ML's machine shop thread
Started by Monsterlover, January 31, 2011, 03:39:33 PM
Well, all my live milling holders are shot.  Rode hard and put away wet too many times.
I sent the worst one out for rebuild.  $800.  I have one more at that price to go and 2 at $900ea :o
I ordered a TPO floating rotor button so I can measure it up and make a bunch of my own.  Their website says they fit pretty much all Ducati's so that's nice that one part fits everything.
I am also quoting helicopter parts :o :o :o :o :o :o :o
Ddan
I think TPO sends a shim for the thinner rotors.  I measure roughly 5.5mm on snowflake carriers and 4.0 on the stockers.
Ducati Monster Forum at
www.ducatimonsterforum.org
Seems like it includes the clip and shim.
I take it the shim is in the 1-1.5mm range on it's thickness?
Ddan
Quote from: Monsterlover on June 24, 2011, 11:10:47 AM
I would guess so, I don't have any yet until you make some    ;D
I need 20 of each size please.
Shot some footage of chips flying.
These are 8620 steel shafts that just needed faced to length and the OD roughed and finished.
I would call the rough pass a fairly aggressive cut.  And really, the insert lasted too long, so if I ever get these again, I'm going faster next time :D
8620 Shafts.MP4
Jumptship
Never get tired of watching the mills, lathes, and water jet working in the Metals Tech shop on base.  They can really do some cool stuff.
This has been a test of the Emergency Broadcast System.
DesmoDiva
#249
*oops. wrong thread.   :-[
musta been too much  [wine]
'01 ST4 Yellow
'02 ST4s Yellow
Holy God...
We hooked up my high pressure coolant tonight.
Its like going from a super soaker to a fire hose.
It puts out 1000psi but I'm only at 500 right now.
What a difference!!
Oldfisti
Quote from: Monsterlover on August 08, 2011, 05:33:21 PM
Holy God...
What a difference!!
Does it basically pressure wash the chips away from the tooling?
Well, it serves two purposes.
When cutting metal you're limited by 2 things (mainly)  Generated heat and chip evacuation.
I had an insert drill running (1.5" diameter drill) at like 1300 rpm and the chips were starting to discolor (straw color)
With HP coolant I was able to almost double that rpm and the chips show no discoloration at all.  Speed = good :D
Additionally, since this unit flows 8gpm it washes chips away like crazy :)
I should take video even though it's hard to see (bad lighting and reflection on the window)
cokey
Stick ya hand inside with the cam, but have an extra video camera ready
I WIN
About the goat...
My gopro is waterproof, but my machine defaults to setup mode when the door opens.
That means I have to hit go like 10 million times.
Not happenin'
;D
