February 22, 2025, 01:43:41 AM
Please Help
Battery tender for 696?
Topic: Battery tender for 696? (Read 4388 times)
Dr. D
December 18, 2010, 02:38:17 PM »
This winter is starting too cold for me to ride enough to keep the bike happy. I want to install a wire so I can connect a battery tender during the longer breaks. Is there a 'how to' for installing such a connector? Is there a part number, or manufacturer of the connector?
Peter
'08 BMW K1200GT
dgm
Re: Battery tender for 696?
December 18, 2010, 02:46:00 PM »
Are you sure it didn't come with one installed? Mine did and I gather several dealers install the cable for a battery tender when they set the bike up. Otherwise, I think the general recommendation (and certainly mine) would be a battery tender. It'll come with a connection for the battery, which involves removing the panels, the tank and then connecting the cable to the batt. Was a 5 minute job on my harley. Not so much on these.
2009 696, Termi CF Pipes ECU Intake, Woodcraft Rearsets, Fender Elim, Shorty Pazzo Levers, CRG Lane Splitters, DP Low Seat, Powder Coated Bits, Speedymoto Frame Sliders, Rizoma Front Sliders, Rhinomoto Rear Sliders, Shorai Batt, Billet Oil Cap, iPhone Mount, LED Blinkers, Leggero Sprocket Cover, TPO Corsa Crankshaft Cover, Canister Delete/Euro Shroud, 14T Front Sprocket
sisca77
December 18, 2010, 05:06:50 PM »
Yep. Mine came with the connector.
Dr. D
December 18, 2010, 07:08:14 PM »
Quote from: sisca77 on December 18, 2010, 05:06:50 PM
Uh, mine didn't. Went out and checked it. Nope.
Peter
'08 BMW K1200GT
dgm
December 19, 2010, 09:10:48 AM »
Quote from: Dr. D on December 18, 2010, 07:08:14 PM
Bummer... then you have to remove the tank to get to the battery. It's not terribly hard, just lots of little screws/bolts. A little time consuming.
Dr. D
December 19, 2010, 10:50:45 AM »
Quote from: dgm on December 19, 2010, 09:10:48 AM
Where can I find instructions? I suppose I could just start taking off parts, but I would rather not mess with a part that isn't going to be in the way. And there always seems to be a fastener which isn't obvious.
About the pigtail: How long? I've found one that is two feet, which seems long enough. Is it? Is there a DP pigtail?
Last Edit: December 19, 2010, 10:53:34 AM by Dr. D
Peter
'08 BMW K1200GT
December 19, 2010, 12:07:22 PM »
Some people have been saying on the newer bikes there a Ducati specific battery charger in the tool tray.
If you still don't have that (don't confuse the DDA plug)
then search the tech section. there are a few copies of the instructions in there
alibaba
December 19, 2010, 07:46:56 PM »
I just went thru this process of accessing the battery on my M696 3 times in the last 2 days for various reasons. In spite of what others say, it is a PITA job with lots of small screws, spacers, and clips to fall off and roll away. There is a trick to removing the side panels. There is a hidden bolt under the seat and when all is free, prying up and raising the tank is still not easy. I think I have the drill down. If you run into a problem, email me direct at
a.baba@mindspring.com
Dr. D
December 20, 2010, 03:07:04 AM »
Thanks!
Peter
'08 BMW K1200GT
sisca77
December 20, 2010, 11:44:21 AM »
Thought this may help:
Ducati Monster 696 Battery Tender Connector Installation
Good luck.
jchurch
December 20, 2010, 01:22:03 PM »
My bike didn't come with the tender plug either (M1100 09). Apparently its your dealers decision if he will install it or not.
I already had a C-Tek charger so which I had just purchased before upgrading so I just installed it myself no real issue and it works a treat. I even have the cigarette lighter plug for it to charge iphone when on the move so its a handy thing to have.
Current Bike: 09 M1100
Previous Bike(s): 02 M900I.E
04 Aprilia RS125
CDChase1981
December 20, 2010, 02:45:30 PM »
My 2009 696 came with one installed. Mine is on the left side, near the charcoal canister.
2009 Pearl White 696. DP Touring Seat, DP Carbon tank protector, carbon fiber front fender, Rizoma Class Retro bar end mirrors, CW tail chop, and CW tail light w/integrated blinkers.
Dr. D
December 20, 2010, 05:03:08 PM »
You guys rock. That battery access sucks.
Peter
'08 BMW K1200GT
OT
Still Sweeping.....
December 24, 2010, 09:10:39 AM »
The fused rat/pigtail connecter should come with the Battery Tender...
I also installed a Powerlet BMW-style socket kit on my bike (mounts to frame). I use it for the Battery Tender cable when bike's in garage and the Gerbings heated vest plug when riding. IMO, safer, and easier to use, and more flexible apps than the 'tail....
http://www.powerlet.com/products
