February 06, 2025, 04:17:02 PM *
Pages: [1] 2   Go Down
Author Topic: Fiamm Freeway Blaster Horn - Low tone 72112  (Read 9241 times)
theprocess
'09 M696
« on: July 19, 2010, 04:05:25 AM »
Installed one of these today in my 696.  Single horn (5A), low tone.  No relay.  Stock horn harness connectors clipped right on.  Needed to relocate the bracket to the empty oil cooler space but it fits under the cover/cowl fine.  Sorry, I forgot to take pics during the install but its really very easy.
A lot louder than the stock horn and nice low tone.  No more "meep meep".
ducamonsta
Ducamonsta
« Reply #1 on: July 19, 2010, 09:35:22 AM »
how much did you pay? where?
05 DUCA S2R800 yellow stock! ASV levers, Marvin Dual Exhaust, Harris Performance Grips, T-rex Sliders. Rizoma Conical bar, SSR Brake/Clutch cnc covers. Tammer G2 throttle tube.
« Reply #2 on: July 19, 2010, 11:20:58 AM »
did a search on Amazon, $14
RAT900
« Reply #3 on: July 19, 2010, 12:12:08 PM »
do they make one that will trigger heart attacks in the Floridians who come north in the summer?...
or one that will trigger involuntary bowel movements in soccer moms driving short bus SUVs?
DucatiTorrey
My wife's super hero is my
Industrial Designer
« Reply #4 on: July 19, 2010, 01:22:31 PM »
i definitely want a new horn, its either this or the stebels. anyone have experience with both?
  - real place
theprocess
'09 M696
« Reply #5 on: July 19, 2010, 04:05:08 PM »
Any auto supply shop for around 15 bucks.
Yes and Yes. Fiamm Ultimate Blast Horn (aka Stebel Nautilus).
 http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_6200020-P_x_x?cm_mmc=CSE-_-Shopping-_-VALUE3-_-VALUE4&srccode=cii_13736960&cpncode=21-67919424-2
From what Ive read the Stebel Nautilus is significantly louder but will require installing a relay (not plug-n-play).
DucatiTorrey
Industrial Designer
« Reply #6 on: July 19, 2010, 05:53:37 PM »
link?
  - real place
trpletme
« Reply #7 on: July 19, 2010, 06:26:12 PM »
Check this out.  Great comparo.
http://www.webbikeworld.com/motorcycle-horns/
Scooter-Trash
« Reply #8 on: July 19, 2010, 09:23:43 PM »
^^^ Bookmarked
Wonked
« Reply #9 on: July 20, 2010, 05:14:23 AM »
Love my Stebel Nautilus. You must install it properly (angle of horn, and relay). But it will wake the dead if you do.
TobyDanger
2007 S2R800
« Reply #10 on: July 20, 2010, 10:48:18 AM »
Waking the brain dead is what I need Wink
For the Stebel Nautilus, did you use one of the wiring harness kits ("deluxe" or "plug n play") or wire it yourself?  Wondering if the $20 is worth the hassle...
-=TobyDanger=-
"@[=g3,8d]\&fbb=-q]/hk%fg"
DucatiTorrey
Industrial Designer
« Reply #11 on: July 20, 2010, 02:10:28 PM »
+1
  - real place
r_ciao
My first Ducati.
« Reply #12 on: August 06, 2010, 07:47:18 PM »
how's is one supposed to know if a relay is necessary?  relays are cheap, but a plug n play horn is so much easier w/o changing out the relay.
'09 Monster 696+ Red, of course.
EvoTech Tail Tidy, SpeedyMoto frame sliders, 14T front sprocket
theprocess
'09 M696
« Reply #13 on: August 09, 2010, 03:40:16 AM »
Depends on the current drawn by the horn.  Stock horn button and wiring should be able to handle upto 5A.  Stebel Nautilus draws 18A, relay required.
r_ciao
My first Ducati.
« Reply #14 on: August 09, 2010, 06:12:12 AM »
Thank you theprocess.  That's exactly the definitive answer that I was looking for.  According to Fiamm, the Freeway Blaster uses 10A and it is suggested that I use a 10A in-line fuse when I wire it up.  I've read that others just do the plug n play.  While that may work, it probably isn't a good idea to forego the relay.  So now I just have to run out and get me some wiring accessories and wire according to the relay instructions.  I'll post up install pictures later...
Ciao!
Pages: [1] 2   Go Up
