CRG lever for ducati monster 1100 install help
Started by torck, July 20, 2010, 06:20:40 AM
torck
I have CRG lever and having a hard time putting the screw back in that hole that holds the lever. Seems like the hole doesn't like up right, but when I put back the original levers i had the same issue. Not sure what I'm doing wrong.
Veloce-Fino
Quote from: torck on July 20, 2010, 06:20:40 AM
Look here.  http://ducatimonsterforum.org/index.php?topic=14769.0
Put the pivot pin in the top of the lever. Pull the lever back as if you were using it normally. Wiggle it a bit and it should fall into place. You will not be able to push it through unless the lever is pulled in.
Is this thing on?
