February 12, 2025, 12:16:06 PM
Please Help
Open VS Closed clutch?
Topic: Open VS Closed clutch? (Read 12430 times)
truckinduc
Re: Open VS Closed clutch?
Reply #30 on:
August 22, 2010, 02:35:09 PM »
no im not saying you will gain anything. I just believe it will take longer to start slipping due to overheating.
The best kind of whore is a
Reply #31 on:
August 22, 2010, 02:35:44 PM »
Found pics
didn't break the skin, but it still scabed over.
I'd do it all over again
Monstermash
AKA-TomColore
Interferiscalo se potete
Reply #32 on:
August 22, 2010, 03:26:12 PM »
Quote from: D Paoli on August 21, 2010, 06:05:37 PM
The dry clutch is the only major thing missing from that bike.
I have to respectfully disagree with this statement. While I will agree the wet clutch is definitely not cool, the brakes on the 848 suck once the pace heats up a little. And the bike seriously needs a damper.
Last Edit: August 22, 2010, 06:30:59 PM by Monstermash
fastwin
Reply #33 on:
August 22, 2010, 03:50:59 PM »
Cost cutting.
Triple J
Reply #34 on:
August 23, 2010, 05:13:58 AM »
Quote from: Monstermash on August 22, 2010, 03:26:12 PM
848 brakes suck...really? I agree about the damper, but the brakes are more than adequate.
duccarlos
Reply #35 on:
August 23, 2010, 06:57:59 AM »
I would love to swap out my wet clutch, but for the money, I might as well sell my bike and buy an S2R 1000.
Feral 859
Reply #36 on:
August 23, 2010, 07:06:56 AM »
Quote from: duccarlos on August 23, 2010, 06:57:59 AM
Or swap in a 1000DS motor.
duccarlos
Reply #37 on:
August 23, 2010, 07:26:21 AM »
That too.
For $50 you can touch my
Reply #38 on:
August 23, 2010, 11:34:32 AM »
I never had an issue with the dry clutch on my duc and the cover was never opened, or cleaned out, in a solid 30K miles.
A clutch should not require the maintenance some people have mentioned in this thread.
Reply #39 on:
August 23, 2010, 12:01:31 PM »
I agree with the dave.
The "better cooling" argument is a lame excuse.
Clutches get opened up because being able to see spinning things is cool and the sound is cool.
It's 100% cool factor 0% reliability improvement.
Reply #40 on:
August 23, 2010, 12:31:06 PM »
The cooling issue is relevant but not for normal street use.
Triple J
Reply #41 on:
August 23, 2010, 12:35:49 PM »
Open clutches do let the clutch dust out. If I ran my MTS closed, the clutch would start making a moaning sound right at take-off after about 3K miles. I'd have to remove the cover and blow it out with air to make it quit. Didn't seem to affect performance, but it was annoying.
When I switched to open I never had to do that again.
Reply #42 on:
August 23, 2010, 12:39:10 PM »
Quote from: MrIncredible on August 23, 2010, 11:34:32 AM
I went from DP open carbon cover to stock closed. Sounded like a chaff cutter. Have to say I only open up the cover to clean/service the clutch when changing the plates or springs.
Speaking of chaff cutters, the kids are wondering why I'm laughing so much. It's the new avatar!
Last Edit: August 23, 2010, 12:42:58 PM by koko64
Reply #43 on:
August 23, 2010, 12:45:38 PM »
Quote from: Triple J on August 23, 2010, 12:35:49 PM
Yeah I reckon that's true having tried both.
Monstermash
AKA-TomColore
Reply #44 on:
August 23, 2010, 01:22:48 PM »
Quote from: Triple J on August 23, 2010, 05:13:58 AM
Maybe for casual street riding the brake are adequate. That being said, the word "adequate" doesn't exactly translate into steller. The 1098 brakes are an entirely different story. Do you realize the 848 comes with the same calipers that are on the 696?
Have you ever ridden an 848 at the track? I have and believe me the brakes completely suck ass once the pace heats up. After two laps the brakes began to fade and I couldn't hit my markers consistantly without fear of going into the turn too hot. It doesn't exactly exude confidence.
