Bizzarrini
Showing off his
'94 M900
« on: June 09, 2008, 01:48:34 AM » |
"As a final touch, God created the Dutch"
Bizzarrini
Showing off his
'94 M900
« Reply #1 on: June 09, 2008, 01:50:31 AM » |
« Reply #2 on: June 09, 2008, 06:43:09 AM » |
Xenon is a gas and running an electric arc through it excites the atoms and causes it to produce light. Atleast tahts how i think it works. Those look like they are litterally blue halogen light bulbs. Plus it would be a rip off since you only need one H4. I wouldnt bother with it.
LUKE
07 S4RT Green Bay, WI
« Reply #3 on: June 09, 2008, 09:20:12 AM » |
I purchased something like this. I got them because they are brighter than stock and I often take back roads home. That being said they nothing more than normal bulbs with blue on the glass. True HID is on my shortlist.
olivs
« Reply #4 on: June 09, 2008, 09:59:31 AM » |
mmakay
« Reply #5 on: June 09, 2008, 10:27:04 AM » |
True HID set-ups can be had for as little as $85. That's all I spent and the difference is night and day (pun fully intended). Blue bulbs won't help you see any better, no matter what they claim.
- Mickey
RandyFloyd
2007 S2R 800
« Reply #6 on: June 09, 2008, 10:32:21 AM » |
I'd go with either HID's or Sylvania Silverstar's...
« Reply #7 on: June 09, 2008, 01:22:21 PM » |
My biggest question is, what is the quality of the Ballast for those cheapie $85? Because ive been dying to pull the trigger on a set of 2 Bixenon ballasts+bublbs+ wire harness. ( i have duals ). The cheap ebay ones can be had for as little as 125 bucks.
peaveybassist
« Reply #8 on: June 09, 2008, 01:51:05 PM » |
Search on DML for the HID stuff from hondatech. I got mine for $95 I think with a slim ballast and plugs to just plug'n'play with the H4 setup. Cheap and it has worked well so far. I've had it for about 4 months now. Awesome badass light output.
knightrider
« Reply #9 on: June 09, 2008, 03:03:00 PM » |
imo never buy bulbs that have a blue coating, the coating accually cuts down on the available light output and its only for looks. hid look is just that, a look, not the performance. and you have to be careful with putting hid into a halogen housing because you will cause glare for oncoming drivers and is illegal in most states.
1994 M900
northerncalguy
« Reply #10 on: June 09, 2008, 03:46:18 PM » |
Agree with others in the thread that true HID is the best option for clarity and brightness while riding at nite.
On a related note, for those that have HID & ballasts, does your lamp ever "not turn on" during at startup? I've found that I need to flick the high beam on and off after starting the engine to get the lamp to fire. I think this is somehow related to a relay, but not quite sure...I have the one from the bspec guys that I found through the Honda forums.
« Reply #11 on: June 09, 2008, 04:11:05 PM » |
thats usually the sign of a dying ballast or a cheap one that is unable to generate the right voltage to start the light. Again, cheap bixenons can be had for under $60 per bulb+ballast. THe question becomes whats the quality of those chinese ballasts?
Heath
« Reply #12 on: June 09, 2008, 05:53:54 PM » |
PIAA Xtreme White Plus Bulb- H4 Single Pack Part #PIAA-15214 is what I run and I love it. I got it off eBay, if you look on the TOB there was a website for bulbs from Europe. Supposedly they have ones that last longer then ones we can get in the states.
2007 Ducati Monster S4RT 2006 Ducati Monster S2R800 Dark [sold]
« Reply #13 on: June 09, 2008, 05:55:37 PM » |
I have a Silverstar and I like the additional output.
2006 S2R1000 2015 Monster 821
Scooter-Trash
« Reply #14 on: June 10, 2008, 07:35:26 AM » |
A few manufacturers make make conventional bubs with xenon vs the usual inert gas they use. I call these bulbs HID-lite (no pun intended) and they do give a slight boost to the light (but not much)
Not really worth it, IMHO.
So +1 on the Silverstars if you're looking to save money (I use one and it's great).
