me
DrDesmo
July 07, 2010, 04:32:05 AM »
... At least you're not this guy
http://www.advrider.com/forums/showthread.php?t=595717
'95 916
'12 800XC
redial
July 07, 2010, 04:39:04 AM »
yes i am an idiot.
first time i did my valves i measured an entire cylinder on the WRONG STROKE.
proceeded to sand the shims until they were double the needed gap and had to buy whole
new shims after i thought the whole adjustment was going to cost me $5 in sandpaper
awesome.
arai_speed
July 07, 2010, 06:59:54 AM »
I had the problem of putting things back together to "test fit" w/out torquing down all the bolts....only to forget that things were not torqued to spec and assembling the whole shabang!
DucHead
No garage queens
July 07, 2010, 09:29:10 AM »
Recently hand tightened most of the 14 bolts on the Bandit valve cover only to discover it was on backwards.
"45"
Rameses
*Your Mom* has a Hypermotard
Reply #14 on:
July 07, 2010, 10:53:07 AM »
Quote from: pompetta on July 07, 2010, 09:29:10 AM
What's that about a rear brake caliper??
