Open VS Closed clutch?
Started by desmodoktor, August 21, 2010, 09:46:16 AM
desmodoktor
what are the + & - of having an open/closed clutch. what i mean is having the stock clutch closed cover.. or upgrading it with an open one *(aftermarket)
just wondering.
IG @desmodoktor & @ridingturtlegarage
krolik
Coolness factor.
Open clutch =  8)
fastwin
Leave it stock but always give your passengers a tambourine! [laugh]
Personally I just like the way other drivers at intersections and pedestrians stare at it and wonder if it's about to blow up.
the reasons for it are supposed to be functional.
cooler as in not hot
cleaner as in no dust buildup
BUT it is cool as in I want it. course my wet clutch would be a mess.
It's definitely something to look at when its open. It spins differently when its in gear vs idle.
Greg
2012 M1100 Evo with Termis
desmodoktor
Quote from: D Paoli on August 21, 2010, 01:48:52 PM
what do u mean???  ???
Kopfjager
1KDS
^^^There you go Raux, dry clutch conversion, kopfjager did it to his
Every bike I've ever owned.
more noise
better cooling
potentially more debris entering
moisture/rain entering
There's the joy of dropping it on the clutch side while it's running and it lands on your leg. This is not to be underrated.
Of course, it ain't broke......
Quote from: SA_S2R on August 21, 2010, 02:32:50 PM
Quote from: svp88 on August 21, 2010, 02:39:20 PM
I mean watch one spinning with the clutch engaged vs in Idle. I don't know how else to explain it.
Quote from: kopfjäger on August 21, 2010, 02:45:14 PM
For the bling.  ;)
Ducati 848 dry clutch
That is by default the coolest 848 around. The dry clutch is the only major thing missing from that bike. Are you sure that's not a 1098 with 848 stickers on it?
Kopfjager
Quote from: D Paoli on August 21, 2010, 07:05:37 PM
Positive. That kit has been out for over a year.
don't worry i know about the conversion. i have the thread saved on my favorites on how to do it, what parts, etc.
That is a better looking conversion than Duc Stews 750 conversion. I was impressed with his but this looks factory.
