February 22, 2025, 12:50:19 AM *
Author Topic: wierd oil leak near swingarm  (Read 3199 times)
« on: November 14, 2010, 08:12:20 AM »
Does the motor constantly oil the swingarm pivot?
I have oil on the swing arm coming from that area.
« Reply #1 on: November 14, 2010, 08:46:53 AM »
No.  That was an old Super Sport trick I'm sure the EPA would frown upon today.  Clean, ride, inspect.  If that doesn't work. clean, spray with aerosol powder, ride, inspect.  The oil trail in the powder will lead you to the leak.  Remember, oil travels when you ride.  The oil may not be coming from the rear of the engine.
« Reply #2 on: November 14, 2010, 08:56:05 AM »
ok, well that eliminates that possibility.
what's wierd is that i cannot see any oil from any other location except on the swingarm behind the rearset on the left side
i'm not low on clutch fluid so thinking it can't be the slave cylinder.
DarkStaR
« Reply #3 on: November 14, 2010, 11:57:36 AM »
Excess chain lube?
Clutch push rod o-rings?
Got a pic?
« Reply #4 on: November 14, 2010, 12:01:57 PM »
Excess chain lube?
Got a pic?
no pics. not chain oil. use teflon clear.
has consistency of motoroil, maybe dirty clutch fluid (which like I said isn't low)
ReapeR696
« Reply #5 on: November 14, 2010, 04:15:27 PM »
Raux, check your cam inspection cover on your verticle cylinder. I've been dealing with a small leak on mine and your symptoms sound similar (small drops of oil on the top of the swing arm). Use a bright flash light and look for a shiny reflection of oil near the cover or just use powder like another board member mentioned. If that's it you will need new o rings. I changed mine out but no luck, now i'm thinking gaskets to fix the problem. Hope this helps brother......
« Reply #6 on: November 14, 2010, 09:27:21 PM »
thanks I'll check that today
GAAN
« Reply #7 on: November 15, 2010, 03:36:52 PM »
I've had a leak around that area and it was from the crankcase breather assembly
devimau
« Reply #8 on: November 15, 2010, 06:52:46 PM »
remove the slave and check the push rod o'rings.....
« Reply #9 on: November 15, 2010, 07:51:36 PM »
+1
+1
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #10 on: November 16, 2010, 03:56:31 AM »
+1 too
WetDuc
AKA iamhybris
« Reply #11 on: November 16, 2010, 10:35:36 AM »
Two 696's around here just had leakage coming from the vertical valve inspection covers, but it was pretty obvious when following the oil upstream to the source.  I'm not sure how it would get down there without you seeing a clear oil path.
« Reply #12 on: November 18, 2010, 02:57:16 PM »
check the cam cover: good
check the breather: good
need to check the valve cover when i have more time
