Goldline Caliper Pinch bolts - torque setting?
Started by junior varsity, February 14, 2011, 12:02:35 PM
The 4 bolts that hold the two piece calipers together - what is the appropriate torque value for this?   (Not the one in the owners manual that describes the caliper mounting bolts that attach caliper to fork bottom).
I've seen 29NM dry, 30-35nm with loctite, and 40NM when searching online. I had at one time found a definitive answer for this but cannot locate the bookmark.
I talking about the 4 bolts seen along the top edge of the caliper, shown here:
http://tinyurl.com/4ehhvgl
(because i want 'em too look this good on the other 900 too)
No loctite.
I torque mine (goldline and otherwise) to 25 ft lbs which is about 35 nm.  If you MUST use loctite, do not use Red, use the thread seal or blue.  I've built dozens with this, no problems.
why no loctite on what seems like critical area?
next questiooooon. ti bolts. i have always used antiseize. would antiseize be unwise in this application?
I'd use something on the threads to keep them from seizing.
Grease or anti-seize I'd think.
You might want to up the torque a few pounds to compensate for the lubed threads.
good news. just got word back from Allen @  TPO (they make the Ti through-bolts or pinch bolts) and he said
QuoteI have always used 35 NM with loctite and never had a problem
That's two of you and that seems quite alright with me.
Quote from: a m on February 14, 2011, 02:35:55 PM
Did he say what color loctite?
I agree with 'Tiz about no red.
he did not.
and if you are thinking no red, then i shall use blue.
I would use Green 29000 or Blue.  29000 is yet a weaker form of loctite.
The screws are torque and there is no lateral stress to loosen them.  Unlike some materials, the caliper bodies do not expand much.
Blue or Green 29000.  (there are two types of green)
It's settled then. ;D
Don't use the green sleeve retainer. You'll never get them out. [laugh]
These are going on a set of the billet 2-piece calipers, so "goldline" is misleading, except that everything seems to be identical so far when taking them part.
Quote from: a m on February 14, 2011, 03:07:53 PM
It's still a caliper.
Don't confuse yourself with over thinking. ;)
Quote from: ducpainter on February 14, 2011, 03:06:45 PM
yeah, that's the other Green Loctite.  Not for threads.
The only thing I still need is 1 o-ring that seals the two caliper halves together.   I've got one good one, now I just need a source for the other.
Apparently that will prove more difficult than most other tasks, as the parts fiche don't break down far enough to give me a part number for that o-ring, and apparently Brembo doesn't do 'spares' for regular machines.
Any thoughts on how to find replacement seals / o-rings for the Brembo calipers? They are the 30/34's. I can "kind of" measure the one O-ring I have (approx. 1.5mm thick, 10mm OD, 6mm ID), but then when it comes to material for use in brakes, it seems difficult (does Aflas take the #1 spot? Can't find a perfect match on McMaster-Carr)
