$8 Less/quart???
Started by dgm, February 19, 2011, 05:13:31 PM
Quote from: Punx Clever on February 20, 2011, 02:14:05 PM
I would have liked to see a press-fit steel insert for the oil drain plug like my truck has in it's aluminum pan.  Just sayin.
Write them a letter.  [laugh] [laugh] [laugh] [laugh] A pressed in steel insert is a bad idea IMO. Too much chance for a galvanic reaction and potential failure.
I personally don't see the big deal. Certainly nothing to get pissed off about.
We all realize the washer is there. If you think you need a new one every time you change oil, buy a half dozen at a time. They're not very expensive.
I use them many times without any issue.
Punx Clever
A good carbon steel insert wouldn't be much of a problem because carbon steel and aluminum are pretty much right next to each other on galvanic charts.  A drain plug with a silicon o-ring in the head to seal out moisture would prevent any corrosion issues from everyday moisture.  A stainless steel insert would definitely cause the problems you are talking about.  On the other hand, when I say "pissed" I mean mildly annoyed at a quirk in the design... not pissed like my tank is expanding and the paint is flaking off.
2008 S2R 1000 - Archangel
Ducatisti asked/begged for plastic tanks and Ducati delivered. Look at how that worked out.
I say leave the drain plug alone. It isn't broke.
ivobivo
I used the same crush washer 7-8 times on my Monster and never had a problem. For my new bike I just ordered an Aluminum plug from TPO that comes with some kind of rubber seal. We'll see how it works. Here's a link to it
https://www.tpoparts.com/cat093/index.php?route=product/product&path=1_29&product_id=11
2007 Monster 695
2006 PS1000LE
Punx Clever
Very interesting.  I like it!
dgm
Quote from: xcaptainxbloodx on February 20, 2011, 01:05:00 PM
if you use a clean oil pan you can put it back in...
I didn't.   My pan was not clean enough for me to considering putting it back in.   [bang]
2009 696, Termi CF Pipes ECU Intake, Woodcraft Rearsets, Fender Elim, Shorty Pazzo Levers, CRG Lane Splitters, DP Low Seat, Powder Coated Bits, Speedymoto Frame Sliders, Rizoma Front Sliders, Rhinomoto Rear Sliders, Shorai Batt, Billet Oil Cap, iPhone Mount, LED Blinkers, Leggero Sprocket Cover, TPO Corsa Crankshaft Cover, Canister Delete/Euro Shroud, 14T Front Sprocket
Quote from: Punx Clever on February 20, 2011, 02:41:39 PM
Hardly a quirk, 20+ oil changes with no problems.  Never a problem with any of my cars with aluminum pans.  I use new crush washers if I have them.  If not, I don't.
drain plug with crush washer has been there for 30+ years, works fine for me.
Quote from: ducatiz on February 20, 2011, 08:26:41 PM
Why do I picture you saying this at the top of your lungs, in a rocking chain on your porch, waving a cane?  [laugh]
Quote from: Drunken Monkey on February 20, 2011, 08:59:14 PM
Because you need to get off his lawn.
daaaaaggnabbit!
Quote from: bobspapa on February 19, 2011, 05:21:01 PM
please tell me you didnt put CAR oil in it
What's wrong with that?
Quote from: bobspapa on February 19, 2011, 05:39:34 PM
AFAIK the 4t is.... but out here, the auto store dont sell bike oil, so thats why I questioned it.... plus, we get a shit ton of people asking if car oil will work simply because it's cheaper.
the Mobil1 "high mileage" 10w40 for cars apparently is remarkably similar to the Mobil1 4T 10w40
Don't let my Molly and Syreena see this thread...
Their belts my curl if they new they were getter diesel formulated Rotella...
JM
greenohawk69
Quote from: dgm on February 20, 2011, 08:53:47 AM
cool, I'll spend some time reading that thread you reference buckethead.  I did try to drain as much of the motul out as I could before putting the Mobil 1 in.  there shouldn't be an issue with the two of them mixing in there right?
OH, and where can I order crush washers for the 696 online?  The seem a little hard to find.
Have you tried a hardware store or maybe something like Fastenal or Grainger?
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
