February 13, 2025, 02:55:15 PM *
Pages: [1] 2   Go Down
Author Topic: JFF: Dream bike challenge  (Read 6215 times)
« on: August 03, 2010, 05:27:52 AM »
You have $10,000 to build your dream bike.
Post links to everything you purchase.
Yes, just $10,000.  Install labor is free, but paint, fabrication, engine work (i.e. head, crank, etc) work is not
You can buy any bike and customize it, but:
1.  It must be a Ducati.
2.  It can be any year or model.
3.  All parts must be commercially available or custom, but you have to post a link or info about the part(s).
4.  Must be either STREET or TRACK.
5.  Your starting bike should be as close to stock as possible.
the point is to show off what your "bike bucket" list is and what you'd do if you could.
JFF = just for fun
« Last Edit: August 03, 2010, 05:40:24 AM by ducatiz » Logged
« Reply #1 on: August 03, 2010, 05:32:06 AM »
This is the bike I would start with:
1997 900ss CR
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290458379467
10,000 - 3,999 = 6000
SIL header
http://www.spareshack.com/products/230/900SS-carb-91-98-Sil-motor-Spaghetti-Style-Headers.php
6000- 915 = 4100
Sharkskinz mono seat ($250) plus pads ($180) plus paint (200) = $630
Raceparts rearsets ($150)
HC pistons ($650)
Heads ported and flowed with the SIL exhaust ($800)
Nichols flywheel $450?
Bucci alu clutch $500
SIL high mount CF cans $800
will finish later... Cheesy
i think 10 grand was a lot to start with.. not much of a challenge.. maybe drop it to $5K?
« Last Edit: August 03, 2010, 03:06:33 PM by ducatiz » Logged
Jaman
« Reply #2 on: August 03, 2010, 07:03:41 AM »
^^ it makes me a little sad to see a beauty like that with so few miles of enjoyment...
speaking of dreambikes with too few (s)miles...
http://cgi.ebay.com/ebaymotors/2000-Ducati-996SPS-1134-Full-Ohlins-Mint-NO-RESERVE-/160461348490?cmd=ViewItem&pt=US_motorcycles&hash=item255c3dde8a
and speaking of dreambikes for under $10k... http://ducatimonsterforum.org/index.php?topic=40704.0
 needs nuthin'. waytogo
« Last Edit: August 03, 2010, 07:29:33 AM by Jaman » Logged
MotoCreations
« Reply #3 on: August 03, 2010, 07:05:41 AM »
Starting point: 1965 Ducati 250cc Scrambler -- $250
mods: remove and sell everything except for the engine and front/rear hubs ($244 to use elsewhere -- profit!)
build:
- motocreations 1934 Rudge frame but configured for Ducati single engine -- $1400 (mostly labor costs)
- motocreations girder fork w/shock and friction dampners -- $1800 (mostly labor / jigging to build)
- speedwell seat -- $145 (eBay)
- seat shock/spring -- $150 (eBay)
- rebuild Ducati engine with extensive mods (www.ducatiphoenix.com -- $1500)
- racing carb with velocity stack -- $400 (eBay)
- Buchanan relaced 21in wheels -- $800
- 21in Avon Speedway tires -- $300 (parts unlimited0
- re-line brake pads -- $55 (Tacoma Brake)
- reverse pull brake/clutch handles -- free (from Poland swapmeet)
- choke lever, decompression lever etc -- parts box
- custom headlight / taillight -- $800 (labor costs plus vintage lenses)
- motocreations aluminum fuel tank -- $1000
- custom fabricated rearsets / pegs (parts bin and some fabrication) -- $500
- cloth wiring - $200 (ask Stuart/FlightCycles)
- old fuse panel setup -- free (from UK swapmeet)
- steering dampner (friction) -- parts bin special with machined adjustment knob - $100
- paint -- leftover from a 1933 Alfa Romeo P3 racer (very dark red) -- free!
- sign painted graphics -- $500 (Dunn?)
- Ducati logos -- $600 (SeaCast in Seattle) to get cast in stainless and will enamel myself
- misc electrical -- $250
- steering tube bearings -- $125 (Tacoma Bearing & Screw)
- gauges -- custom made using vintage lens/faces  (myself)
- gauge cables -- $22
When done -- something that maybe Tazio Nuvolari (remember he was a famous motorcycle racer before becoming Italy's most famous racecar driver) might have ridden for the Scuderia Ferrari in @1935 and if powered by a Ducati racing engine.  Of course after building the first one the second one is easier and faster to build (and will be yellow or Ducati red and with a normal fork on it...)
Goal: to build something very different that is fun/unique and will get magazine coverage (already booked) for under $10K total outlay.
Hint -- see signature below
Ducatl
« Reply #4 on: August 03, 2010, 11:39:21 AM »
There are so many I'd like to do but here's one..
3-phase Carb model monster 750 selling everything but motor- $700?
Custom superlow hardtail trellis frame with single upper tube until rear wheel and round tube continuous axle plates like acme choppers, really tight fitment and clearances, built for skinny rear wheel - $1200
Custom tapered-tube style girder fork- $1000
Penske shock for fork- $600
Twin alloy tanks, 1 gas/1 electric - $1500
Custom 40 spoke 4.5" front hub drilled for single 5 bolt rotor, SS spokes and 18" alloy wheel- $500
Custom 18" 40 spoke 4.5" rear with sportster drum/sprocket combo- $300
Single Brembo race rotor- $300
Single 1098 caliper- $150
ISR master- $400
top clamp with integrated bars and internal throttle- $400
custom foot clutch with suicide shift- $200
Custom a123 battery- $100
Firestone replica rubber- $300
Custom Ribbed rear fender with small integrated tail light- $300
Custom solo seat with small shock and linkage- $200
Crime Scene Choppers Rapide headlight- $300
Misc wiring/lines- $200
Vintage carbs- $250
Paint/coat with the last $1000
« Reply #5 on: August 03, 2010, 02:25:27 PM »
2004 749S Crashed ~$800 thats the buyback price for my friends crashed 749S. Engine has been blueprinted and balanced already, includes Ducabike Slipper clutch and a bunch of other rashed up parts that are still good. But most of it will be sold off to help offset the budget.
and since ducatiz is doing 15,000 im doing $15,000 too...  Evil
This is actually what im going to do with it since im on an actual $2500 budget...
1098 forks + calipers - $800
Aluminum subframe - $350
ECU Flash (guages are destroyed) - $400
FP Racing Levers - $165
Nose fairing frame- $150
Armored Bodies fairing - $650
Total $2515 Which is right where i am at as far as budget goes.... now what else would i do with the rest of my $11,685?
Berringer Rotors Cast Iron $1050
http://www.bellissimoto.com/BeringerRotorsandKits.html
GPR steering Damper $500
http://www.bellissimoto.com/GPRDampers.html
Woodcraft Rearsets $350
http://www.bellissimoto.com/WoodcraftRearsets.html
Matris F05-R 1098 Fork Kit $1300
http://www.bellissimoto.com/MatrisForkKits.html
Matris M05-R shock $1500
Kyle Racing Throttle Tube $100
http://www.shop.kyleusa.com/product.sc?productId=252&categoryId=58
Quat D SS exhaust $1350+800 (will get a custom header with it, maybe $800 bucks for the header?
http://www.motowheels.com/italian/myProducts.cfm?parentcategoryid=1219|749%2F999%20%20Superbike&productID=4761&showDetail=1&categoryID=668|749%2F999%20Exhaust&vendoridtodisplay=0&filterFor=&collection=168|European%20Motorcycle%20Parts
Kyle Racing 30mm Triples (yea it says 1098 but they also make them for 749, if not MW has them too) $850
http://www.shop.kyleusa.com/product.sc?productId=304&categoryId=58
This leaves me at $7800 bucks total and $3885 to spend, so it ends up either as Carbon Fiber wheels or a bunch of tires... if we are playing with $10000, that only leaves me with $2200 which in that case, I would use it on trackdays and tires. Carbon Fiber wheels can eat my dust.
BST Carbon FIber wheels (yes for 1098 also, but thye make htem for 999) $3500
http://www.bellissimoto.com/BSTWheels.html
« Last Edit: August 03, 2010, 02:28:56 PM by He Man » Logged
« Reply #6 on: August 03, 2010, 02:28:03 PM »
It is cool how people spend for their dream bike
MotoCreations
« Reply #7 on: August 03, 2010, 04:21:17 PM »
with budgets of under $10K (or $15K)
If price was no object -- the extra Desmosedichi engine needs a custom chromoly chassis, restyled carbonfiber bodywork and a few other additions... and a slightly difference "stance/attitude adjustment" in my opinion. Can you say "DesmoDevil-sedichi"... Evil  (too bad the engine isn't actually mine)
« Last Edit: August 03, 2010, 04:23:24 PM by MotoCreations » Logged
« Reply #8 on: August 03, 2010, 04:30:38 PM »
having a limited budget makes it more interesting because people have to make choices.
what's more important?  or what does one THINK is more important?
« Reply #9 on: August 04, 2010, 05:18:13 PM »
depends on how your economic situation looks.
I dont have a lot of money, in fact ive never been as broke as I am today. And owning a ducati doesnt help for sure. which is why i do most of my own things, so i cant justify spending $350 on rizoma levers, when FP racing levers are half the price and function the same. If you have a budget to spend, spend it on something that is worth spending on..suspension, not NCR clutch covers that are over priced Evil
if you want to drop the price down to 5k, then just delete everything i spent on shit i wouldnt buy anyway cause i cant afford it. and stic kwith
749S $800
actual mods, or really parts i have to replace because they no longer work $2500
remaining $1700 would be enough to pay for a years worth of trackday expenses + tires.
« Last Edit: August 04, 2010, 05:21:18 PM by He Man » Logged
Javamoose
« Reply #10 on: August 04, 2010, 06:48:42 PM »
Done. I would be happy.  [moto]
2000 M750
« Reply #11 on: August 05, 2010, 04:10:08 PM »
I haven't priced it out, but my dream bike would something similar to this Radical Ducati.
Superbike frame
S2R swingarm
Air-cooled engine
V-Rod headlight
Custom bodywork
Custom Exhaust
I've got a hunch that it would be hard to keep it under $10K, but maybe I could do it by finding the parts cheap enough over a period of time and staying away from the high dollar stuff like the Ohlins shock.
« Reply #12 on: August 06, 2010, 05:18:07 AM »
For 10k?
« Reply #13 on: August 06, 2010, 05:49:35 AM »
No. But knowing of the existence of this motorcycle precludes me from dreaming of others.
I can delete the post if it doesn't fit in the thread.
sac
whole point is what can you do for 10 grand...not what can you go out and buy from someone else..  Roll Eyes
SacDuc
WWSDD?
« Reply #14 on: August 06, 2010, 05:57:10 AM »
Okay dude. Chill a bit, no need to get all eye rolly on me. I'll delete the previous posts. No worries.  chug
sac
HATERS GONNA HATE.
Pages: [1] 2   Go Up
